This thread is about: A single knock on 'take off', it's in Bugs, faults and irritations at the Honda Civic forum Civinfo; I think you are correct, it may be coming from the brakes. Since day one I've notice that the brakes tend to stick alittle, and ...
Old 24th April 2008, 12:08   #21 (permalink)
cnicolini's Avatar
I think you are correct, it may be coming from the brakes. Since day one I've notice that the brakes tend to stick alittle, and its worse after you have washed the car and have left it all night. You can hear a clonk when you first move off. Mind you it does not keep reocurring after that!
Old 24th April 2008, 13:30   #22 (permalink)
GHGH's Avatar
Also experience a clonk at similar conditions as cnicolini.
Old 24th April 2008, 15:40   #23 (permalink)
cnicolini's Avatar
The hand brake must be sticking and not releasing properly, hopefully they will fix this when the car is next serviced as they should check the brakes!
Old 25th April 2008, 09:18   #24 (permalink)
Most amusing: No knock if you pull it up properly and release in < 10 degrees. A knock when the handbrake has been released for several hours in temps over 10 degrees. So it starts sticking when you don't pull it up and leave it for a while
Bear in mind I have only tested pulling it up and leaving it outside under 10 degrees. Still on the list: pulled up handbrake inside. Released handbrake outside
Old 25th April 2008, 09:49   #25 (permalink)
Type S GT
If you can leave it on flat ground in gear, then start off as normal in the morning, this should test whether its the handbrake. I cant, as my drive is sloping
Old 12th June 2008, 09:30   #26 (permalink)
Well now, I've finally tested this as I could leave my car at friends. And it does the single knock thing on take off under following conditions:
Car in gear on flat ground. Handbrake NOT pulled up
+ 10° temps outside
Knock occurred at +- 17-18 km/hour.
This has been tested in order to rule out handbrake issues.
Because I'm currently in a dispute with the dealers I can't have it checked anytime soon. Has anyone been able to resolve the issue?
@relaxmax. Whether the car is in gear or not, is irrelevant to the issue. It's just to prevent the car from rolling away. You might as well lay a brick behind one of the wheels. Also note it only happens once on take off.
Old 12th June 2008, 09:33   #27 (permalink)
relaxmax's Avatar
I get the knock irrespective of gear/neutral (I have an i-Shift). Time to park without the handbrake and see what happens...
relaxmax is offline   Reply With Quote
Old 12th June 2008, 09:40   #28 (permalink)
streakybird's Avatar
I have the exact same thing... like people have already mentioned, i have grown used to it.
It does very much sound like its coming from the front drivers side. Its pretty much one clicky sound and thats it. Im not bothered by it, i kinda expect it now and if i dont hear it, worry why??? lol
Good to know that its not just mine then
Old 16th June 2008, 12:19   #29 (permalink)
small update as to what may be the cause
Anyone ever heared of VSA performing a 'break test' after the car has stood still for a while?
Maybe a good idea for a poll
Old 16th June 2008, 13:09   #30 (permalink)
relaxmax's Avatar
You mean "brake test" ! Nope, never heard of it. But as you say, it could very well explain the knock.
Lets try accelerating gently with the left foot slightly on the brake, and see if we feel anything on the left foot
Old 16th June 2008, 13:20   #31 (permalink)
Yes that's the one
I was advised to turn off the VSA. We could try both
Similar Threads for: A single knock on 'take off'
knock knock TTDegs Any non Civic chat here please! 22 29th March 2008 19:50
Head Unit Single Din Conversion .. SteveTDCi Ipods, MP3 Players and ICE 16 30th October 2007 13:37
Brakes Knock/Tap when braking leodis41 Wheels, Tyres, Suspension and Brakes 28 17th October 2007 16:20
Fuel Knock? Knock? - ECU The Phantom Engines and Transmission 3 15th May 2007 12:40
Interior Single Courtesy Light philosoma Lights 1 13th April 2007 23:09
