ABP Current suspension/geometry prices - Page 5 - Civinfo
Old 9th April 2013, 12:56   #81 (permalink)
A/C fixer-upper'er
Wee-nemo's Avatar
Car: '13 white Ibiza Cupra
Thanks given: 115
Originally Posted by ABP Motorsport View Post
Hi Nemo,
So it's possible a broken spring is causing the uneven ride height?
It's no problem to do just a front FRS, leaving the rear to do at a later date. It's only a couple of hours work to strip down the rear and fit the required shims. This is less if you find you only need to change the settings on one side.
I carry the ProKits for the diesels in stock @ £174.00 inc VAT. These come with shortened bump stops. The front camber bolts are £25.00 inc VAT and shims £8.50 each. As long as you're not classed as 'highlands' postage will be just £10.00 for a 24hour service.
If you need, give me a call and i'll do my very best to help out.
Rich
A broken spring was my thought, though I couldn't get it diagnosed before going back to work. Thanks for the feedback, I probably will save a lot of faffing about and just stick with a front FRS initially, during which they can let me know the required number of rear shims to do later on.
Wasn't sure just how much work was involved to get to the rear shims and that it would be a false economy not to do them while the rear suspension was in bits. I can live with a couple of hours labour though.
I'll give you a ring when I get the car in the air and if there's a broken spring to contend with. Should be next Friday hopefully.
Many thanks,
Nemo
Wee-nemo is offline   Reply With Quote Quick reply to this message
Old 9th April 2013, 13:48   #82 (permalink)
Commercial user
ABP Motorsport's Avatar
Thanks given: 258
Many thanks,
Nemo
No problem. That sounds like the best plan of action, as it is isn't a huge amount of labour to sort the rear. Many people go for just the front FRS to begin with.
Let me know if you want to go for the ProKit and i'll get one shipped out to you
Rich
ABP Motorsport is offline   Reply With Quote Quick reply to this message
Old 9th April 2013, 16:48   #83 (permalink)
Thanks given: 9
Hi Josh,
I'm guessing you mean our Eibach kit that lowers the Type R -30mm, and all other petrols -40mm?
I keep these in stock @ £150.00 inc VAT and they do come with the shortened bump stops. You can cut your originals down by 50% if you prefer, but either can be done.
I also keep the ProKit in, which lowers the Type R's by 15mm, and all other petrols by around 25/30mm. This kit is a little more @ £164.00 inc VAT.
If you want to order either of these, give me a call on 01270 567177 and i can get them out today and with you for tomorrow
Cheers,
Rich
Thanks Rich. yes the ones that lower 40mm my cars an es. Will hopefully give you a call tomorrow to get some ordered
Josh
jd26 is offline   Reply With Quote Quick reply to this message
Thanks to jd26 from:
Old 31st July 2013, 03:34   #84 (permalink)
Car: 2007 CTR FN2, Black
Thanks given: 13
is there anyway to lower the car 20mm front and 15mm back or 15mm front and 10mm back?
Or if i want to do that, do i have to get coilovers?
Waiting on a bonus payment i will get 10 aug.
So looking to buy break pads,disc and springs if the bonus is enough
Spikeis is offline   Reply With Quote Quick reply to this message
Old 31st July 2013, 13:44   #85 (permalink)
Commercial user
Thanks given: 258
The Eibach Pro kit lowers the FN2 by 15mm all round and the non Type R's between 20mm and 35mm (due to the difference in standard ride height).
If you want something in between that, really it's going to be coilovers to give you more adjustability.
Let me know how you get on, and if there is anything i can help with in the future.
Rich
Old 31st July 2013, 21:48   #86 (permalink)
Thanks given: 13
Rich
Oki, like i though.
Thanks for the fast respond, i will have to check what im going to do and how much money im getting
Old 11th October 2013, 12:46   #87 (permalink)
Obsessive Modder
a.roden's Avatar
Car: 2008 1.8 Type S GT
Thanks given: 380
Will these lower the type s the same amount as the type r?
a.roden is offline   Reply With Quote Quick reply to this message
Old 11th October 2013, 12:52   #88 (permalink)
Commercial user
Thanks given: 258
The 15mm Pro kit will lower non Type R's by around 25-30mm and our Eibach 30mm kit will lower the non Type R's by 40-45mm.
Hope that makes sense. As far as i know there is no difference in ride height between a Type S, and for example an EX etc.
Rich
Thanks to ABP Motorsport from:
Old 11th October 2013, 18:50   #89 (permalink)
Obsessive Modder
a.roden's Avatar
Thanks given: 380
Rich
Ok, I will probably ring up to book tomorrow, undecided on which springs yet though :-/ need some help persuading me on to the lower set. Is there any ride difference or is it just the ride height...
Old 13th October 2013, 22:19   #90 (permalink)
Obsessive Modder
a.roden's Avatar
Thanks given: 380
ringing tomorrow morning to book, decided on full FRS with the Eibach pro's.
Thanks to a.roden from:
Old 16th October 2013, 16:12   #91 (permalink)
Obsessive Modder
a.roden's Avatar
Thanks given: 380
Springs are 110% better than the stock springs. See you all next week for the spacers...
