This thread is about: Clutch burning??, it's in Bugs, faults and irritations at the Honda Civic forum Civinfo; Hi, Was going up to Uni today to see a mate, and whilst going up the main hill, had to slow to a crawl to ...
Old 22nd February 2008, 14:29   #1 (permalink)
Comedian/Smart A*se
Clutch burning??
Was going up to Uni today to see a mate, and whilst going up the main hill, had to slow to a crawl to avoid a large box, the car was rolling quite slowly in second gear, and I went to shift down to first, the gear lever moved, engaged etc. but the clutch didn't, I reved to accellerate and tha gears spun, and the revs went higher, back down to second, same thing, by this time worrying, tried third no luck, back to first, in it goes and takes off, but with an awful smell of burning clutch, dealership, can find nothing wrong, and it's stopped doing it now. I'ts only happened once, but on a hill quite scary
Anyone else had similar in a proper manual???
Old 22nd February 2008, 16:26   #2 (permalink)
Oh my... This really looks like a fried clutch, sh*t...
Once had this, yes, but in an old Fiat, >20 years ago (and it was my fault I was pulling a way too heavy caravan through Greece)
:edit) if the service says nothing wrong, maybe it isn't that bad? The smell could come from rubber (tyres) and the "lameness" from the ESP (?)
Old 22nd February 2008, 23:19   #3 (permalink)
Nick7's Avatar
What kind of floor mat you got? Maybe it got stuck for a clutch, so it didn't let pedal move all way up?
Old 23rd February 2008, 15:30   #4 (permalink)
Comedian/Smart A*se
Honda approved ones, thing is now the gear change is perfect and smooth and I have no problems getting 2nd gear, like I had before!!!
Old 15th March 2008, 12:05   #5 (permalink)
Andiww's Avatar
I had this problem once. I was getting my car out from my friends garage. I was reversing on a very slopy driveway with high revs. It smelled awful and I thought thats the end of my brand new clutch from my brand new car. Fortunately I didn't notice any difference. Than my friend (a car mechanic) told me that honda clutches are very resistant for such situations. I don't know if its true. Did you check your clutch at the dealer? Maybe I should go and check it...?
Andiww is offline   Reply With Quote
Old 20th March 2008, 12:56   #6 (permalink)
cnicolini's Avatar
Yes it sounds like you were frying your clutch, I did the same on a steep hill. I started to roll back and gave it more gas, then lifted the clutch with high revs and had the burning smell. I do not recommend doing this too offen as you will burn the clutch out!
It sounds like that you did nt engage gear correctly for some reason, do you have very low miles? I had my reverse gear sticking but touch wood, its now disappeared (got 6,000 miles on the car now). It may improve once you run in the car and its gearbox, the Honda mechanic that I saw told me that its tight on a new car and needs wearing in.
Old 20th March 2008, 18:24   #7 (permalink)
Comedian/Smart A*se
Mine had about 4000 miles on the clock when it happened, it's been fine since really, no more burning episodes.
ATB,
Similar Threads for: Clutch burning??
CD Burning stuff Unknownsoldier Any non Civic chat here please! 9 22nd January 2008 23:46
Oil Burning oil smell question... uncler Engines and Transmission 6 5th January 2008 14:15
Clutch adjustment tomnorth Any non Civic chat here please! 2 7th November 2007 08:36
Built in CD Burning MP3's for Car leodis41 Ipods, MP3 Players and ICE 4 4th March 2007 17:32
Transmission Clutch Judder geoff Bugs, faults and irritations 10 13th September 2006 05:33
