Stoptech Touring Kit - Page 2 - Civinfo
Old 28th June 2014, 03:45   #21 (permalink)
Thanks given: 101
Originally Posted by jonathan power View Post
Cant make my mind up on these or the bbk kit.Theres not enough reviews on the touring kit.I did come across one and the guy said there was hardly any improvement bar in the looks department.
I dont do track days so im leaning towards the touring kit because of the price compared to the bbk.But in saying that i dont want to waste my money with the touring kit if its not a vast improvement over oem.Id sooner save up the extra £££ for the bbk.
If anyone can give some extra info on the touring kit that would be great?
were you referring to my review about the touring kit with hardly any improvement? you have to bear in mind I had braided lines, uprated brake fluid, stoptech grooved discs all around and stoptech pads at the front before I changed to the touring kit, and if you look at the whole set up, the touring kit did not give me much apart from slightly bigger pads, going from OEM to touring kit with better brake pad is going to be a BIG difference. BBK is overkill for a road car, tbh touring kit is over kill for a road car but I love those calipers. lol
TAS_Jeffers is offline   Reply With Quote Quick reply to this message
Old 28th June 2014, 14:43   #22 (permalink)
jonathan power's Avatar
Thanks given: 1
Hi tas im not sure if i read your review or someone elses,do you have a link to your review?
jonathan power is offline   Reply With Quote Quick reply to this message
Old 28th June 2014, 15:26   #23 (permalink)
lazytrev's Avatar
Car: 2008 NHB CTR
Thanks given: 237
Have you any experience with the touring kit or know anybody that has?
No mate but I've got BBK for track use.
You simply cannot compare the OEM brakes to these. The touring kit has 4 pistons compared to the OEMs having 1.
Not 100% but pretty sure the discs are thicker. I think kevh04 uses his touring kit on track so they must be good. Pop him a pm
lazytrev is offline   Reply With Quote Quick reply to this message
Old 28th June 2014, 15:30   #24 (permalink)
Thanks given: 1
Thanks trev
Old 28th June 2014, 15:33   #25 (permalink)
Commercial user
ABP Motorsport's Avatar
Thanks given: 258
The Touring kits uses an ST41 caliper, with 4 pistons and yes, a thicker disc too. It's 300mm in diameter but thicker to aid in cooling.
Going from standard brakes to either of these setups will be night and day. The biggest advantage to the BBK is the 2 piece disk setup which is better for dissipating heat and gives a bigger surface area for the pad.
The Touring kit is great value and a huge improvement over standard.
Hope this helps.
Rich
ABP Motorsport is offline   Reply With Quote Quick reply to this message
Old 28th June 2014, 16:13   #26 (permalink)
Thanks given: 1
Hi Rich thanks for that,it helps alot.Can i get a price for the following please with p&p to Ireland.Im looking for The Touring kit,the B14 bilstein coilover kit and a set of 15mm spacers.
Thats what i want to begin with but is there anything else i can add to that to improve overall ride quality and keep it nice and tight round corners.
Regards jonathan
Old 28th June 2014, 16:36   #27 (permalink)
lazytrev's Avatar
Car: 2008 NHB CTR
Thanks given: 237
Originally Posted by ABP Motorsport View Post
The Touring kits uses an ST40 caliper, with 4 pistons and yes, a thicker disc too. It's 300mm in diameter but thicker to aid in cooling.
Hope this helps.
Rich
I'm pretty sure the touring kit uses the smaller st41 calliper. BBK uses bigger st40
Thanks to lazytrev from:
Old 30th June 2014, 10:51   #28 (permalink)
Commercial user
Thanks given: 258
Completely right, St41 is the smaller caliper and the ST40 is used in the BBK
Cheers Trev!
Rich
Old 30th June 2014, 10:52   #29 (permalink)
Commercial user
Thanks given: 258
Regards jonathan
Sending you a PM now Jonathan!
Cheers, Rich
Old 16th July 2014, 23:28   #30 (permalink)
Thanks given: 1
Hi Rich
If in the future i decided to charge my car would the touring kit be able to cope with extra power.
What is the cost of replacement discs and pads for the touring kit,and whats the price of replacement discs and pads for the BBK kit?
I will definitely be getting either one of these kits over the coming weeks so need to know about costs,thanks again for answering all the questions
Regards
Old 17th July 2014, 11:45   #31 (permalink)
Commercial user
Thanks given: 258
Hi Rich
Regards
I think the touring kit would be fine for forced induction, for road use definitely. The only thing i would say is, if you are charging, and possibly thinking of doing track days or speed runs the Big Brake Kit maybe the route to take. It's future-proofing it that way.
Cost wise for replacement parts, there isn't a huge difference.
Touring kit;
Discs £300.00 (pair)
Pads £99.00 (yellowstuff)
BBK;
Rotors £390.00 (pair)
Pads £112.00 (Yellowstuff)
Hope this comparison helps. Any other questions, let me know!
