This thread is about: Rubber Stop Strip, it's in Any non Civic chat here please! at the Honda Civic forum Civinfo; Does anyone know where to get a length of rubber strip that can be stuck to the garage floor so as to indicate when the ...
Old 27th August 2007, 10:35   #1 (permalink)
allan40alt's Avatar
Rubber Stop Strip
Does anyone know where to get a length of rubber strip that can be stuck to the garage floor so as to indicate when the car has driven in far enough to clear the door coming down? I'm sure I've seen an adhesive 'peaked' or 'domed' strip for this purpose.
PS: I guess something like a rubber threshold strip may well do the job. It just needs to be raised slightly so as you can 'feel' it as the front tyres bump against it.
Old 27th August 2007, 11:07   #2 (permalink)
A length of 4x2 maybe? Dangling tennis ball on windscreen?
Old 27th August 2007, 11:16   #3 (permalink)
allan40alt's Avatar
I thought of the 'tennis ball' but preferred the floor strip idea. A rubber strip 40mm wide x 8mm high should give enough of a 'feel' and I could cut it to length. It's for my wife's side of the garage as she drives in, wereas I reverse in and my sensors give me a 'contiuous' beep at just the right position.
Old 27th August 2007, 11:34   #4 (permalink)
I've put a painted vertical line on the garage wall that I line up with the edge of the passenger door mirror.
Old 27th August 2007, 14:18   #5 (permalink)
elfa7's Avatar
I'm a 4"x2" man.
Old 27th August 2007, 14:21   #6 (permalink)
allan40alt's Avatar
Originally Posted by elfa7 View Post
I'm a 4"x2" man.
With a dangling ball as well?
Old 27th August 2007, 14:27   #7 (permalink)
elfa7's Avatar
Old 27th August 2007, 20:20   #8 (permalink)
allan40alt's Avatar
It's just dawned on me; the perfect product.....cable protector. It's what's used to carry cables across roads, paths etc to prevent them being damaged.
It comes in a variety of sizes. My local City Electrical Factors should have some. I can cut it to length and fix it to the floor. Problem sorted.
Ps: This is similar: Heavy-Duty Cable Protectors
Pps: Just found some on ebay: 900mm RUBBER CABLE PROTECTOR BS476 part 7 CERTIFIED NEW on eBay, Test Measurement Equipment, Electrical Test Equipment, Business, Office Industrial (item 260126155058 end time 04-Sep-07 15:37:37 BST)
Old 28th August 2007, 01:09   #9 (permalink)
lobey dosser's Avatar
I've got a couple of strategically placed bricks that serve the purpose.
Unfortunately, I can't get out of the car once it's in the garage so I don't need the parking guide much!
I guess that cars were much narrower when the previous owner built the garage in the late sixties. Anybody got a Ford Anglia they want to swap?
- KIDDING!!!
lobey dosser is offline   Reply With Quote
Old 28th August 2007, 07:10   #10 (permalink)
andi22b's Avatar
Originally Posted by lobey dosser View Post
I've got a couple of strategically placed bricks that serve the purpose......
The current Mrs. andi22b keeps going on about a couple of strategically placed bricks ................. nothing to do with parking though ..........................
andi22b is offline   Reply With Quote
Old 28th August 2007, 09:04   #11 (permalink)
Harris Tweed
Anthony's Avatar
I use a single house brick on the floor of the garage, which seems to work well.
Anthony.
Anthony is offline   Reply With Quote
Old 28th August 2007, 13:52   #12 (permalink)
allan40alt's Avatar
As I am already the owner of 2 pavia blocks (sounds better than 'house bricks' don't you think) I thought that I'd give that idea first try as it's the cheapest!
Old 28th August 2007, 15:36   #13 (permalink)
Harris Tweed
Anthony's Avatar
Ahh... what I meant to say was that I am using a single instance of a fundamental construction media primitive.
Anthony.
Old 29th August 2007, 23:02   #14 (permalink)
pjr
We call him... The Stig
pjr's Avatar
Used to use a tennis ball hanging from the roof, which worked well.
Now, have a 2" x 1" strip of wood, lying across the garage floor (not fixed down), and this also works fine - Don't think the paint on the bumper would take too kindly to hitting the pedal of my mountain bike which is sitting against the back wall of the garage!
Old 30th August 2007, 22:34   #15 (permalink)
LNT
LNT's Avatar
Bearing in mind I have parking sensors on the back of my car, I do the following. When I think I'm there, I stop, put the car into reverse, press the remote for the garage door and when it shuts, the bleeps shouldn't be continuous....
LNT is offline   Reply With Quote
Old 31st August 2007, 02:01   #16 (permalink)
...but if they are?
Arrrrgh - too late - the door's shut on your tailgate!
Old 31st August 2007, 07:58   #17 (permalink)
elfa7's Avatar
Smoothy ! .
Old 31st August 2007, 15:26   #18 (permalink)
allan40alt's Avatar
I reverse my Civic in and when the sensor note is continuous I know the front is in far enough for the sectional door to come down. My wife parks her 206 next to me, but drives in.
This means she either drives too close to my workbench and I can't get to my reserve wine rack which is behind my Civic, or she parks with the back too far out, and the door will hit it.
The pavia blocks seem to work Ok.
Similar Threads for: Rubber Stop Strip
Windscreen Windscreen top strip allan40alt Bugs, faults and irritations 13 24th May 2008 20:42
Recalls Windscreen Strip vtidan Bugs, faults and irritations 4 29th September 2007 12:48
Flappy rubber bits..!! Al Stirling General Discussion 16 7th September 2007 20:58
Wanted: rubber window runner/seal/guide (?) pankyp For sale and Wanted 0 6th June 2007 17:09
Strip for the Hoff richierich Any non Civic chat here please! 1 16th February 2007 19:01
