| This thread is about: HD Format War? What War?, it's in Any non Civic chat here please! at the Honda Civic forum Civinfo; N ever T wice the S ame C olour... | ||
#122 (permalink) | |
#123 (permalink) |
No - your TV accepts a 24 Hz signal but then converts it to 60 Hz again, so you get the judder. Have a look at the reviewer here dated 20 Dec.
#124 (permalink) |
Gadgeteer
My PS3 and TV give me an awesome picture, I am outputting via HDMI andeveryone who sees it is very impressed. The PS3 is upgradeable and Sony have already made improvements in the Blue Ray playback via one of the firmware updates.
The PS3 is the cheapest upgradable Blue Ray player (DLNA Client, Media Centre, Games Console), and in the Spring the Play TV service comes out which will allow you to use the PS3 as a DVR which can then either download or stream to your PSP if you have one. I'm just waiting for Paramount to start releasing Blue Ray disks so I can replace some of my very old VHS Videos. |
#125 (permalink) | |
Oh well - you get what you pay for As I only had a budget of £650, it was the best I could get. Apart from that flaw it appears to get reasonable reviews. There appears to be less judder than watching the same BD on my brother's 32" Samsung LCD TV Last edited by alanwalne; 6th March 2008 at 08:24. |
#126 (permalink) |
what res is BD output at?
apparently my (cheap as chips, but all I was allowed to spend at the time tv.gif so the lower res can do multiples of 24, but the higher ones are either 70 or 75 I'm guessing 70 might be better, and loose the occasional A, rather than 75 and have it put the odd extra A in... LOL - completly out of my depth now! |
#128 (permalink) |
just about afloat...
High-definition video - Wikipedia, the free encyclopedia High definition video (prerecorded and broadcast) is defined threefold, by:
A frame or field rate can also be specified without a resolution. For example 24p means 24 progressive scan frames per second and 50i means 25 interlaced frames per second, consisting of 50 interlaced fields per second. Most HDTV systems support some standard resolutions and frame or field rates. The most common are noted below. High-definition signals require a high-definition television or computer monitor in order to be viewed. High-definition video has an aspect ratio of 16:9 (1.78:1). The aspect ratio of regular widescreen film shot today is typically 1.85:1 or 2.40:1 (sometimes traditionally quoted at 2.35:1). Standard-definition television (SDTV) has a 4:3 (1.33:1) aspect ratio, although in recent years many broadcasters have transmitted programs "squeezed" horizontally in 16:9 anamorphic format, in hopes that the viewer has a 16:9 set which stretches the image out to normal-looking proportions, or a set which "squishes" the image vertically to present a "letterbox" view of the image, again with correct proportions. |
#129 (permalink) |
High-Definition Display Resolutions
Resolution (W×H) Pixels Aspect Ratio Video Format Description 1024×768 786,432 16:9 (non-square pixels) 720p/XGA Used on PDP HDTV displays with non square pixels 1280×720 921,600 16:9 720p/WXGA Used on Digital television, DLP, LCD and LCOS projection HDTV displays 1366×768 1,049,088 16:9 720p/WXGA—HDTV standard format Used on LCD/PDP HDTV displays (HD Ready, HD Ready 720p,1080i) 1024×1080 1,105,920 16:9 (non-square pixels) 1080p Used on PDP HDTV displays (Full HD, HD Ready 1080p) 1280×1080 1,382,400 16:9 (non-square pixels) 1080p Used on PDP HDTV displays (Full HD, HD Ready 1080p) 1920×1080 2,073,600 16:9 1080p—HDTV standard format Used on all types of HDTV technologies (Full HD, HD Ready 1080p) 4096×2160 8,847,360 16:9 2160p DCI Cinnema 4k standard format Quad HDTV, (there is no HD Ready 2160p Quad HDTV format) |
#130 (permalink) |
so - the highest res my TV can do is the lowest true HD spec of 1024x768, which is 720p
my TV can only run 720p at 60/70/75Hz so it looks like I'm in for a bit of a stutter with BD unless Sony release a firmware patch to sort it out (somehow! |
#131 (permalink) |
24 FPS Compatible: Enables the display of a 24 frames per second input at the native frame rate of the TV (50/100 Hz).
24 FPS Compatible with 5:5 pull-down: From a 24 frames per second input the image processing replicates the exact frames in sets of 5 to virtually eliminate 'Film Judder' artefacts. Just found this on Toshiba's website, unfortunately my telly is only the former. It is £300 more for the higher spec one so it was the former or nothing!!!! |
#132 (permalink) |
Now I am very confused.....
Which frequency should be a multiple of 24?
Should it be the Horizontal Frequency, the Vertical Frequency or the Pixel Frequency????? |
#133 (permalink) |
Alan, vertical frequency. You can see you have 50 and 60, but that's it. 59.94 is 60, NTSC SD style.
TT - looks like 720p60 for you (like me). |
#134 (permalink) |
cheers Pottsy
confused again now though If my TV can do it (haven't tried it yet, as still working on the wife about the PS3!), wouldn't 720p70 or 720p75 give less judder? 60/24 = 2.5 70/24 = 2.92 74/24 = 3.08 or have I missed something obvious (again!) |
#135 (permalink) |
It might be worse - but either way you'll never know because HD players will only send 24 or 60 Hz. That will make the display default to 60 Hz output.
#137 (permalink) | |
Vivid Blue Rocks!!!
Using a normal controller to wield the light sabre must be dull compared with controlling the light sabre with the Wii controller. The only problem is, you probably look like a complete idiot jumping around your living room waving the controller around like you are a Jedi Knight, but it is great fun All the excuse you need to get a Wii |
| What will win the format war? | Bungle | Any non Civic chat here please! | 23 | 6th September 2006 17:51 |
| Civic 5 door Owner's Manual in .pdf format | andris | General Discussion | 3 | 19th August 2006 21:09 |
