ABP Current suspension/geometry prices - Page 6 - Civinfo
Old 27th October 2013, 23:06   #101 (permalink)
Guest
Thanks given: 16
If I got this done would I get a print out of the geometry of the car before and after having it done?
Could it be done in a day?
54687 is offline   Reply With Quote Quick reply to this message
Old 28th October 2013, 10:57   #102 (permalink)
Commercial user
ABP Motorsport's Avatar
Thanks given: 258
Originally Posted by a.roden View Post
Those wheels REALLY suit the car and the colour, and they sit perfect in the arches. Great choice!
Rich
If your geo is ok before you fit the spacers, you wouldn't need to check it again after putting them on. You're adding width to the track of the car so it will effect it slightly, but in equal measures each side (as the spacers are equal sizes each side).
If you want the system 6 spacers, like the car above has (these come with the longer studs which are more involved to fit) they start at £99.00 inc VAT per axle set, and are available in 10mm, 15mm, and 20mm. They take a couple of hours to fit, at around £110 labour.
The other option, depending on what wheels you're running, is the system 4 spacer which bolts on just like a wheel would. These come with studs built in to the spacer but can only be used with original wheels (need to be checked first). These are the most commonly used at £110.00 per axle set.
Hope this all makes sense.
Rich
ABP Motorsport is offline   Reply With Quote Quick reply to this message
Old 27th January 2014, 22:23   #103 (permalink)
Shake n Bake
foggy4ever's Avatar
Car: 2007 2.2 Diesel
Thanks given: 315
EIBACH 2.2 Diesel (-25mm) springs fitted including front and rear ABP Fast Road Setup is £508.00 (worse case)
Looking to have this fitted 22/25 April. Whats the latest I would need to book and how long is the job.
Scott
foggy4ever is offline   Reply With Quote Quick reply to this message
Old 28th January 2014, 10:10   #104 (permalink)
Commercial user
Thanks given: 258
Scott
Hi Scott.
Fitting the springs and setting geometry wouldn't take any longer than 4 hours really.
I can take a booking anytime, we could put it in our diary now if you like? But for April 22nd/25th which I have as a Tuesday and Friday you could let me know the week before.
Rich
Old 28th January 2014, 10:25   #105 (permalink)
Shake n Bake
foggy4ever's Avatar
Thanks given: 315
Originally Posted by ABP Motorsport View Post
Hi Scott.
Rich
Cheers Rich,
You can pencil me in for the Wednesday(23rd) morning and I'll confirm beginning of April.
Scott
Thanks to foggy4ever from:
Old 28th January 2014, 20:49   #106 (permalink)
Hi Rich, I have the Eibach 15mm kit for my fn2.
(Not yet fitted) Now I want the FRS front and rear camber bolts and shims.
How do I know the alignment specifications that the car should have?
Is it possible that you ship to Belgium?
Oakheart is offline   Reply With Quote Quick reply to this message
Old 29th January 2014, 10:27   #107 (permalink)
Commercial user
Thanks given: 258
Hi there. We can ship the parts to you, no problem!
I would have to see a geometry printout of your car as it sits now, for me to be able to see if it would benefit from you fitting any rear shims. If you have a local garage that can check the alignment for you, and provide you with a print out that you could then send to me, that would be perfect.
I hope that makes sense.
Rich
Old 29th January 2014, 20:12   #108 (permalink)
Rich
Hi,i ask my local garage for a print out of the alignment.
Thanks to Oakheart from:
Old 1st February 2014, 09:10   #109 (permalink)
Hi Rich,I have the print out of the alignment.
Where do I send it to?
Old 2nd February 2014, 22:34   #110 (permalink)
Boris_Yeltsin's Avatar
Thanks given: 9
How low is A.Roden's car? I have a CTS on 19's lowered on H&R 30mm but it's nowhere near as low as that. I'm not sure what's wrong.
I was thinking about getting CTR 30MM which would lower it 45mm but if the car pictured above is only 30mm then there's a problem on my end.
Boris_Yeltsin is offline   Reply With Quote Quick reply to this message
Old 3rd February 2014, 10:19   #111 (permalink)
Obsessive Modder
a.roden's Avatar
Car: 2008 1.8 Type S GT
Thanks given: 380
I have a sub in the back if that makes any difference haha. About 20kg
a.roden is offline   Reply With Quote Quick reply to this message
Old 3rd February 2014, 10:24   #112 (permalink)
Commercial user
Thanks given: 258
You can PM me, or send it via email to rich@abpmotorsport.co.uk
We fitted the Prokit to the gold Civic above, which lowers it around 25/30mm. We've fitted a few of the H&R kits and in honesty, they do usually sit a little higher than the quoted 'drop'.
Hope that helps.
Rich
Old 3rd February 2014, 20:42   #113 (permalink)
Thanks given: 9
Yeah I had the H&R 30mm fitted and they're so high I'm convinced something is wrong. Does this look familiar?
