Rear Whiteline Anti roll Bar - Page 5 - Civinfo
Go Back   Civinfo > vendors > ABP Motorsport
Like Tree1Likes
Old 30th July 2013, 23:16   #81 (permalink)
leigh's Avatar
Car: 2009 CW CTR
Thanks given: 687
Originally Posted by Dave84 View Post
I herd you can file down the bar a little if you are have clearance problems.
No need file anything, all you need do is space the u brackets further out (closer to the wheels). The instructions were written based on a FN2 with oem exhaust as stated I had issues with the Milltek as the back box is bigger than oem so fitting the brackets as per instructions you could instantly see they were catching the exhaust box with car in the air so I moved the brackets so they sat either side of the box and have no issues
leigh is offline   Reply With Quote Quick reply to this message
Old 30th July 2013, 23:28   #82 (permalink)
stevencavanagh's Avatar
Car: 58 2.2, Black ; 09 CTR, Red
Thanks given: 11
I never noticed it being too hard at all, just the massively improved handling. It did catch on the Martelius initially, but ABP kindly sorted that and it is now completely silent - an awesome mod, well worth the money.
Sent from my BlackBerry 9900 using Tapatalk
stevencavanagh is offline   Reply With Quote Quick reply to this message
Old 20th August 2013, 00:37   #83 (permalink)
Dave84's Avatar
Car: 2009 CTR GT, Albaster Silver
Thanks given: 80
Just a little review after i got mine fitted front and rear arb + uprated drop links. Didn't think the car would handle any better as it was amazing on coilovers, frs and an mfactory diff.. Feels even more keaner to turn, miles sharper and feels a little lighter at the front end. Far less body roll especially from the front end of the chassis. The rear feels more active, can get a lot more lift off oversteer which is nice adding a little more driver involvement. Will provide more feedback towards the end of year of how it feels at oulton park compared to last year.
The drop links are twice as thick as the o.e.m ones. There was a slight thud which appeared to come from the o.e.m drop links or dampers. Noticed this on a road near me. Same road, same speed no thud at all absolutely brilliant. Highly recommend the drop links as the o.e.m ones are not very good.
One of the best mods you can buy, great fun around roundabouts and noticeable enough to justify buying for daily use.
Dave84 is offline   Reply With Quote Quick reply to this message
Old 20th August 2013, 01:08   #84 (permalink)
aka Paul
Revs FN2's Avatar
Thanks given: 1,439
That's very similar to my experience very pleased with what it's done for the car.
Revs FN2 is offline   Reply With Quote Quick reply to this message
Old 20th August 2013, 01:18   #85 (permalink)
Thanks given: 11
Must admit I was also extremely pleased with the difference the RARB made. Also had the uprated drop links fitted.
Didn't go for the front ARB as worried it might detract from the rear and reintroduce some understeer.
Old 20th August 2013, 01:20   #86 (permalink)
Thanks given: 11
Double post - deleted.
Old 20th August 2013, 05:26   #87 (permalink)
mylesjohn's Avatar
Car: 2002 Civic Type r EP3
Thanks given: 76
Is the uprated droplinks by Whiteline as well?
Sent from my GT-N7000 using Tapatalk 4
mylesjohn is offline   Reply With Quote Quick reply to this message
Old 20th August 2013, 08:29   #88 (permalink)
aka Paul
Revs FN2's Avatar
Thanks given: 1,439
Whiteline KLC106 Sway bar - link assembly
Old 20th August 2013, 10:37   #89 (permalink)
stoney's Avatar
Car: 2007 FN2 GT
Thanks given: 227
I don't see the point in the links myself. Its not you'll notice a change over a std item. If your going very low and you need a shorter link just get a shorter one by asking at ECP to compare a few different ones.
The 8th gen ones are just longer ones as used on 6L Ibiza's and 8P A3s
stoney is offline   Reply With Quote Quick reply to this message
Old 20th August 2013, 13:24   #90 (permalink)
Thanks given: 11
Agreed. The only reason I went with them was that I had play in one of the front ones and it was banging away at times.
Sent from my iPad using Tapatalk - now Free
Old 22nd August 2013, 23:08   #91 (permalink)
Dave84's Avatar
Thanks given: 80
With the links the front end seems to glide over bumps so much nicer no clunks at all. The o.e.m links are very weak and only last for a few years before they need replacing.
Old 16th January 2014, 12:30   #92 (permalink)
trancem's Avatar
Car: '59 CW FN2 GT
Thanks given: 2
Snapped one of these up while it was on offer with you guys over Xmas.
