ABP Current suspension/geometry prices - Page 2 - Civinfo
Old 7th March 2012, 09:33   #21 (permalink)
misterk's Avatar
Car: 2007 CTR GT NHB
Thanks given: 206
Due to various questions on this forum about the 30mm lowering springs i thought i would post some pictures here so people can see what the 30mm drop looks like, my car has had these springs on for one week now and it is fantastic.
i have also done a picture of the front end with a 500ml bottle to give you an idea of ride height.
free for dave at ABP
misterk is offline   Reply With Quote Quick reply to this message
Thanks to misterk from:
Old 16th March 2012, 21:04   #22 (permalink)
Merk1981's Avatar
Car: FRV EX 2.2
Thanks given: 33
Originally Posted by Merk1981 View Post
This is a read out from my 2nd to last alignment check. It has been corrected twice but each time the same issue has come back fairly shortly afterwards.
Is FRS likely to address this?
Thanks for your help.
Bump
Merk1981 is offline   Reply With Quote Quick reply to this message
Old 19th March 2012, 13:44   #23 (permalink)
Commercial user
ABP Motorsport's Avatar
Thanks given: 258
Bump
It may well help as we've not heard of similar problems on cars we've set-up. It also depends on the accuracy & calibration of the kit previously used to measure the car? Has it been set up at the same place both times?
Best option may well be to book the car in and see what we find. That way we can determine whats causing your wear issues and the pulling problem....
Chris
ABP Motorsport is offline   Reply With Quote Quick reply to this message
Old 19th March 2012, 13:46   #24 (permalink)
Commercial user
Thanks given: 258
Bump
Looking good and we love the black front plate
Cheers, Chris
Old 21st March 2012, 19:14   #25 (permalink)
MiChA's Avatar
Thanks given: 15
Send a message via ICQ to MiChA
hi chris,
I have the Eibach Pro kit -15mm.
Which price can you make for the eibach front camber bolts and eibach rear toe / camber shims including shipping to germany?
So I think I need 4 shims, it is better?!
Would it go her in germany in a good workshop?
I get your alignment with this?
MiChA is offline   Reply With Quote Quick reply to this message
Old 21st March 2012, 20:14   #26 (permalink)
misterk's Avatar
Thanks given: 206
Cheers, Chris
Black front and rear 100% legal
Just numbers no letters
Old 22nd March 2012, 10:06   #27 (permalink)
Commercial user
Thanks given: 258
Originally Posted by MiChA View Post
hi chris,
Front Eibach camber bolts are £25 pair.
Rear Eibach camber / toe shims are £8.50 each (maximum required 4)
We can ship to Germany no problem at all but to establish what rear shims you are going to need you will need to get your geometry checked first and let us have a copy of the results. With these we can send you the correct size and number of shims required along with our recommended settings.
Shipping costs will be around £20
Thanks, Chris
Old 23rd March 2012, 17:31   #28 (permalink)
Commercial user
Thanks given: 258
Here at ABP we get loads of questions about -15mm or -30mm lowering for the FN2 Type R.
We obviously have both options of Eibach springs available but what most folk want is to see the difference on the car.
So today we had 2 cars lined up outside. My car with our ABP exclusive Eibach -30mm springs fitted and a customers car with the Eibach -15mm prokit springs fitted. Take a look on our facebook page for the images and if you don't already like ABP on Facebook now's the time to do it!
Look here: Welcome to Facebook
Cheers, Chris
Old 28th March 2012, 18:09   #29 (permalink)
MiChA's Avatar
Thanks given: 15
Thanks, Chris
thanks Chris...
sounds great
And these fast Road Setup will improve the extrem understeer?
How do change tires abrasion after Fast Road Setup?
Old 4th April 2012, 20:58   #30 (permalink)
MiChA's Avatar
Thanks given: 15
thanks Chris...
sounds great
chris??
Old 6th April 2012, 16:37   #31 (permalink)
Unrealer's Avatar
Car: 2007 CTR
Thanks given: 9
Dears,
one question regarding the 15mm set I bought few weeks ago from you.
These bump stops were included in the package:
http://i39.tinypic.com/wbe4k1.jpg
Do I need to replace the original ones with these or the original ones need to be replaced only if they are worn off?
They have a different shape, etc so I am wondering if it's necessary to fit them there.
Unrealer is offline   Reply With Quote Quick reply to this message
Old 7th April 2012, 19:20   #32 (permalink)
a5hy's Avatar
Car: cdti 2.2 in silver.
Thanks given: 3
whats the difference?
hi mate whats the difference btween the eibach pro kit and the eibach kit apart from the drop?
a5hy is offline   Reply With Quote Quick reply to this message
Old 9th April 2012, 21:26   #33 (permalink)
Commercial user
Thanks given: 258
chris??
Sorry for the delay in replying....
Understeer will be dramatically reduced once the springs are fitted and the geometry is set to fast road spec.
