This thread is about: Water dripping from under the engine after parking up...?, it's in Bugs, faults and irritations at the Honda Civic forum Civinfo; When i went out today after a half hour drive and then parking up for about an hour i returned to the car to find ...
Old 3rd September 2006, 17:52   #1 (permalink)
rmh999's Avatar
When i went out today after a half hour drive and then parking up for about an hour i returned to the car to find a small amount of water that appeared to have leaked from under the middle of the engine.....(probably half a cup full)
I am pretty sure it was water as no smell to it, but i am concerned that it may be a problem... has anyone else noticed this.... or is it just cooling and coming out of the expansion overflow pipe ?
As its new and i am going to be doing large milage i really dont need it to run out of water...
Rob
rmh999 is offline   Reply With Quote
Old 3rd September 2006, 17:53   #2 (permalink)
Smell My Cheese!
richierich's Avatar
Its from the Aircon, as you cool air down the amount of water vapour it can hold drops, the water has to go somewhere.
Old 3rd September 2006, 17:54   #3 (permalink)
3rd Honda's Avatar
Unless it has the colour of antifreeze, its probably just the condensate from the air conditioner.
Old 3rd September 2006, 18:02   #4 (permalink)
Bungle's Avatar
Agreed. Most like from air con. My car always leaves a wet patch! I often get a whole line of drips from the car when moving off from my drive.
As pointed out, unless it smells chemically or has a colour tinge, no need to worry.
Is it safe to assume this is your first car with a/c? All cars I know of witrh a/c leave puddles of water...
Old 3rd September 2006, 18:04   #5 (permalink)
rmh999's Avatar
No it was clear and we did have the aircon on during the journey....
Sounds like you are right first time... thanks for the prompt response
I feel better now
Rob
Old 8th September 2006, 09:51   #6 (permalink)
Mark996's Avatar
Mine does it too - living here in Portugal, my Air con gets quite a decent work out, so there's usually a wet patch lurking near my car!!!
Mark996 is offline   Reply With Quote
Old 8th September 2006, 10:51   #7 (permalink)
rmh999's Avatar
The 206 CC had Aircon / climate control and NEVER did this... it had lots of other faults though...so this could just be one more, and it was really annoying so often switched off......
The Air Con was truly rubbish, so maybe it just never worked properly, would not surprise me, even according to Peugeot the scale of 16 - 24 was just a graduated system and did not relate directly to the temperature you would get ??!! So why not make it 1 - 10 or something ??
It did do a similar thing once but the fuel economy also suffered as it was leaking petrol really strong smell.. so good job no-one was smoking...
Thanks again for the prompt re-assurances
Rob
Old 15th June 2007, 14:11   #8 (permalink)
Aircon water dumping?
Hi there
I have an 07 CDTi SE, recently after parking i have noticed a stream of water appear under the car when ive parked up and walked back to the car shortly after.
Now i know aircon systems occaisionally dump water from the system, but there seems to be water under the car whenever i stop.
Had a look and its not coming from the engine, and engine coolant levels are fine, temp reading fine etc etc
Any suggestions?
Cheers
Paul
Paulo is offline   Reply With Quote
Old 15th June 2007, 14:25   #9 (permalink)
Wine and cooking !
l-noel's Avatar
Hello Paulo,
Don't worry, it is normal, it is just the water from the compressor. Mine do that too.
Old 15th June 2007, 14:47   #10 (permalink)
Not just on Civics, normal on any AC car to drop condensation from the compressor.
Old 15th June 2007, 18:20   #11 (permalink)
Perfect Guy!
Brodick's Avatar
so Whenever you stop this always happens??
if that is the case I would take it round to the dealer
Old 15th June 2007, 18:53   #12 (permalink)
CopyCatz's Avatar
I first noticed it last weekend, drove 250 km and parked the car. After a few hours I decided to park a few meters down the road and noticed a water trail. Seems pretty normal to me, it's clear condensated water.
CopyCatz is offline   Reply With Quote
Old 15th June 2007, 19:41   #13 (permalink)
Aircon not only cools air, but removes the water. All the time. That's why it's so good to have the aircon on to demist the car.
When ever the aircon is on, water will drip from a little pipe under the car. If ever the water stops, the aircon is faulty!
Old 15th June 2007, 20:40   #14 (permalink)
Your motor is in good health Paulo!
Old 15th June 2007, 23:38   #15 (permalink)
WavyD's Avatar
Only worry when your air-con drops water, then you realise that you don't have air-con!
I'm sick of well meaning old people telling me that my car has a leak.
Old 18th June 2007, 14:17   #16 (permalink)
Excellent, thanks for the replies guys, just wanted to make sure.
Cheers
Old 20th June 2007, 00:49   #17 (permalink)
mouse123's Avatar
yep mine as well seems all in order
mouse123 is offline   Reply With Quote
Old 24th June 2007, 01:22   #18 (permalink)
5 seats are a must!
MC Hammer's Avatar
You also get some water from the exhaust which can leave trails.
A/C water should only be present when you have used the A/C.
Old 24th June 2007, 15:02   #19 (permalink)
Power_of_Dreams's Avatar
Perfectly normal. If your that concerned, you can watch the water come out from under the car when you have the air con on, just look behind the front left or right tyre towards the centre of the car, just behind the metal plate on the undertray...theres a small tube connected to the heater matrix assembly inside, that allows the water thats been drawn from inside the car to be drained!
Power_of_Dreams is offline   Reply With Quote
Old 26th October 2007, 09:07   #20 (permalink)
clindsay's Avatar
Water under car
its hopefully nothing but i almost always get a puddle of water under the car - i park on a concrete drive at home so its really noticable and NEVER use the aircon.
Is this just condensation from the aircon does anyone else have this happen?
clindsay is offline   Reply With Quote
Similar Threads for: Water dripping from under the engine after parking up...?
Leaks Water and more water Welsh Boy Bugs, faults and irritations 16 1st August 2007 13:24
AC/Heater Water on the driveway... probbo33 Bugs, faults and irritations 9 17th March 2007 09:01
Leaks Water water everywhere. lofthouse lightweight Bugs, faults and irritations 5 1st December 2006 20:54
