Rear Whiteline Anti roll Bar - Page 6 - Civinfo
Go Back   Civinfo > vendors > ABP Motorsport
Like Tree1Likes
Old 17th January 2014, 11:20   #101 (permalink)
Commercial user
ABP Motorsport's Avatar
Thanks given: 258
It's all personal preference at the end of the day, but to see the best improvement I would recommend the stiffest setting .
You can always back it off at a later date.
Rich
ABP Motorsport is offline   Reply With Quote Quick reply to this message
Thanks to ABP Motorsport from:
Old 17th January 2014, 12:07   #102 (permalink)
stevencavanagh's Avatar
Car: 58 2.2, Black ; 09 CTR, Red
Thanks given: 11
Hardest setting on the rear one for me.
Sent from my iPad using Tapatalk
stevencavanagh is offline   Reply With Quote Quick reply to this message
Old 17th January 2014, 12:10   #103 (permalink)
leigh's Avatar
Car: 2009 CW CTR
Thanks given: 687
Originally Posted by seejay View Post
i dropped mine off by one setting and i already had a rear boot bar and j's racing bar's, meister r's coilovers, frs, spoon collar kits fitted. i put it straight back to the hard setting as soon as i could and haven't looked back since.
My suspension mods are the same as yours other than I run buddyclub rsd coilovers and im full polybushed and mine rides the roads nicer than when it was oem and can take the corners and round abouts a hell of alot quicker than I could before as I use the same stretch of road/corners to compare the changes I make to see if it's improved or not.
Sent from my SM-N9005 using Tapatalk
leigh is offline   Reply With Quote Quick reply to this message
Old 17th January 2014, 12:10   #104 (permalink)
Commercial user
Thanks given: 258
Hardest setting is the best setting by far on the FN2 rear. Why reduce the benefit & improvement available by using any of the other settings? Would be like fitting the very best tyres and not running the correct pressures!
Chris
Old 17th January 2014, 18:44   #105 (permalink)
Thanks given: 11
Originally Posted by HUB View Post
Hi. I just bought rear upper strut bar and I got rarb on already. Can I expect any improvement with both on?
Which tower brace are you using, is it the Ultra Racing one?
Old 17th January 2014, 19:03   #106 (permalink)
HUB
HUB's Avatar
Thanks given: 12
It just arrived. I make whole back one piece.
HUB is offline   Reply With Quote Quick reply to this message
Old 17th January 2014, 19:07   #107 (permalink)
HUB
HUB's Avatar
Thanks given: 12
it makes whole back as one piece.
Old 17th January 2014, 21:19   #108 (permalink)
Thanks given: 3
Chris
I disagree!
For me the stiffest setting was far too hard, it felt like the car was reluctant to change direction.
TaKeN is offline   Reply With Quote Quick reply to this message
Old 17th January 2014, 23:15   #109 (permalink)
seejay's Avatar
Thanks given: 20
is that with the vsa on?
seejay is offline   Reply With Quote Quick reply to this message
Old 17th January 2014, 23:24   #110 (permalink)
Thanks given: 3
Yep, I can't see that making a difference though.
Old 18th January 2014, 00:08   #111 (permalink)
seejay's Avatar
Thanks given: 20
turn it off and see.
Old 18th January 2014, 06:18   #112 (permalink)
HUB
HUB's Avatar
Thanks given: 12
Originally Posted by TaKeN View Post
I disagree!
Check aliment of wheels after fitting. Can be different.
Old 18th January 2014, 08:31   #113 (permalink)
Thanks given: 3
Please explain to me how a fixed rear beam can 'lose alignment' after fitting a metal rod that limits body roll.
Old 18th January 2014, 09:06   #114 (permalink)
HUB
HUB's Avatar
Thanks given: 12
Did you check your alignment before? If something is out to much stiffness of arb can demonstrate the problem.
Fixed rear beam can lose alignment. I think condition of shock absorbent can do it. You can check it on adjustable one.
Old 18th January 2014, 12:03   #115 (permalink)
stoney's Avatar
Car: 2007 FN2 GT
Thanks given: 227
Unless it's took a serious thwacck the rear beam geometry won't move
stoney is offline   Reply With Quote Quick reply to this message
Old 18th January 2014, 12:29   #116 (permalink)
HUB
HUB's Avatar
Thanks given: 12
On Hunter machine even different pressure on tyres can give you variable readings. My readings have changed after fitting bilstein and rarb 0.5 on the back(camber).
