Old 15th June 2009, 03:15   #1 (permalink)
reb
reb's Avatar
Question Type R engine whining
Is it normal for there to be a loud whine when accelerating in any gear. It happens at about 3000 revs and gets louder all the way to 8000.
It also happens at any throttle position.
Is this normal?
reb is offline   Reply With Quote
Old 15th June 2009, 04:36   #2 (permalink)
aidanjones88's Avatar
Car: 2007 1.8 Type S Alabaster ;)
i have this also on my type S, not sure if it is normal or not. i am interested in this answer too.
Hopefully it is normal and not too much to worry about. i havent noticed any MPG or performance decreases.
Does yours sound like Air is being sucked in from somewhere?
aidanjones88 is offline   Reply With Quote
Old 15th June 2009, 06:36   #3 (permalink)
Orschild's Avatar
Are you sure that is the engine and not the gearbox? Gearboxes often make a whining sound when the cogs interlock. It is quite common.
Orschild is offline   Reply With Quote
Old 15th June 2009, 09:11   #4 (permalink)
Car: 2009 59 CTR, Silver
Hi, sounds like a wheel bearing! get it to your dealer quick as the bearing will over heat and explode, which will cause the car to grind to a stop.
Matt
VetecMatty is offline   Reply With Quote
Old 15th June 2009, 21:32   #5 (permalink)
reb
reb's Avatar
Its getting booked in for the first service very soon, will have them check it out then.
@aidanjones - Its hard to describe what it sounds like, will let you know what the problem with it is after I get it checked
Old 16th June 2009, 00:50   #6 (permalink)
Thanks,
Mine seems to sound like air being inhaled from somewhere and seems to increase in speed and pitch with the revs as they go up. doesnt happen all the time but it is quite annoying.
Old 16th June 2009, 01:11   #7 (permalink)
R-2
found Nemo
R-2's Avatar
Car: 2008 TYPE R GT NHB
Is it like the noise described in this thread? Engine sound question
Old 16th June 2009, 01:35   #8 (permalink)
[ ! BUGGER OFF NOW ! ]
J. Derek Riddell's Avatar
Low engine oil level ?
Dirty air filter ?
Misfitted air filter cover ?
J. Derek Riddell is online now   Reply With Quote
Similar Threads for: Type R engine whining
Other Whining diesel bobanreg Engines and Transmission 2 23rd February 2009 21:28
whining engine noise thread ........where is it? blader General Discussion 4 27th July 2008 18:10
AUX in Whining after Connects2, help me? Jani Ipods, MP3 Players and ICE 7 25th April 2008 11:41
AC/Heater Noisey Whining Fan? Barryjm Bugs, faults and irritations 15 14th February 2008 20:54
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48
