This thread is about: Road Salt and No Rear Wiper!!, it's in Bugs, faults and irritations at the Honda Civic forum Civinfo; I like to know exactly what is behind me...cyclists don't have big headlights...but they do die when you turn into a road without knowing they ...
Old 29th February 2008, 10:03   #41 (permalink)
I like to know exactly what is behind me...cyclists don't have big headlights...but they do die when you turn into a road without knowing they are behind you
Variantealta is offline   Reply With Quote
Old 29th February 2008, 10:24   #42 (permalink)
My car is fitted with some of the best wing mirrors I have seen on a car - quite sure these are standard issue...
Old 29th February 2008, 11:04   #43 (permalink)
can't quite work that one out actually
If you're going so slowly that a cyclist can hit you from behind when you turn left, then they are unlikely to die (although, granted they might not be tooo chuffed!)
But wing mirror checking should sort that, and rear mirror / view probably wouldn't have helped anyway.
If you're going that much quicker, then surely you have just overtaken them, and are possibly going a bit too quick for the corner anyway?
sorry - obviously my lack of comprehension here - but I just can't see how better rear view would help in this situation
Old 29th February 2008, 11:22   #44 (permalink)
the point is not all cyclists travel convniently at the edge of road hugging the curb, nor do they politely remain at a constant slow speed so as not to interfere with traffic.
A decent able cyclist can easily maintain 30 mph and is therefore travelling as fast as another car or motorcycle. The problem with not being able to see behind you stems from the fact that you should be able at all times to see clearly out the back of a car, you may be happy to not have this ability but you should be able to.
Not all cyclists, motorbikes etc will be visible to wing mirrors due to their position on the road. Mirror, signal, manouvere includes the rear view mirror not just the wing mirrors.
Old 29th February 2008, 11:30   #45 (permalink)
Comedian/Smart A*se
Ahhh, but not if you reverse over them a bit.
Old 29th February 2008, 11:31   #46 (permalink)
Damn i knew i had been doing it wrong all these years, cheers Tom!
Old 29th February 2008, 11:35   #47 (permalink)
yep, appreciate all that
So. You are approaching a side road which you want to pull into.
In option 1 - a car with a rear wiper, which has been used, and therefore has complete rear visibility, you look in your rear view mirror, and see a cyclist catching you up.
In option 2 - a civic, which for whatever reason, you can't see out of the rear window, you attempt to look in the rear view mirror, but fail to see the cyclist catching you up.
This is where I get a bit lost
what would you do differently in option 1 to option 2, that would prevent the cyclist from crashing into you from behind and dying?
Old 29th February 2008, 11:36   #48 (permalink)
Comedian/Smart A*se
Also helps to go slowly so the weight is there for a longer period
Gosh, do you think people will notice all the cyclists that have gone missing in Canterbury now???
Old 29th February 2008, 11:42   #49 (permalink)
Me neither.
Need of a rear wiper can be argued for sure, but for this reason?
Old 29th February 2008, 11:46   #50 (permalink)
TTDegs...the difference is that in the first scenario, you see them and allow them to pass on the near side or make sure they have see you indicating and have stopped in a safe place.
In the second scenario you don't know they exsist they attempt to sneak down the near side unaware of your turning and then impact the vehicle as you turn across their path...
Simple as that really...
Old 29th February 2008, 12:03   #51 (permalink)
So does that make all vans and trucks dangerous?
Old 29th February 2008, 12:13   #52 (permalink)
More dangerous than cars, yes.
Old 29th February 2008, 12:13   #53 (permalink)
DeanFYoung's Avatar
If you're indicating during these Manoeuvres, the cyclist is a fool to try and sneak up and get past. Dirty rear window or no window at all!
There's only so much a driver can do to avoid an accident, the whole process also relies on the other party to not want an accident either.
Old 29th February 2008, 12:15   #54 (permalink)
Your right but surely the lack of a rear wiper is a bit like a knife thrower shutting one eye - a pointless risk that can be easily avoided.
Old 29th February 2008, 12:20   #55 (permalink)
Only if the water droplets obscure the view sufficiently to make it impossible to see through. I find I can see through the droplets even before they blow off a mile or two down the road.
Old 29th February 2008, 12:23   #56 (permalink)
DeanFYoung's Avatar
I guess, so the cyclist is the knife thrower taking the pointless risk...one that the driver can never do anything about.
Old 29th February 2008, 12:30   #57 (permalink)
GHGH's Avatar
Here trucks now and then do that .
Why do you change the avatar so frequent?
Old 29th February 2008, 12:45   #58 (permalink)
Ok - I'm happy to admit it when the huge and overwhelming body of evidence is against me
So I have just one final question on the matter:
Varinteala - if you truly believe that this is such a dangerous situation, how do you sleep at night, knowing that you have sold such a potential death trap on wheels?
Old 29th February 2008, 12:55   #59 (permalink)
GHGH's Avatar
My driving instructor made a fuss about this, but I must admit it hasn't turned out to be a big problem yet.
Old 29th February 2008, 13:10   #60 (permalink)
I'm on commission!
Similar Threads for: Road Salt and No Rear Wiper!!
Rear wiper Is it a problem that the civic doesnt have a rear wiper? Robbieee Bugs, faults and irritations 85 11th January 2008 21:48
I've got a rear wiper! Skaven252 General Discussion 10 29th November 2006 13:50
Rear wiper nonsense basegreen Recycle Bin 7 17th November 2006 15:44
Rear wiper Lack of rear wiper skaramanga Bugs, faults and irritations 6 29th September 2006 10:52
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36
