This thread is about: Radio Reset?!??!, it's in Bugs, faults and irritations at the Honda Civic forum Civinfo; Hi, I've had my 08 model Type-R for almost a month now, and I've noticed that the Radio resets itself for no reason sometimes!?? The ...
Old 20th February 2008, 11:37   #1 (permalink)
arun1uk's Avatar
Radio Reset?!??!
The first time it happened, I had an MP3 CD in and I clicked the "Channel Up" button on the steering wheel, all off a sudden it had a think then the radio turned itself off and then on again...was a bit strange and it made an acoustic pop (that's the technical term - seriously!). It also happened again when I changed track via the radio buttons too (but on a diff day)....happened 4 times in total, in 1 month.
Anyone encountered this yet? Thinking of taking it to the dealer and getting it sorted.
Cheers
arun1uk is offline   Reply With Quote
Old 20th February 2008, 13:09   #2 (permalink)
Originally Posted by arun1uk View Post
Before going to the dealer - please check if your discs are "finalized" in the burning software, if they are not (e.g. if only the session is finalized), most players will reject them completely, and others will play them with problems and seek the next track long - which could be the "reset"... If it happens with pressed CDs however, it's definitely at least a dirty laser lens if not worse
Cheers
Old 20th February 2008, 13:36   #3 (permalink)
arun1uk's Avatar
Thanks for the reply, but all my discs are finalized. Used them in all my other cars without trouble....it's definitely a fault with the software. It seems to get in an error state loop (which would explain the pause), then resets itself after a timeout period.
Just wondering if anyone else has had this or if mine is an isolised case?
Old 20th February 2008, 13:53   #4 (permalink)
Hard to tell, mine is a 2006 and the only problem I've had with audio (apart of the lacking soundproofing in the doors) was the RDS not working, which was repaired by a firmware update. I think it might be possible that you got this update and the service guys had a faulty update disc or somehow managed to screw it up It may also be that your CD unit is simply faulty, anyway, a tip to the dealer
Old 20th February 2008, 15:29   #5 (permalink)
ghowarth's Avatar
Not had the same problem, but I regularly get a split second of radio silence, happens very often, driving along listening to radio 1 and it just goes silent......only for half a second or so, but enough to make you notice, and often wait for the hands free to ring......as it goes silent when the phone rings!!
But it is not..........I know I need to go to the dealer but know it will probably not do it whilst there!!!
ghowarth is offline   Reply With Quote
Old 20th February 2008, 16:24   #6 (permalink)
pcr
pcr's Avatar
Ghowarth, isn't that just the AF changing channel ?
Old 20th February 2008, 16:35   #7 (permalink)
ghowarth's Avatar
Thats what I thought, but it can happen about 10 times on a two mile journey, and happens even when stereo button is not flashing!
I know it's minor, but it's really annoying!!
Old 21st February 2008, 07:36   #8 (permalink)
No, my radio has no problems. I usually play audio and mp3 disks and the radio works well.
reed is offline   Reply With Quote
Old 22nd June 2008, 02:06   #9 (permalink)
xfield's Avatar
My radio once reset itself - whilst listening to the radio. Mines an 06 model, only occurred once in the time I've had the car - about eight months.
xfield is offline   Reply With Quote
Similar Threads for: Radio Reset?!??!
Computer PGM-FI Reset Djevans4 Electronics 6 1st June 2008 09:44
Computer Average speed reset Urban Tangleweed Bugs, faults and irritations 18 19th August 2007 21:27
Servicing How To Reset the Oil Service abu-sarta Buying, Dealers and Servicing 1 13th June 2007 19:20
MPG MPG after ECU reset KevinF Engines and Transmission 19 28th January 2007 03:27
Computer Average Speed Reset Steevie Electronics 6 25th September 2006 13:27
