This thread is about: Cigarette lighter socket coming out...?, it's in Bugs, faults and irritations at the Honda Civic forum Civinfo; I recently invested in a Tomtom and the last time I used it I pulled my power cable from out of the power socket and ...
Old 10th January 2008, 16:56   #1 (permalink)
Girl Aloud
SandGirl's Avatar
I recently invested in a Tomtom and the last time I used it I pulled my power cable from out of the power socket and the whole thing came out of the hole! The wires still appear to be attached and it still powers my Tomtom if I push it in and pull it out carefully, but can this be fixed with a simple bit of superglue or should I be more careful?
SandGirl is offline   Reply With Quote
Old 10th January 2008, 16:58   #2 (permalink)
Comedian/Smart A*se
I'd go to the dealer this is a known problem on some of the earlier model civ's. Just be careful you don't get a shock . It may well be fixed free as a recall/notice.
Old 10th January 2008, 19:25   #3 (permalink)
Jools100's Avatar
Mine's the same. I don't use the cigarette lighter socket for anything so it's not a major problem, but i will mention it to the dealer at the next service.
Jools100 is offline   Reply With Quote
Old 10th January 2008, 19:43   #4 (permalink)
My dealer said I can get it replaced (for an identical piece of sh*t) so I preferred to fix it with "super glue" - no problems 1 year later now
(warning: don't use too much glue or you will damage the surrounding plastic, 2,3 drops will do)
Old 10th January 2008, 20:08   #5 (permalink)
pjr
We call him... The Stig
pjr's Avatar
It's a common problem, and not helped by the TomTom power socket being quite a tight fit in the cigarette lighter socket.
I usually try and press down on the edges of the lighter socket with one hand while unplugging the TomTom - that usually works.
Old 10th January 2008, 20:58   #6 (permalink)
FireStarter's Avatar
I just got the pliers on the tom tom plug and bent the spring clips in a bit so its not so tight, did the same with my mobile charger to, they come out fine now and leave the socket behind as they should
FireStarter is offline   Reply With Quote
Old 11th January 2008, 07:18   #7 (permalink)
It shouldn't pop completely out because there is a small 'fin' on the underside plastic body of the lighter to stop this.
It is a very loose fit though as the 2 underneath 'clips' only just cover the width of the hole so it easily pops out.
I doubt you will have any electrical problems as a result.
Having ventured underneath, if I had a TT or a gadget that needed repeated connection I would be wiring in a third party socket somewhere else more convenient.
Alternatively there must be another lighter model that could replace the Honda one that fixes more firmly with a proper screw thread?
The wiring is very simple though, just 2 black wires with the positive having a wide white tracer to identify it.
Old 11th January 2008, 19:08   #8 (permalink)
Munro's Avatar
There is a "How To" fix for this, click on link below :
[HOW TO] Secure the cig lighter a bit better
Old 12th January 2008, 19:59   #9 (permalink)
Yes, it is even in the New Car Checklist in the Wiki.
New car checklist - Civinfo Wiki
Old 14th January 2008, 12:49   #10 (permalink)
spile's Avatar
I fitted a slave 12v socket behind the central console using wires from the existing 12v socket. My GPS wiring is then left connected.
spile is offline   Reply With Quote
Old 14th January 2008, 14:27   #11 (permalink)
Ditto - only mine currently powers the Talex :
Similar Threads for: Cigarette lighter socket coming out...?
Electrics Cigarette socket to usb FWH Electronics 2 5th November 2007 10:44
Electrics RA Compact cigarette Cable for Garmin Nuvi? Bardley Electronics 6 19th August 2007 12:08
[HOW TO] Wire socket from cig lighter to fuse box for phone Tomthumb How To 34 4th July 2007 10:11
Electrics cigarette lighter john1509 Electronics 16 16th June 2007 17:12
Mounts TomTom charger and Civic's crappy lighter socket NickG Electronics 25 29th January 2007 21:34
