| This thread is about: Droning/Roaring Noise & Refuelling, it's in Bugs, faults and irritations at the Honda Civic forum Civinfo; Hi all. Please go easy on me - I'm a newbie both to Civic ownership and the forum (which is great by the way). Purchased ... | ||
Hi all.
Please go easy on me - I'm a newbie both to Civic ownership and the forum (which is great by the way). Purchased a 2005 CTDi Sport with 26.5k privately 2 days ago and have a couple of questions: 1. There is a roaring/droning noise from the rear of the vehicle between around 30-55mph (no, it's not the wife or kids!). I'm not mechanically gifted but could it be a wheel bearing perhaps? 2. Refilled for the first time today and found it impossible to avoid the fuel kicking back and cutting the flow from the pump, however I angled the nozzle. Does anyone have the same problem and a solution? I have taken the time to search these two issues on the forum with no luck, so sorry if it's old ground. Cheers |
S29 AWS
Hey Glepor - 1st of all welcome - good choice - that's under average mileage for a 3 year old car - well found!
Your problems... not sure about the 1st - the 2nd one - was this only at one garage? Could have just been a rubbish pump! Someone here will know about the 1st problem. |
Yes, I'm rather chuffed with myself!
Only one garage so far, the reason I mentioned though is that I used the same garage for my last car & never had the problem. Also the last owner of my Civic said she had the same problem. |
#4 (permalink) | |
Have the allignment/suspension checked, and the wheel balance. The tyres on our car were very much worn on the inside, having little wear on the outside (I believe this is called uneaven wear). Due to the fact this was on the inside it was hard to see. The problem was caused by a certain rod or something which was worn/bend Oh yes, the higher the speed, the louder the droning (more wind blew past the rear tyres, strengthening the sound) 2 reminds me of our '96 civic. Putting the nozzle too deep caused cutting because the pump was too powerful for the car to 'swallow' it. Never had this problem with the CTDI except on one occurrence: I tanked with the nozzle for lorries (which, obviously, is bigger) Last edited by Jeroen1000; 10th April 2008 at 14:26. |
So I finally found out what the droning noise from the back of my car was. Took it to have the rear wheels balanced this morning, thinking that's what it might be. Guy didn't even need to take the wheels off to diagnose the problem. Both rear tyres are "stepped" or "feathered", on the inside inch or so. Apparently, this means that they are wearing in a sort of undulating pattern which accounts for the vibration when on the move. I asked if this was indicative of a mechanical fault somewhere and he said it was more likely to be because of crap tyres. Went to another place for a 2nd opinion and he confirmed the feathering. He said that on a car with 40k miles plus he might think that the shockers were to blame, but at 27k thought it unlikely. So now I have a dilemma. Do I take it to a dealer (it's still under warranty) and ask them to check for an underlying cause? If they don't find anything, will I get charged for the time they spend investigating? If they do find a mechanical reason, where do I stand re compensation for 2 replacement tyres? If it is just the tyres, is it worth taking it up with the manufacturer? There is still loads of tread on both, so it's a real stinger to have to buy 2 replacements, especially if the same thing might happen again. Finally, if I stick with the tyres and put up with the noise until they need replacing due to low tread, is it likely to damage anything else?
| Noise under braking? | Rocko | Type-R | 23 | 8th April 2008 07:18 |
| Scraping noise | apapageo | General Discussion | 4 | 8th March 2008 19:45 |
| AC/Heater Air Con noise | rogie | Bugs, faults and irritations | 6 | 23rd April 2007 20:16 |
| Wind noise | glen666 | Wiki Article Discussion | 2 | 11th April 2007 14:27 |
| Faults Engine noise! | gs7776 | Engines and Transmission | 7 | 25th February 2007 16:09 |