As the hubs will be coming off for the spacers, could I ask how much extra it would be to install my Accord type R callipers, discs, and braided lines? should be a straight swap and bleed them �� ...
Old 18th October 2013, 11:50   #92 (permalink)
Commercial user
Thanks given: 258
Glad you're happy with the springs! They are a great upgrade, and your car looked great with the slightly lower ride.
As long as everything bolts straight up, and your're supplying the relevant bits (calipers, carriers, discs, pads, lines and fluid) we'd be looking at around 6 hours in total, including fitting the spacers and longer studs. That's £536.00 inc VAT for everything fitted including the cost of the spacers.
We've never fitted accord brakes to the 8th gen Civic before, so it's a bit of a new one on us as regards to whether the carriers go straight on etc but if you're sure it's all good, that would be the price.
Hope that helps, let me know if you'd like me to change your booking to include the above work for Wednesday.
Cheers,
Rich
Old 18th October 2013, 12:19   #93 (permalink)
Obsessive Modder
a.roden's Avatar
Thanks given: 380
Think I will leave it with just the spacers, Ive been quoted a cheap price from my work. See you all next week
Old 18th October 2013, 13:11   #94 (permalink)
Commercial user
Thanks given: 258
No problem! The majority of the labour is for the brake lines, as they are a 6 piece kit which are a little more involved to fit.
Look forward to seeing you and the car next week
Rich
Old 23rd October 2013, 10:00   #95 (permalink)
Obsessive Modder
a.roden's Avatar
Thanks given: 380
Rich
Lots of traffic this morning guys, hopefully i wont be late
Old 24th October 2013, 10:06   #96 (permalink)
Commercial user
Thanks given: 258
You made it ok time-wise, considering the state of the M6 you did well!
What do you think of the look of the car now? Get some pics up!!!
Rich
Old 24th October 2013, 12:37   #97 (permalink)
Obsessive Modder
a.roden's Avatar
Thanks given: 380
Rich
Im waiting for the 19"s to go on will do a before and after then aha
Old 26th October 2013, 15:09   #98 (permalink)
Obsessive Modder
a.roden's Avatar
Thanks given: 380
Old 26th October 2013, 15:25   #99 (permalink)
reshamg's Avatar
Car: 2009 2.2 SE, Galaxy Grey
Thanks given: 124
Eco display Eco display
Wow. How much for these alloys
Sent from my Nexus 4 using Tapatalk
reshamg is offline   Reply With Quote Quick reply to this message
Old 27th October 2013, 00:33   #100 (permalink)
Obsessive Modder
a.roden's Avatar
Thanks given: 380
I got two cheap on ebay and bought two from the dealership, £1200 new for a set :-/
Insurance
Human Verification
Similar Threads for: ABP Current suspension/geometry prices
Let's talk about suspension geometry... ryko Any non Civic chat here please! 4 14th September 2012 08:06
Do you think CR-V prices will drop further on the current model? Dodger21 Honda CR-V 7 2nd July 2012 09:13
Current fuel prices and your next car devils_hands Hybrid 45 11th April 2010 10:12
Current Petrol Prices- penny increase every few days! egraphistudios Any non Civic chat here please! 28 16th March 2010 15:08
abp fast road car geometry setup lozhoon Type-R 16 26th February 2008 17:54
» Buyer's Resource
» Recent Discussions
2011 Civic Type R GT...
15th January 2017 10:38
Last post by 2013fn2
Today 00:57
5 Replies, 310 Views
Oil filter removal tool
Today 00:14
by MattJ
Last post by MattJ
Today 00:14
0 Replies, 13 Views
Engine more noisy after...
Yesterday 18:51
Last post by hondacivicnut
Yesterday 23:53
2 Replies, 73 Views
Car wandering, steering...
Yesterday 18:04
by forneus
Last post by scaramanga
Yesterday 23:46
3 Replies, 81 Views
I-cdti 2.2 no power...
Yesterday 01:34
Last post by Buffalobilluk
Yesterday 23:45
7 Replies, 161 Views
2.2 cdti ex
17th January 2017 22:30
by vti444
Last post by vti444
Yesterday 23:29
13 Replies, 200 Views
Unlocking problems
18th January 2017 14:19
Last post by stevenjp90
Yesterday 22:54
14 Replies, 223 Views
Random chat II
14th November 2011 08:25
by skam
Last post by liakos
Yesterday 22:54
22 Replies, 813,727 Views
Championship White Type...
11th August 2016 20:06
Last post by Chrisjacko
Yesterday 22:42
2 Replies, 813 Views
Fn2
16th January 2017 00:15
by cnking
Last post by Fergiem123
Yesterday 22:25
28 Replies, 647 Views
Copyright ©2000 - 2017, Jelsoft Enterprises Ltd.
vBulletin Security provided by vBSecurity v2.2.2 (Pro) - vBulletin Mods & Addons Copyright © 2017 DragonByte Technologies Ltd.
User Alert System provided by Advanced User Tagging (Pro) - vBulletin Mods & Addons Copyright © 2017 DragonByte Technologies Ltd.