Old 18th January 2014, 12:39   #117 (permalink)
stoney's Avatar
Car: 2007 FN2 GT
Thanks given: 227
Go and take a look at the rear suspension and come back,
Old 18th January 2014, 13:40   #118 (permalink)
HUB
HUB's Avatar
Thanks given: 12
Ok is not easy adjustable but If you have different settings on your suspension you will be having the same readings from the same machine?
Old 24th May 2016, 23:33   #119 (permalink)
chrisg18's Avatar
Car: 2008 fn2 red
Thanks given: 7
warb settings
had a white line arb fitted by ABP last week. the car feels much faster round roundabouts now,. what worries me slightly is on the hardest setting will this induse too much oversteer ? which can be lethal on wet country bends. been reading loads of reviews covering all makes of cars and oversteer is a problem on the hardest setting it seems.has any one tested their car on all four settings?slight understeer is not a bad thing lol.
chrisg18 is offline   Reply With Quote Quick reply to this message
Old 25th May 2016, 09:07   #120 (permalink)
Commercial user
Thanks given: 258
I ran different settings on my FN2 and found the hardest setting to be my favourite by far. On any dry road the improvement was massive and I personally would prefer an oversteer situation to any understeer issue as simple adjustment of steering can sort it. The only time when a softer setting would be 'better' is if you ran the car on a very wet track day but at this point tyre pressures also play a big part.
Standard tyre pressures + road use = hardest setting is best in my opinion.
stevencavanagh likes this.
Insurance
Human Verification
LinkBack to this Thread: http://www.civinfo.com/forum/abp-motorsport/85752-rear-whiteline-anti-roll-bar.html
Civic Type-R Owners Club & Forum • View topic - Best and cheaperest mod for a few more speedpowerz This thread Refback 16th November 2012 15:10
Similar Threads for: Rear Whiteline Anti roll Bar
Anti Roll Bushes lucas Cox Motor Parts 0 16th July 2012 13:11
Suspension Anti Roll Bar bushes...... M1tch Wheels, Tyres, Suspension and Brakes 7 20th June 2012 21:49
Civic anti roll bar bushes ...help equanimity Introduce yourself 13 12th June 2011 18:24
anti roll bar \/ polsonm87 Type-R 12 19th May 2009 14:25
Suspension Anti roll bars alexps Wheels, Tyres, Suspension and Brakes 17 19th May 2008 12:14
» Buyer's Resource
» Recent Discussions
BMD Wax Sale ** Luxury...
15th May 2017 12:22
Last post by piasek
Today 13:54
68 Replies, 1,764 Views
other cars at the same...
2nd November 2008 23:42
Last post by jimp
Today 13:47
9 Replies, 462,820 Views
Will 225/45/18 fit my...
10th March 2011 22:05
Last post by 786evo8
Today 13:44
11 Replies, 2,832 Views
Excelon Performance UHP...
27th May 2017 21:08
Last post by atom3624
Today 13:33
4 Replies, 142 Views
FN2 suddenly feels like...
25th May 2017 17:38
Today 13:31
24 Replies, 703 Views
Brakes FN2/EP3
Today 13:21
by mrespt
Last post by dobbyboy83
Today 13:24
1 Replies, 29 Views
PRO 35W HID Xenon...
24th January 2011 15:17
by Mr JP
Last post by Mr JP
Today 13:14
1 Replies, 87,582 Views
Tuning in Greece
4th February 2008 20:27
by alexps
Last post by vatigoal
Today 12:48
16 Replies, 827,656 Views
How do I remove Wing...
16th November 2012 19:07
Last post by Snowglobe
Today 12:12
20 Replies, 10,278 Views
HONDA CIVIC Type R GT-...
29th April 2017 15:02
Last post by MaTTALICa10
Today 12:11
4 Replies, 222 Views
Copyright ©2000 - 2017, Jelsoft Enterprises Ltd.
vBulletin Security provided by vBSecurity v2.2.2 (Pro) - vBulletin Mods & Addons Copyright © 2017 DragonByte Technologies Ltd.
User Alert System provided by Advanced User Tagging (Pro) - vBulletin Mods & Addons Copyright © 2017 DragonByte Technologies Ltd.