Rich
Old 6th December 2014, 19:32   #32 (permalink)
Car: '08 1.8 Sport, Milano Red
Thanks given: 6
who can share experience: putting this kit to a 1.8 requires removing/cutting the whole dust shield?
eddie_gt4 is offline   Reply With Quote Quick reply to this message
Old 8th December 2014, 08:42   #33 (permalink)
Commercial user
Thanks given: 258
Total removal of OE dust shield is required.
Chris
Old 3rd May 2015, 07:37   #34 (permalink)
Big_Rich's Avatar
Car: 2008 CTR-GT DBP
Thanks given: 18
do you still do these kits and if so, how much fitted?
Rich
Big_Rich is offline   Reply With Quote Quick reply to this message
Old 4th May 2015, 17:19   #35 (permalink)
Anderoo's Avatar
Car: 2016, Polished Metal Type R
Thanks given: 44
Yes mate they should do. I had one fitted in April.
Anderoo is offline   Reply With Quote Quick reply to this message
Old 4th May 2015, 18:26   #36 (permalink)
Big_Rich's Avatar
Thanks given: 18
Cheers mate, how are you getting on with them day to day?
Rich
Old 4th May 2015, 20:21   #37 (permalink)
Anderoo's Avatar
Thanks given: 44
Rich
They are great, if you are running standard then they will be a massive difference. I already had the hoses done on mine, so the pedal feel is much the same. But there is more bite and stopping power. And they look so much better.
Overall I am very happy with them. Oh and you will need 15mm spacers if running standard wheels to clear them. This as well makes the car look even better.
Thank You to Anderoo from 2 Users:
Old 4th May 2015, 22:28   #38 (permalink)
Commercial user
Thanks given: 258
Thanks for putting up some first hand experience Andy. I love your car, sitting on the new anthracite wheels!
We still have supply of the touring kits Rich. I'll check availability and cost tomorrow for you
Rich
Thanks to ABP Motorsport from:
Old 4th May 2015, 22:35   #39 (permalink)
Anderoo's Avatar
Thanks given: 44
Rich
Cheers Rich!
I really do love the new look. Everything has just added the little bits, wheels, spacers, calipers and then the Black breaking up all that White.
Sorry gatecrashed brakes there.
Thanks to Anderoo from:
Old 5th May 2015, 12:00   #40 (permalink)
Commercial user
Thanks given: 258
Rich
Hi Rich, sorry for the delay in my reply.
We have the Touring kits in stock @ £950.00 inc VAT.
Fitting would be £200.10, including Castrol Response brakefluid.
Total £1150.10 inc VAT
I have two kits in stock, so let me know if you have any questions or would like to book in to get it fitted. I can also ship the kit and fluid out to you, cost-wise to mainland UK would be £20.00 due to weight, but would see you next day with UPS.
Rich
Insurance
Human Verification
Similar Threads for: Stoptech Touring Kit
**Stoptech Touring 4-pot kit offer!** ABP Motorsport ABP Motorsport 46 25th February 2013 13:41
Brakes Stoptech Touring Brake Kit jonno66 Wheels, Tyres, Suspension and Brakes 53 24th February 2013 11:51
Stoptech Touring 4-pot kit civi08 ABP Motorsport 1 21st June 2011 18:16
Stoptech Touring 4-pot FN2 kit - NEW!! ABP Motorsport ABP Motorsport 23 30th December 2010 19:41
» Buyer's Resource
» Recent Discussions
How to clean / remove...
18th March 2012 20:25
Last post by Kwame-Flip
Today 11:17
776 Replies, 149,505 Views
What makes a Fn2(2011)...
19th March 2017 22:17
Today 11:15
38 Replies, 678 Views
15% Discount at EBC...
26th November 2008 20:09
by Pottsy
Last post by stevencavanagh
Today 11:14
469 Replies, 141,575 Views
55% OFF CAR PARTS - THIS...
Today 10:55
Last post by GSF CAR PARTS
Today 10:55
0 Replies, 13 Views
musegroove's FN2 -...
28th April 2016 09:51
Last post by Farqui
Today 10:50
1 Replies, 25,858 Views
Civic and Jazz I-shift,...
17th May 2016 20:51
Last post by namaqua
Today 10:32
63 Replies, 3,559 Views
Lowering springs or OEM
Today 09:32
Last post by flashy
Today 10:30
5 Replies, 55 Views
New CTR GT owner
Yesterday 12:20
Last post by Ricky Eyers
Today 10:30
8 Replies, 117 Views
jaxckhan ishift 1.8 type...
16th March 2017 00:35
Last post by anfield786
Today 10:27
84 Replies, 1,160 Views
"History of Trip A" on...
9th February 2017 10:02
Last post by Red Dwarf
Today 10:20
8 Replies, 441 Views
Copyright ©2000 - 2017, Jelsoft Enterprises Ltd.
vBulletin Security provided by vBSecurity v2.2.2 (Pro) - vBulletin Mods & Addons Copyright © 2017 DragonByte Technologies Ltd.
User Alert System provided by Advanced User Tagging (Pro) - vBulletin Mods & Addons Copyright © 2017 DragonByte Technologies Ltd.
