LinkBack (1) | Thread Tools |
#1 (permalink)
![]() Join Date: 15th August 2007
Humming noise from clutch when cold
Has anybody notice an occasional humming noise from their clutch when cold, and when just starting off? Once you drive around abit it clears up, and it only does it occasional. My neighbour has a new Peg 307 and that does it too, it appears as soon as you find the biting point and move. I thought it was the brakes seizing up, but now think its from the clutch? (I've only done 10,000 miles)
![]() Join Date: 10th August 2007
Clutch is hydraulic . I also get the whirring noise from the clutch when cold. Glad you posted this as I was beginning to think it was a problem with my car. It seems to be normal.
I spoke to the dealer about this noise, the clutch is hydraulic on the CTRs. They told me that they have never come across this with their CTRs. They asked me to keep an eye on it and if it gets worse then to book it in. On some days you just dont hear it, if it was the clutch then you'd think that it would do it all the time? May be it sometimes drys out? I'm not too bothered as I still have 2 year waranty remaining on the car.
![]() Join Date: 14th September 2007
So guys, has anyone brought this up with Honda?
Mine has started doing this and I was sure it was my brake pads as I know they need doing... Any update from you guys would be appreciated! Would rather my clutch was silent or is that too much to ask from a decent car these days!? |
![]() Join Date: 10th October 2008
I did speak to the Honda dealer about this when I got the car serviced, they told me that I had to leave it with them overnight. I have nt bothered as it does nt always do it, it seems to be worse when its damp and raining? After a couple of biting points it disappears. I just thought it was down to me sitting in traffic all day and having something dry out?
I did speak to mechanic (family member) and he thinks it could be the clutch bearings drying out, it only happens in 1st and not in reverse, which still does nt make sense as it should matter which way the bearings are spining? I was going to leave it till it gets worse to get it looked at, I still have 2 more years Honda cover left. I was reading the Type R foreum about this and some guy did take it to a dealer, they changed the chutch plate and a couple of days later it was doing it again! Last edited by CCC; 23rd October 2008 at 09:47. |
![]() Join Date: 14th April 2007
It's probably the release bearing, not unusual to get some noise from them. BTW I think all the Civic have a hydraulic clutch the diesel certainly does.
Yes the CTR also has a hydraulic clutch I asked the dealer this question, I'm not sure that a new clutch would fix this problem for good, it may reappear after a few months.
Civic RGT
![]() Join Date: 7th August 2008
Either thrust bearing or beacause of lightened flywheel which can warp slightly and thus causes these noises when cold. Had it on the EP3 too.
Civic RGT
they could replace the thrust bearing, but if its the flywheel it will happen again. Put your mind at rest and take it to the dealer and see what they say. Good Luck with it.
#14 (permalink) |
Wigan Warriors
![]() Car: 2008 CTR, Red
Mine is doing this too when setting off in first, only every now and again so I tried loading the clutch by setting off in 3rd gear and it does it every time. Clutch and parts are a grey area when it comes to warrantee. Wear and tear is often used as an excuse for not covering them, seeing as I don’t trust dealers as far as I can shot put a planet, im going to ask a few questions now. By the way I have only done 5k
#15 (permalink) |
I was reading up on this on a different website, and one dealer re-greased something on the clutch, not sure what, and it was nt covered as they did nt class a noise as a fault? Everything still works fine! The sound gets worse when its dump! It looks like that this is a common problem on Hondas! Another dealer said it was damp on the clutch plates???
I'm not going to bother with it now, if it gets worse then book it in! Some guy on Civic Type R Owners Website had a new clutch fitted and the noise was still there! One dealer told a guy that it was: the spriggot bearing next to the flywheel that was making the noise Another guy said: Dont reckon its a problem mate. Loads of people on here have reported the same noise. Mine started not too long after new (March 04). And I have done over 30K miles now with no problems. Another guy: had the clutch noise when the engine was cold. Told dealer that the forum thought that it was the clutch release bearing so they changed it. This morning was the first cold start since..and the noise is still there. Any other ideas? Same as everyone else, just the first few gear changes of the day, perfect after that. This has been going on for years even on the 2004 CTRs. |
#16 (permalink) |
![]() Car: # 39 Type R GT,Milano Red.
noisy clutch
i have the same noise,which does only happens when first pulling away when cold,however it goes away very quickly. its definately not the brakes & if it was a dry bearing it prob wouldn't go away. if you start on a hill & roll then put the car in gear & lift the clutch it doesn't happen. also if you start facing up hill you can ride the clutch & get the noise to stay for quite a few seconds.i think its just something to do with the clutch being cold & nothing serious.
#17 (permalink) | |
#18 (permalink) |
Ah, good, other people have this noise, it's not just me.
Symptoms as described, only when the car is cold and pulling away in 1st, gone after a few minutes. I guessed the clutch release bearing before coming on here and am possibly not too far out. Not seeing it as a major problem but will monitor it. 08 plate Type R with 6,000 miles Snert |
#19 (permalink) | |
LinkBack to this Thread: http://www.civinfo.com/forum/bugs-faults-and-irritations/16511-humming-noise-clutch-cold.html
| Noise from the Transmission/Clutch - 8th Generation Honda Civic Forum | This thread | Pingback | 25th February 2009 04:12 | |
Similar Threads for: Humming noise from clutch when cold
| Squeaks Clutch pedal noise | Mr Lovedog | Bugs, faults and irritations | 17 | 12th August 2007 17:27 |
| Cold arm | jalaman | General Discussion | 2 | 24th July 2007 09:33 |
| How cold is your air con???? | mr w1z | Type-R | 8 | 12th June 2007 17:22 |
| Transmission vtec when cold | DUNCAN | Engines and Transmission | 25 | 11th February 2007 20:24 |
| Engine Someone doesn't like the cold! | Jammy | Bugs, faults and irritations | 8 | 22nd December 2006 19:49 |