I'm looking to order the pro springs but a bit sceptic after this so-called '30mm' drop. Do you sell CTR 25MM?
Old 4th February 2014, 10:29   #114 (permalink)
Commercial user
Thanks given: 258
It certainly doesn't look a 30mm drop. It looks standard height!
We sell the 15/20mm Eibach Prokit and then our 30mm Eibach kit which are all suited to the FN2. You can fit these to the petrol non Type R's but add another 10mm (ish) to the drop.
Rich
Old 4th February 2014, 12:11   #115 (permalink)
Thanks given: 9
Do you have the pro kit in stock mate? And how much to ship to Northern Ireland (plus how long?).
Old 4th February 2014, 12:16   #116 (permalink)
Commercial user
Thanks given: 258
Prokit is in stock @ £164.00.
Can you PM me your address and I'll get you a cost on shipping?
Cheers,
Rich
Old 4th February 2014, 12:22   #117 (permalink)
PradaFK3's Avatar
Car: 2007 2.2 FK3, Galaxy grey
Thanks given: 133
Hi, i will be buying the 25mm 2.2 Eibach spring kit and fitting it myself but i wondered what you would charge to check it all out afterwards with a fast road front and rear setup? Hoping that saving money on the fitting will enable me to get this all in before Japfest
PradaFK3 is offline   Reply With Quote Quick reply to this message
Old 4th February 2014, 13:45   #118 (permalink)
Commercial user
Thanks given: 258
We'd charge between £190 and £224 inc VAT to fit bolts and shims and set the geo to Fast Road Spec. The difference in cost is determined by how many shims we use in the rear. It is usually only one or two.
Hope this helps.
Let me know when you're ready to get the springs, I'll send them out and we can get you booked in for the FRS.
Cheers,
Rich
Old 4th February 2014, 14:01   #119 (permalink)
PradaFK3's Avatar
Thanks given: 133
So really for the little extra money it is I might as well get the whole done at yours fitting, setup and spring purchase I'll let you know as soon as i have the funding (heavy weekend lol)
Hope this helps.
Cheers,
Rich
Old 5th February 2014, 13:03   #120 (permalink)
Commercial user
Thanks given: 258
It works out at around £100.00 difference, so it depends on how much it costs for to get the springs fitted. It's not as much work for us, when we fit the springs and adjusters together so we are able to lessen the price than if we did both jobs separately.
Hope that makes sense, let me know when you're ready.
Rich.
Thanks to ABP Motorsport from:
Insurance
Human Verification
Similar Threads for: ABP Current suspension/geometry prices
Let's talk about suspension geometry... ryko Any non Civic chat here please! 4 14th September 2012 07:06
Do you think CR-V prices will drop further on the current model? Dodger21 Honda CR-V 7 2nd July 2012 08:13
Current fuel prices and your next car devils_hands Hybrid 45 11th April 2010 09:12
Current Petrol Prices- penny increase every few days! egraphistudios Any non Civic chat here please! 28 16th March 2010 14:08
abp fast road car geometry setup lozhoon Type-R 16 26th February 2008 16:54
» Buyer's Resource
» Recent Discussions
How to clean / remove...
18th March 2012 20:25
Last post by Kwame-Flip
Today 11:17
776 Replies, 149,505 Views
What makes a Fn2(2011)...
19th March 2017 22:17
Today 11:15
38 Replies, 678 Views
15% Discount at EBC...
26th November 2008 20:09
by Pottsy
Last post by stevencavanagh
Today 11:14
469 Replies, 141,575 Views
55% OFF CAR PARTS - THIS...
Today 10:55
Last post by GSF CAR PARTS
Today 10:55
0 Replies, 13 Views
musegroove's FN2 -...
28th April 2016 09:51
Last post by Farqui
Today 10:50
1 Replies, 25,858 Views
Civic and Jazz I-shift,...
17th May 2016 20:51
Last post by namaqua
Today 10:32
63 Replies, 3,559 Views
Lowering springs or OEM
Today 09:32
Last post by flashy
Today 10:30
5 Replies, 55 Views
New CTR GT owner
Yesterday 12:20
Last post by Ricky Eyers
Today 10:30
8 Replies, 117 Views
jaxckhan ishift 1.8 type...
16th March 2017 00:35
Last post by anfield786
Today 10:27
84 Replies, 1,160 Views
"History of Trip A" on...
9th February 2017 10:02
Last post by Red Dwarf
Today 10:20
8 Replies, 441 Views
Copyright ©2000 - 2017, Jelsoft Enterprises Ltd.
vBulletin Security provided by vBSecurity v2.2.2 (Pro) - vBulletin Mods & Addons Copyright © 2017 DragonByte Technologies Ltd.
User Alert System provided by Advanced User Tagging (Pro) - vBulletin Mods & Addons Copyright © 2017 DragonByte Technologies Ltd.