If you acheive the 1 degree negative camber on the front you may see very slight additional wear on the inside of the front tyres but this is minimal.
Cheers, Chris
Old 9th April 2012, 21:29   #34 (permalink)
Commercial user
Thanks given: 258
Originally Posted by Unrealer View Post
Dears,
The -15mm prokit springs fit a number of Civic models and on the Type R they have a different bump stop than the standard models. You can either use the ones supplied or just shorten the original Honda ones (shorten by 50%).
Hope this helps,
Chris
Thanks to ABP Motorsport from:
Old 9th April 2012, 21:31   #35 (permalink)
Commercial user
Thanks given: 258
Our ABP exclusive -30mm kit only fits the petrol cars and is specific to the FN2 Type R. As you have a diesel if you use our -30mm springs the front will actually come down by -40mm due to the additional weight of the diesel engine.
Hope this helps,
Chris
Old 15th April 2012, 18:17   #36 (permalink)
Type r Richard's Avatar
Thanks given: 2
Hi how do I go about buy a set of these (30mm drop ones)? Could you pm me please
Type r Richard is offline   Reply With Quote Quick reply to this message
Old 16th April 2012, 21:59   #37 (permalink)
Commercial user
Thanks given: 258
You can call us on 01270 567177 and order over the phone for mail order delivery. We take all major credit and debit cards and will ship the springs out to you the same day for next day delivery @ only £10 inc vat.
Open from 8.30am t0 6.00pm
Chris
Old 3rd June 2012, 16:40   #38 (permalink)
The White Knight
Josh1987's Avatar
Thanks given: 15
Send a message via MSN to Josh1987
Hi Chris,
Just wondering is the 30mm kit you supply at ABP causes any rubbing or issues on Stock Honda Wheels 18"
Are do you have a current price for the -30mm kit with VAT and delivery included
Josh1987 is offline   Reply With Quote Quick reply to this message
Old 5th June 2012, 13:59   #39 (permalink)
Commercial user
Thanks given: 258
Originally Posted by Josh1987 View Post
Hi Chris,
No problems at all with the Eibach -30mm springs even when using 19" wheels!
Current price is £150 set inc vat with delivery an extra £10 (UK Mainland)
Call us to order on 01270 567177.
Cheers, Chris
Old 13th June 2012, 10:26   #40 (permalink)
M1tch's Avatar
Thanks given: 3
Hi there,
I take it the front camber bolts for the 2.2 come with a copy of your settings?
Regards,
Colin.
M1tch is offline   Reply With Quote Quick reply to this message
Insurance
Human Verification
Similar Threads for: ABP Current suspension/geometry prices
Let's talk about suspension geometry... ryko Any non Civic chat here please! 4 14th September 2012 07:06
Do you think CR-V prices will drop further on the current model? Dodger21 Honda CR-V 7 2nd July 2012 08:13
Current fuel prices and your next car devils_hands Hybrid 45 11th April 2010 09:12
Current Petrol Prices- penny increase every few days! egraphistudios Any non Civic chat here please! 28 16th March 2010 14:08
abp fast road car geometry setup lozhoon Type-R 16 26th February 2008 16:54
» Buyer's Resource
» Recent Discussions
How to clean / remove...
18th March 2012 20:25
Last post by Kwame-Flip
Today 11:17
776 Replies, 149,505 Views
What makes a Fn2(2011)...
19th March 2017 22:17
Today 11:15
38 Replies, 678 Views
15% Discount at EBC...
26th November 2008 20:09
by Pottsy
Last post by stevencavanagh
Today 11:14
469 Replies, 141,575 Views
55% OFF CAR PARTS - THIS...
Today 10:55
Last post by GSF CAR PARTS
Today 10:55
0 Replies, 13 Views
musegroove's FN2 -...
28th April 2016 09:51
Last post by Farqui
Today 10:50
1 Replies, 25,858 Views
Civic and Jazz I-shift,...
17th May 2016 20:51
Last post by namaqua
Today 10:32
63 Replies, 3,559 Views
Lowering springs or OEM
Today 09:32
Last post by flashy
Today 10:30
5 Replies, 55 Views
New CTR GT owner
Yesterday 12:20
Last post by Ricky Eyers
Today 10:30
8 Replies, 117 Views
jaxckhan ishift 1.8 type...
16th March 2017 00:35
Last post by anfield786
Today 10:27
84 Replies, 1,160 Views
"History of Trip A" on...
9th February 2017 10:02
Last post by Red Dwarf
Today 10:20
8 Replies, 441 Views
Copyright ©2000 - 2017, Jelsoft Enterprises Ltd.
vBulletin Security provided by vBSecurity v2.2.2 (Pro) - vBulletin Mods & Addons Copyright © 2017 DragonByte Technologies Ltd.
User Alert System provided by Advanced User Tagging (Pro) - vBulletin Mods & Addons Copyright © 2017 DragonByte Technologies Ltd.
