This thread is about: Creaking windscreen ??, it's in Bugs, faults and irritations at the Honda Civic forum Civinfo; Hope someone can help ? I have what appears to be an intermittant 'creaking' sound coming from I think the front windscreen. I think I ...
Old 28th March 2008, 19:11   1 links from elsewhere to this Post. Click to view. #1 (permalink)
Ferny's Avatar
I have what appears to be an intermittant 'creaking' sound coming from I think the front windscreen. I think I have read somewhere on Civinfo that there is some kind of modification to the rubber seal, but I cant seem to find it.
I have a EX 1.8 56 plate, registered in Jan 2007, anybody got any ideas.
Ferny is offline   Reply With Quote
Old 28th March 2008, 19:47   #2 (permalink)
What helped with mine was a "lift" of the cowl on small felt pads and (after cleaning) sealing with silicone, there are other ways too that work, look here
How To - Fix The Windscreen Cowl creaks.
or here
Dashboard squeak noise :-(
Good luck
Old 30th March 2008, 16:26   #3 (permalink)
Ferny's Avatar
Thanks for that civicfan.
I will give it a go when the weather improves.
Has this modification cured your car ?
Old 30th March 2008, 16:49   #4 (permalink)
brawnr's Avatar
It cured mine
brawnr is offline   Reply With Quote
Old 30th March 2008, 18:11   #5 (permalink)
Yes - but it isn't quite that easy to do. You must be particularly careful not to smear your windscreen with silicone, it's damn hard to remove once it's solid. It is also important to lift the cowl on the felt pad supports, to get enough gap to allow for cleaning before applying the stuff. Good luck
Oh, after cleaning / drying you can apply the silicone, leaving the felt pads in place (that's why it's better to use dark ones) - if you remove them the gap will be too flat for the fix to work, mine was about 4 mm
Old 30th March 2008, 22:42   #6 (permalink)
Type R GT 09570
It has cured mine.
Old 31st March 2008, 10:48   #7 (permalink)
Ferny's Avatar
Civicfan, what sort of silicon did you use was it a silicon glue or a silicon filler
Old 2nd April 2008, 11:22   #8 (permalink)
Bikec_4's Avatar
go to a carglass company or something like that..let they do the work..you'll just mess it up...my father owns that kind of company here in slovenia for 20 years and we have a lot of problems with people who stick those kind of plastics on them self with bad silicons,thinking that they will actually repair it...
belive me you can make it worse
Bikec_4 is offline   Reply With Quote
Old 2nd April 2008, 21:38   #9 (permalink)
Clear silicone glue/gasket "pistol" from Obi (Germany) I don't know the manufacturer any more, it was quite cheap some 3€ per piece (about 500 g). I don't think it can make the glass crack because it does not harden completely but stays elastic. My fear was it will weather badly, but until now, all is well (though I would make it a cleaner job if I were not too lazy to tape up the windshield first)
Old 2nd April 2008, 21:46   #10 (permalink)
Wink Creaking Windscreen
I have exactly the same problem. I took the car back to Honda and they will be taking the car in for a day under warranty to complete the work. They told me there has been a problem with the plastic clips on top of the screen combined with the bonding! I will let you know if it works...
Neil is offline   Reply With Quote
Old 3rd April 2008, 09:08   #11 (permalink)
peterdh's Avatar
My 06 creaked and groaned when I bought it second hand last year. The dealer had a listen and immediately booked it in under warranty. They said it was something to do with the foam it sat on and the screen would need to come out and be replaced. New screen standing by in case it broke when they took it out. I think they got it out without breaking it. Not a sound since then. Bliss!
peterdh is offline   Reply With Quote
Old 4th April 2008, 08:28   #12 (permalink)
Ferny's Avatar
Have done the modification, it works a treat. No more creaking and grinding noises from the windscreen now, but I still have a few from other places. But I can live with them.
Old 14th April 2008, 15:10   #13 (permalink)
Hello guys... I have a 08 2.0 Si Coupe and I have the same problem. I am wondering if any of you guys have had a permanent fix yet from your Honda dealer?
I am afraid my Honda dealer will not be able to fix and that I have to do the DIY method...
Ghetto2315 is offline   Reply With Quote
Old 14th April 2008, 16:05   #14 (permalink)
Ferny's Avatar
Hi Ghetto2315
I think Honda have a fix for this over here in the UK , but if you follow these instructions you can't go wrong, (see link)
How To - Fix The Windscreen Cowl creaks. Thanks to Munro for this.
This is assuming a Honda SI Coupe has the same cowl arrangement that the Honda Civic has.
This modification certainly worked on mine
Old 14th April 2008, 19:54   #15 (permalink)
Hi Ghetto2315
I am aware of the DIY fix, but what I am really after is my local Honda dealership here in the states to fix this so it NEVER comes back. Some how I think the DIY fix in the link is just a temporary fix and the creaks will come back eventually.
Can anyone find out from the Honda UK dealers how they are going about fixing this problem ... maybe I can relay this to my US dealer.
Old 26th April 2008, 09:03   #16 (permalink)
daiashthomas's Avatar
my local dealer has been told about this method and is awaiting feedback from me and couple others before he can pass on the info to honda uk i think
daiashthomas is offline   Reply With Quote
Old 29th April 2008, 01:57   #17 (permalink)
djm
My local dealer has just "fixed" this problem - ie made it worse. They're gonna think I'm some kind of car hypochondriac but my Civic seems to develop a new fault every 2 weeks!
djm is offline   Reply With Quote
Old 29th April 2008, 07:20   #18 (permalink)
Type S GT
The proven route to a Ford Focus then....
Sorry TC..
Couldnt resist
Have you showed them the DIY method fix?
LinkBack to this Thread: http://www.civinfo.com/forum/bugs-faults-irritations/12951-creaking-windscreen.html
Creaking in my 08 Si Coupe... Driving me crazy! - 8th Generation Honda Civic Forum This thread Refback 16th April 2008 21:15
Similar Threads for: Creaking windscreen ??
Transmission Creaking gear change Topcat Bugs, faults and irritations 20 7th August 2007 08:38
Suspension Creaking Rear! alloallo Bugs, faults and irritations 47 8th July 2007 23:21
Creaking Civic chris rowden Introduce yourself 5 8th June 2007 07:23
Windscreen Kremmen Cleaning and Styling 6 15th April 2007 14:31
Squeaks Creaking trim around the back doors.... Cheltenhamshire Bugs, faults and irritations 15 29th September 2006 21:25
