| This thread is about: Loose Tweeters, it's in Bugs, faults and irritations at the Honda Civic forum Civinfo; For a little while now, I've been hearing a rattle (kind of a tick-tick) noise when hitting potholes or manhole covers. I though originally it ... | ||
We call him... The Stig
Loose Tweeters
I though originally it was the windscreen cowl, so did Munro's fix with the cushion tape, but the sound was still there. However, I discovered last night that both tweeters were somewhat loose in their casing - if you put your thumb on them you could rotate them about 1 mm - they also rattled a bit if you tapped them. So, I took both tweeter housings off, undid the cables, and removed the tweeters from the housing. I then wrapped some insulating tape around the edge of the tweeter mount so that when they were pushed back in they more of a tight fit. Certainly seems to have done the trick, as when driving through town tonight and deliberately seeking out manhole covers and small potholes there was no more rattly/ticking noise. The place where I wrapped the tape is highlighted in green in the enclosed photo of the removed tweeter - not easy to photograph a black plastic thing sitting on a black seat, with black tape wrapped round it Tweeter.jpg |
You need to remove the black plastic triangles from the door frame first. Then there are two clips on the back which need pressed to release the speaker.
Although the speakers are loose I don't think they are loose enough to be removed from the front. |
| Speakers Tweeters in the door | DingBat | Ipods, MP3 Players and ICE | 10 | 10th December 2007 13:16 |
| Loose Change the final cut | illegalhunter | Any non Civic chat here please! | 2 | 6th December 2007 20:37 |
| Door cover for tweeters | DingBat | John Pease Honda | 1 | 30th August 2007 09:46 |
| Music Problems with Radio 1 through tweeters | Ham'sCivic | Bugs, faults and irritations | 8 | 22nd June 2007 14:12 |
| Fog loose fog light | bezz | Lights | 3 | 14th March 2007 12:26 |