Will be getting it fitted in the next month - what setting should I have it on for fast road use? Car won't be on track
Will be lowered with Eibach 15mm Springs, Bolts/Shims and FRSU.
trancem is offline   Reply With Quote Quick reply to this message
Old 16th January 2014, 13:06   #93 (permalink)
leigh's Avatar
Car: 2009 CW CTR
Thanks given: 687
I have mine on the stiffest setting and works great with my other mods. Roundabouts etc become more fun
Sent from my SM-N9005 using Tapatalk
Old 16th January 2014, 16:11   #94 (permalink)
aka Paul
Revs FN2's Avatar
Thanks given: 1,439
Second stiffest hole setting for me. Seems a good balance.
Old 16th January 2014, 16:51   #95 (permalink)
HUB
HUB's Avatar
Thanks given: 12
Hi. I just bought rear upper strut bar and I got rarb on already. Can I expect any improvement with both on?
HUB is offline   Reply With Quote Quick reply to this message
Old 16th January 2014, 16:52   #96 (permalink)
Tarmacadam Terror
RevMonkey's Avatar
Car: 2010 Alabaster Silver CTR GT
Thanks given: 1,411
Absolutely Hub, using the tower brace allows the suspension to work as a single unit. You will be surprised at the difference
"Go Green"
RevMonkey is offline   Reply With Quote Quick reply to this message
Old 16th January 2014, 16:53   #97 (permalink)
Tarmacadam Terror
RevMonkey's Avatar
Thanks given: 1,411
Revs will back me up on this I think
"Go Green"
Old 16th January 2014, 17:48   #98 (permalink)
HUB
HUB's Avatar
Thanks given: 12
Thanks. I'll back you up soon.
Old 17th January 2014, 10:55   #99 (permalink)
trancem's Avatar
Car: '59 CW FN2 GT
Thanks given: 2
Might also try it on this setting. The car isn't used for track so the stiffest setting may be too much.
Old 17th January 2014, 11:08   #100 (permalink)
seejay's Avatar
Thanks given: 20
i dropped mine off by one setting and i already had a rear boot bar and j's racing bar's, meister r's coilovers, frs, spoon collar kits fitted. i put it straight back to the hard setting as soon as i could and haven't looked back since.
seejay is offline   Reply With Quote Quick reply to this message
Insurance
Human Verification
LinkBack to this Thread: http://www.civinfo.com/forum/abp-motorsport/85752-rear-whiteline-anti-roll-bar.html
Civic Type-R Owners Club & Forum • View topic - Best and cheaperest mod for a few more speedpowerz This thread Refback 16th November 2012 15:10
Similar Threads for: Rear Whiteline Anti roll Bar
Anti Roll Bushes lucas Cox Motor Parts 0 16th July 2012 13:11
Suspension Anti Roll Bar bushes...... M1tch Wheels, Tyres, Suspension and Brakes 7 20th June 2012 21:49
Civic anti roll bar bushes ...help equanimity Introduce yourself 13 12th June 2011 18:24
anti roll bar \/ polsonm87 Type-R 12 19th May 2009 14:25
Suspension Anti roll bars alexps Wheels, Tyres, Suspension and Brakes 17 19th May 2008 12:14
» Buyer's Resource
» Recent Discussions
Faults
25th July 2008 07:10
by botsp
Last post by yansta
Today 07:53
18 Replies, 981,380 Views
Engine Control Unit...
Yesterday 22:23
by r.kelly
Last post by Farqui
Today 07:34
4 Replies, 62 Views
Lets Wrap and Mod
16th May 2017 19:08
Last post by marcinwednesbury
Today 06:43
123 Replies, 2,430 Views
Coolice Vinyl Grafix,...
17th June 2015 17:54
by coolice
Last post by R82C
Today 04:17
944 Replies, 43,186 Views
Alloys, Martelius....
23rd November 2016 02:35
by DaveN89
Last post by Gcook8
Today 03:16
131 Replies, 5,107 Views
09 Civic Power Mirror
23rd June 2017 00:39
Last post by Umer Zubair
Today 01:58
4 Replies, 103 Views
57i Air Intake For Sale
11th June 2017 12:22
Last post by micek_kc
Today 01:27
18 Replies, 547 Views
FN2 power mods
21st June 2017 22:42
by phara
Last post by phara
Today 01:24
10 Replies, 231 Views
Derv Clutch Pedal...
1st February 2017 03:31
Last post by hondacivicnut
Today 00:17
208 Replies, 36,034 Views
Honda Civic Type R FN2...
20th June 2017 21:21
Last post by Ashleechristo92
Yesterday 23:56
1 Replies, 130 Views
Copyright ©2000 - 2017, Jelsoft Enterprises Ltd.
vBulletin Security provided by vBSecurity v2.2.2 (Pro) - vBulletin Mods & Addons Copyright © 2017 DragonByte Technologies Ltd.
User Alert System provided by Advanced User Tagging (Pro) - vBulletin Mods & Addons Copyright © 2017 DragonByte Technologies Ltd.
