Commercial user
![]() Join Date: 14th March 2008
Thanks given: 133
Winter Tyres & Wheels @ ABP
Winter Tyres in the UK
Should we all be using 'cold weather' tyres? In many parts of mainland Europe where winter weather conditions are generally more severe and more predictable than in the UK it is common practice, or even a legal requirement, for drivers to keep two sets of wheels and tyres a set of 'summer' tyres and a set of specialist 'winter' tyres. Winter tyres use a tread rubber compound (high silica content) and tread pattern specifically designed to retain flexibility in low temperatures (below +7C) and give good braking/traction performance on snow/ice as well as on wet roads in cold conditions . The sidewall of a winter tyre will be marked with a symbol showing a snowflake or snow-topped mountains. Winter tyres are not really suited to all year round use though summer tyres will give better performance when temperatures are higher and roads dry so two sets of tyres are required if you're going to choose specialist tyres for winter. Why are winter tyres not compulsory in the UK? There are several practical and economic reasons why winter tyres are not compulsory in this country.
Winter tyres make sense for drivers living in the more remote areas of the country where winter conditions are likely to be more severe for longer. Such areas are probably already targeted by tyre manufacturers' marketing campaigns and you may find tyre fitters offering tailored storage and fitting services in these areas too. Read what others drivers say about winter tyres in The Zone » Elsewhere it may be harder to justify the cost, though this has to be a personal decision taking account of the risk of extreme weather conditions, your confidence when driving in such conditions and the need to drive or not in such conditions. Winter tyres are now produced by most of the main manufacturers and some suppliers will provide these pre-fitted to a set of steel wheels too. If changing from alloy wheels to steel wheels you may have to change the design of wheel nuts used too. Ask the wheel supplier or car manufacturer for advice. Winter tyres must be fitted in sets of four. Fitting only one pair will significantly affect the balance and stability of the car. All Season Tyres As an alternative, drivers could consider buying so-called 'All Season Tyres' which also have a high silica content for low temperature flexibility and a tread pattern somewhere between a normal summer tyre and an out-and-out winter tyre. Like all compromises they're unlikely to be as good as the best specialist tyre but can be expected to work better on wintry roads than a summer tyre. Snow chains If you can't justify the expense of buying a second set of specialist tyres for winter you might consider carrying snow chains for use in an emergency. Snow chains are of limited use in the UK because you should only consider using them where the road surface is covered in a protective layer of compacted snow/ice. Snow chains can be quite awkward to fit or remove particularly when the wheel arches are packed with snow and your gloved hands are cold and wet. Fitting & using snow chains » Insurance implications - winter tyres If you fit winter or all-season tyres in place of your standard 'summer' tyres then there should be no need to inform your insurer even though the speed index might be lower than the standard tyre specified by the car maker. The lower speed index is still likely to exceed all national speed limits by a considerable margin with the exception of some German autobahns and is not checked as part of the passenger car MOT test. If you follow the standard European practice of keeping two sets of wheels, one fitted with winter tyres and one with summer tyres, then there should be no need to tell your insurer so long as the winter tyres are fitted to steel or alloy wheels of the correct specification. 'Correct specification' in this context means that the wheel size diameter, width and offset conforms to the vehicle manufacturer's specifications. Check the vehicle handbook for details of wheel/tyre size combinations suitable for your car model and refer to the car manufacturer or dealer for further advice. The AA has nevertheless heard reports of some insurers increasing premiums or remarkably even refusing cover if winter tyres are fitted. As a result we recommend talking to your insurer if you are considering fitting winter tyres. According to the Association of British Insurers (ABI) If anything winter tyres should reduce the accident risk and, by implication, drivers who fit them are likely to be more risk-conscious too. The major motor insurers have all confirmed that they would not class fitting winter tyres as a material modification and it would not impact on the premium. The one condition would be that they would expect such tyres to be fitted by reputable garage/dealer, in accordance with the motor manufacturer's specifications. Some said that they would not require the policyholder to tell the insurer these tyres had been fitted, but the ABI's advice is to play safe and tell your insurer anyway. |
Thanks to ABP Motorsport from:
Commercial user
Thanks given: 133
CIVIC 2001 - 2006
215/45x17 Yokohama W-Drive to fit OE 17” Wheels £135 including VAT 16” Steel wheel & Falken Winter tyre package (Set 4) £599 including VAT (fitted with 205/55x16 94V Falken HS439 Winter tyres) CIVIC 2006 - 2011 225/40x18 Yokohama W-Drive to fit OE 18” Wheels £155 including VAT 16” Steel wheel & Falken Winter tyre package (Set 4) £599 including VAT (fitted with 205/55x16 94V Falken HS439 Winter tyres) We have 10 sets of wheels & tyres available but the tyres are available separately so these prices are only whilst stocks last! 205/55x16 94V Falken HS439 Winter Tyre only £89 including VAT Fitting price for the wheel/tyre package in our workshop £20 including VAT Shipping price for the wheel/tyre package (UK Mainland) £40 including VAT
Commercial user
Thanks given: 133
![]() 16 Steel wheel & Falken Winter tyre package (Set 4) £599 including VAT (fitted with 205/55x16 94V Falken HS439 Winter tyres) We have 10 sets of wheels & tyres available but the tyres are available separately so these prices are only whilst stocks last! 205/55x16 94V Falken HS439 Winter Tyre only £89 including VAT Fitting price for the wheel/tyre package in our workshop £20 including VAT Shipping price for the wheel/tyre package (UK Mainland) £40 including VAT
Commercial user
Thanks given: 133
Reviews on these tyres listed above
Yokohama W-Drive : Yokohama W Drive | the Yokohama W Drive reviewed and rated | the online tyre guide Falken HS439 : Falken Eurowinter HS439 | the Falken Eurowinter HS439 reviewed and rated | the online tyre guide |
![]() Car: 2007 CTR Alabaster
Thanks given: 571
Hello ABP Im after four 205, 55 r16. dont need them fitted.
