This thread is about: Advice please on connecting TV and PS3 to Sorround Sound System using TOSLink cables., it's in Any non Civic chat here please! at the Honda Civic forum Civinfo; Hi, Please could I ask for your help. I have my TV connected to my 5.1 sorround sound DVD system, currently with a HDMI Lead ...
Old 18th April 2008, 12:27   #1 (permalink)
JoeyF's Avatar
Question Advice please on connecting TV and PS3 to Sorround Sound System using TOSLink cables.
I have my TV connected to my 5.1 sorround sound DVD system, currently with a HDMI Lead for video and a fibre optic TOSLink cable for audio.
I then bought a PS3 for playing Blu ray DVD's on (and games of course).
I would like to connect my PS3 to the sorround sound system in the same way as my TV, only trouble with that is that my sorround sound system only has 1 digital audio input.
Short of swapping over the cable every time I want to watch TV or watch a Blu ray DVD I was wondering if you guys have any solutions
Thanks in advance
Joe.
Old 18th April 2008, 14:27   #2 (permalink)
Hi Joe
Are you saying that your TV connects to the surround with a TOSLink?
Ie your TV outputs 5.1?
And am I right in guessing you have an all in one home cinema system that includes a DVD player - and this is the thing with only 1 TOSlink input?
And I'm guessing (again) that your TV doesn't have TOSlink IN, only out?
Old 18th April 2008, 14:30   #3 (permalink)
done a quick google
Keene Electronics
Maplin> TOSLINK
Amazon.co.uk: Ex-Pro Optical TOSlink SPDIF Splitter - Plus 2 x 1m Optical cables - Value Pack: Electronics & Photo
Old 18th April 2008, 15:21   #4 (permalink)
JoeyF's Avatar
Originally Posted by TTDegs View Post
Hi Joe
H TT,
My TV is connected to the home Cinema via a TOSLink but it is not 5.1, I only listen in stereo (Speakers on the TV don't sound as good as the home cinema.)
It is a home cinema with a DVD player, and it only has one TOSlink input.
And the TV only has 1 x output and no input.
I have seen splitters on the web, but I am unsure how this will work as both the sound from the TV and the PS3 will be travelling down the same fibre optic once it passes the splitter, or does the splitter stop this from happening?
Joe
Old 18th April 2008, 16:26   #5 (permalink)
Cool... ish
If you use the toslink from your TV, when your TV is making sound, it will go down the toslink cable to the splitter.
If you then tune your TV to the PS3, and have no sound output from the PS3 to the TV then the TV won't have anything to send down the toslink
Instead, the sound will be going out of the PS3 to the splitter, and then on to the surround sound system
It will cause a problem if both your PS3 and your TV are trying to output sound at the same time - a switched toslink splitter would get round that, but a) they cost more, and b) you would have to get up to switch the switch!
2 other things to note - I'm not sure if the HDMI cable carries sound (or if it's 5.1) - I use a HDMI to DVI convertor on my TV (no HDMI)
The PS3 can (apparently) only output sound on either toslink or RCA - not both at the same time. dunno why, but read it in the manual.
Final point - I've not tried any of this, as I have a different setup, but at £5 for a splitter it might be worth a punt
Old 18th April 2008, 22:50   #6 (permalink)
Bungle's Avatar
TT pretty much has it (oh, and hasn't accepted me as a freind yet on the PS3 )
The best way to output the sound from a PS3 is through it's HDMI. It is the best audo output you can use, and can handle 7.1 channel uncompressed sound, which digital optical can't.
What I cannot understand is why out have your TV connected to your DVD/amp combo with an optical lead. I am guessing it's for watching TV broadcasts (or sky/cable) and getting the sound through your home cinema amp.
Most TVs have RCA outputs for audio (red and white phono jacks) and I will be shocked if your amp cannot accept that for the sound from the TV. That seems to me like your best bet.
If your TV does not have RCA out (and as it has TOSlink out i really would be supprised), can your sky/cable/freeview output directly to your amp with the RCA plugs, completely removing your TV from the equation, making your screen purely a monitor that handles no sound.
That way, your PS3 gets to output to your amp in 5.1 goodness, and you will still get good quality stereo sound watching TV.
Splitters are not the way to go. Ever.
Old 19th April 2008, 00:05   #7 (permalink)
off topic (sorry!) - TTDegs has yet to suss out PS friend requests - sending or receiving...
Old 20th April 2008, 09:49   #8 (permalink)
JoeyF's Avatar
Thanks for the replies guys.
That's what I thought although the DVD/amp dosent have a HDMI input!
As I only have 5.1 anyway the optical lead is a great alternative.
You're spot on! The TV has built in freeview, I thought I have an amp which accepts an optical lead why not use it!
Both my TV and amp have Phono sockets, but I thought this was "old hat" technology compared to the TOSLink option, hence why I went for that which worked really well the sound was great. The amp only has one TOSLink input hence my problem.
The phono sounds like a good option and I think I might go down that route.
Just out of curiosity have you had dealings with splitters before?
Old 20th April 2008, 16:31   #9 (permalink)
Bungle's Avatar
As the saying goes, any chain/system is only as good as it's weakest link.
As long as you use descent quality cables, there is absolutly nothing wrong with normal phono style interconnects. Whatever you do, though, don't use the ones that you get with equipment, there are really terrible.
Splitters are generally very poor in quality, and can tend to introduce signal reduction or noise into the equation. I have used splitters before, and they are a poor solution to having too many bits of kit to connect to an amp!
Your PS3 is a lovely bit of AV kit, and deserves priority as far as cabling goes. The freeview tuner on your TV will not be making full use of the optical cable, and will sound just as good through a medium quality interconnect.
Similar Threads for: Advice please on connecting TV and PS3 to Sorround Sound System using TOSLink cables.
Speakers Type R sound system R GT Ipods, MP3 Players and ICE 11 8th February 2008 00:15
Speakers Is Warranty Invalidated by fitting aftermarket Sound System in a new Civic? psykik Ipods, MP3 Players and ICE 2 5th October 2007 16:35
[HOW TO] Make the Bassworks system sound reasonable.. basegreen How To 20 6th August 2007 10:12
Subwoofer Upgrade sound system smb09_1999 Ipods, MP3 Players and ICE 2 22nd February 2007 12:15
Music sound system mrcanadian Bugs, faults and irritations 6 24th August 2006 12:27
