Gruppem - Civinfo
 8Likes
post #1 of 37 (permalink) Old 14th February 2017, 01:31 Thread Starter
nunoctr's Avatar
Gruppem
3 types
http://www.gruppem.co.jp/news/?itemid=558
nunoctr is offline
post #2 of 37 (permalink) Old 14th February 2017, 06:25
Cigar Chomper
Loxy's Avatar
Car: F30 330d xDrive LCI
Originally Posted by nunoctr View Post
Looks like the most lazy design to date yet. It's just a cone filter on the end of the intake pipe.
Cheers for posting though
Loxy is offline
post #3 of 37 (permalink) Old 15th February 2017, 13:36
GC
Noxia's Avatar
Car: 2016 FK2R - Crystal Black
What makes it GruppeM if it's jus a K&N and using standard duct thing? Am I missing something here.
Noxia is offline
post #4 of 37 (permalink) Old 15th February 2017, 18:18
veehexx's Avatar
Car: 2015 CTR FK2
so we have 2 big manufacturers taking air feed from engine bay, and ..what.. just one dyno readout of 30bhp loss with such a filter?
Interesting. i'm keeping my eye on dyno threads more... £/bhp might come into the results.
veehexx is offline
post #5 of 37 (permalink) Old 15th February 2017, 18:49
regrets his username
dweezle's Avatar
Car: 1.6 focus RS
Got excited when I read GruppeM, Not sure what they were thinking with that one
dweezle is offline
post #6 of 37 (permalink) Old 15th February 2017, 21:15
Dyno runs are usually performed with the bonnet open and with big fans blowing on the engine. Not really realistic.
CTR1633 is offline
post #7 of 37 (permalink) Old 16th February 2017, 08:35
veehexx's Avatar
Car: 2015 CTR FK2
exactly. someone posted 30bhp loss on the injen on dyno, and now everyone is avoiding it like the plague. If it's worse with the bonnet shut, then i cant see how these things are being released from known reputable companies. maybe from a supplier on ebay, but not injen or gruppeM.
oh, i'm not saying these type of filters perform as well as ducted systems, i'm just skeptical to the claimed loss of power figures. so much so, if i had the money i'd test it myself.
veehexx is offline
post #8 of 37 (permalink) Old 16th February 2017, 11:11
GC
Noxia's Avatar
Yet we have a member who said +17bhp. The injen one is confusing.
veehexx likes this.
Noxia is offline
post #9 of 37 (permalink) Old 16th February 2017, 11:48
dweezle's Avatar
Car: 1.6 focus RS
Isn't there talks over on civicturbo of the eventuri not delivering the bhp they advertised
dweezle is offline
post #10 of 37 (permalink) Old 16th February 2017, 12:36
GC
Noxia's Avatar
Not seen it but it wouldn't surprise me on anything with quoted power gains as we don't know the conditions for testing.
Noxia is offline
post #11 of 37 (permalink) Old 16th February 2017, 12:41
flashy's Avatar
Car: NHB FN2 CTR GT
Vented bonnet?
flashy is online now
post #12 of 37 (permalink) Old 16th February 2017, 12:56 Thread Starter
nunoctr's Avatar
this gruppem is the "normal" one they sell, not the ram air models more expensive.
One thing you have to look is the maf housing. Gruppem knows their business on this. Look at the Fn2 model. It worked with a stock car were 99% of the other intakes didn't because of the incorrect maf housing
The first one of this M's intakes have a giant filter. Probably the biggest one I have seen on a stock car. So the only thing it needs is a cold air feed.
The stock rubber pipe is not a problem. Also eventuri intake works with it.
nunoctr is offline
post #13 of 37 (permalink) Old 16th February 2017, 13:06 Thread Starter
nunoctr's Avatar
Í forgot to say. I wil not buy it as I don't like "open" intakes.
nunoctr is offline
post #14 of 37 (permalink) Old 16th February 2017, 13:37
GC
Noxia's Avatar
I just likes whatever is noisy. Would love an HKS RSK level noise one.
Noxia is offline
post #15 of 37 (permalink) Old 16th February 2017, 18:09 Thread Starter
nunoctr's Avatar
the first one should make big noise, but never as a NA car
nunoctr is offline
post #16 of 37 (permalink) Old 16th February 2017, 19:02
veehexx's Avatar
Car: 2015 CTR FK2
yep. half the quoted figure. which imo is about right. I'm not sure anyone sees the gains the manufacturers claim.
thing is, as we all know there are many variables that affect performance: temp, humidity, fuel, height from sea level (air density), dyno hardware.
Someone mentioned (probably civicturbo forum) you need to run dyno of before and after mods, and reruns close as possible to keep variables as identical as possible.
quick look into things; 3% (rough rule of thumb) HP loss for every 1000ft elevation increase from sea level. for us on 306bhp thats 10 per 1000ft. EDIT < wrong info. see chris reply 2 below...
veehexx is offline
post #17 of 37 (permalink) Old 16th February 2017, 21:14
Dyno runs should use corrected values, according to a standard. Otherwise you can't compare numbers.
CTR1633 is offline
post #18 of 37 (permalink) Old 16th February 2017, 21:53
chrisr111's Avatar
Originally Posted by veehexx View Post
height from sea level (air density)..........quick look into things; 3% (rough rule of thumb) HP loss for every 1000ft elevation increase from sea level. for us on 306bhp thats 10 per 1000ft.
The above only applies to NA
Makes no difference to a turbo car
Chris.
veehexx likes this.
chrisr111 is offline
Thanks to chrisr111 from:
post #19 of 37 (permalink) Old 17th February 2017, 16:59
Helmigurt's Avatar
Car: 2016 CTR GT, Polished Metal
Chris.
That's not true. High elevation changes turbo behaviour as well: The short answer is that the turbo has to spool up to a higher rpm to generate the same amount of boost. Higher elevation therefore means you need higher rpm till full boost kicks in which obviously makes the car slower.
There's also a maximum RPM the turbo can spool so at higher elevation you usually loose some max boost as well because the turbo is already a max RPM but can't produce max RPM.
The loss is lower compared to natural aspirated engines but it's there nonetheless.
Helmigurt is offline
post #20 of 37 (permalink) Old 17th February 2017, 17:08
In the NL we have the greatest horsepower in the world, it's true. We are below sea level, it's great, it's true. 😀
Helmigurt likes this.
CTR1633 is offline
  Civinfo > Civic Type R > 9G Type R
Human Verification
GruppeM Milano FN2 Type-R 4 1st February 2013 20:49