can you send me a pm with your BEST price. I may come and pick them up as i will be in the area soon |
Thanks given: 571
Hi abp, I will definately take a set, BUT the bank dont issue my new card till 5-7 days so can you hold a set back for me or arrange an instant transfer?
cheers |
![]() Car: 2008 CTR Nighthawk Black
Thanks given: 1
Hi Dave
I'd like a set of the wheels/tyre package. My car is booked in at ABP for MOT & service on Monday 24th so I'll pick them up and pay for them then. I don't need them fitting. Sean |
#10 (permalink) | |
Commercial user
Thanks given: 133
I will have them ready to put in the back for you. Just to confirm, i have your car booked in for: EBC Yellow pads front & rear 3rd service & check air filter MOT Fast road setup front & rear Supply only 4 x winter wheels & tyre package Hope this is all ok? |
#12 (permalink) |
![]() Car: Type S GT
Thanks given: 8
Your price
16” Steel wheel & Falken Winter tyre package (Set 4) £599 including VAT + £40 delivery Total £639 (fitted with 205/55x16 94V Falken HS439 Winter tyres) My Tyres price Steel wheels with winter tyres (LK 5 x 114.30 x 64.00) Falken-Ohtsu HS-439 M+S marking BSW 205/55 R16 91H Honda CIVIC 3DR 1.8 FN 1 1799ccm 103 kW 09.2006- £ 591.60 delivered. They appear to be the same tyre package. Can you beat this price? |
Thanks to GavF from:
#13 (permalink) | |
Commercial user
Thanks given: 133
Hope this helps? |
#15 (permalink) |
Commercial user
Thanks given: 133
One important thing that alot of people miss is the load and speed rating of the tyre. This has to be suitable and recommended specific to the car. 94V is the correct rating for the Civics and anything below this has a strong chance of causing a problem with your insurance.
Even though this is a winter tyre, you probably will still be using the car on the motorway etc exceeding the speeds that the cheaper lower rated tyres are suitable for. Just bear this in mind when buying the tyres thats all. |
#16 (permalink) | |
[ Laird Mac Nac Feegle ]
Thanks given: 297
#17 (permalink) | |
Commercial user
Thanks given: 133
#18 (permalink) |
Thanks given: 1
Winter tyres on
I fitted my Winter tyres today, and thought I'd post a couple of pics.
I think they look good |
#20 (permalink) |
Commercial user
Thanks given: 133
Update
The cold weather is here!
Winter tyres & wheels in stock @ ABP CIVIC 2001 - 2006 215/45x17 Yokohama W-Drive to fit OE 17 Wheels £135 including VAT 16 Steel wheel & Falken Winter tyre package (Set 4) £599 including VAT (fitted with 205/55x16 94V Falken HS439 Winter tyres) CIVIC 2006 - 2011 225/40x18 Yokohama W-Drive to fit OE 18 Wheels £155 including VAT 16 Steel wheel & Falken Winter tyre package (Set 4) £599 including VAT (fitted with 205/55x16 94V Falken HS439 Winter tyres) We have 10 sets of wheels & tyres available but the tyres are available separately so these prices are only whilst stocks last! 205/55x16 94V Falken HS439 Winter Tyre only £89 including VAT Fitting price for the wheel/tyre package in our workshop £20 including VAT Shipping price for the wheel/tyre package (UK Mainland) £40 including VAT
Similar Threads for: Winter Tyres & Wheels @ ABP
| Winter Steel wheels for winter tyres? | valmiki | Wheels, Tyres, Suspension and Brakes | 20 | 8th November 2011 16:15 |
| Steel wheels and Winter Tyres | jakey.goodman | Items wanted | 2 | 25th October 2011 10:04 |
| Winter tyres and wheels | PaulBaz | Type-R | 18 | 9th January 2010 14:35 |
| Winter winter tyres/wheels | jcw147 | Wheels, Tyres, Suspension and Brakes | 21 | 25th October 2009 15:48 |
| Winter 16inches wheels for winter tyres | flamspower | Wheels, Tyres, Suspension and Brakes | 11 | 12th November 2007 20:58 |
