This thread is about: Water ingress to Drivers door, it's in Bugs, faults and irritations at the Honda Civic forum Civinfo; After several nags the dealer has now sorted this but worthy of note. The arm rest section on the drivers door was wet every morning, ...
Old 4th February 2008, 19:41   #1 (permalink)
rmh999's Avatar
Unhappy Water ingress to Drivers door
The arm rest section on the drivers door was wet every morning, not soaked but significantly damp.
I tried parking the car the other way round and various other options to remove any outside factors, but to no avail.
Finally the dealer accepted the issue as the door card is permenantly damaged, and i would not let them replace it unless they identified and cured the root cause.
When they took the door apart they replaced the internal membrane that keeps the moisture onto the outer skin and replaced the trim panel.
This seems to have done the trick but if anyone else notices the same issue, maybe it will help to know what could be causing it.....
Rob
rmh999 is offline   Reply With Quote
Similar Threads for: Water ingress to Drivers door
drivers door lock recall Type S Bournemouth General Discussion 5 26th March 2008 16:05
Trim drivers interior door opener bikersupermoto Bugs, faults and irritations 7 10th October 2007 10:15
Squeaks Squeek above drivers door? Jani Bugs, faults and irritations 12 13th July 2007 17:23
Bodywork drivers side door handle clunky pikkumies Bugs, faults and irritations 33 27th June 2007 00:09
Leaks Door full with water?? sexykungfufighter Bugs, faults and irritations 5 12th May 2007 21:47
