This thread is about: List of faults reported to my dealer, it's in Bugs, faults and irritations at the Honda Civic forum Civinfo; My Pride and Joy is in for some check ups tomorrow.(tues) Heres the list of issues i have reported to the Dealer: 1, Loud whining ...
Old 21st April 2008, 19:54   #1 (permalink)
Type R-GT, R-11859
ctrdaveg's Avatar
Post List of faults reported to my dealer
1, Loud whining noise from the Fan Belt Pulleys
2, Knocking rear suspension when cold and mainly when reversing
3, Front windows rattle when open a couple of inches, irritating clicking noise
4, Popping noise from the speakers when the radio, cd or ipod is playing. Sounds like interference, static, or loose connections.
Lets see what has been rectified when i get it back.
I've got a FR-V courtesy car for the day, picked it up earlier. They have impressed me up to now. I'm very impressed with the FR-V
Old 22nd April 2008, 13:29   #2 (permalink)
Type R-GT, R-11859
ctrdaveg's Avatar
So far no good.
The dealer has had the car since 4.45pm last night and just called to say they can't find anything for items 1, 2 or 4.
For item 3 they are going to try new window seals to see if that works.
I must admit item 4 hapens when the radio has been on for some time but does it all the time when it starts.
Old 22nd April 2008, 13:56   #3 (permalink)
Originally Posted by ctrdaveg View Post
So far no good.
1 is normal I believe. You do have a CTR, I suppose?
under 3000rmp I don't really hear the whinning anymore. I've also raised this issue and I can only conclude it's normal. How many miles do you have? I tend to think it gets better or I get used to it.
Old 22nd April 2008, 14:09   #4 (permalink)
Type S GT
#2. Is well documented and is apparantly a 'characteritic'!!
I'll be having a word about this when mine is serviced
Old 22nd April 2008, 14:17   #5 (permalink)
meek's Avatar
I have had the same issues with #2 & #3 though mine is a TYPE S 1.8, i asked about the rear knocking noise, and the dealers and other people i know who have worked for honda say that when the handbrake has been applied for a long time (Overnight) its sticks - though after a couple of seconds of driving it goes ! #3 is very annoying as well, i've only noticed since i had to have my driver side window seal replaced (as was leaking!)
meek is offline   Reply With Quote
Old 22nd April 2008, 14:24   #6 (permalink)
Type S GT
Its definately not the handbrake
Old 22nd April 2008, 20:24   #7 (permalink)
Type R-GT, R-11859
ctrdaveg's Avatar
Update now i have my car back
#1, the dealer can't find it or hear it. As soon as i got it home it started again. I'll leave it for a few days and then see how it goes.
#2, no action dealer said they've checked the suspension and is fine. Must be true what "Robbo51" has quoted.
#3, Cured. They said they have replaced the window rubbers and guides.
#4, Typical this never happened for them even when i told them to leave the radio on for at least half an hour. Seems like it only does it for me
I'll have to drive straight to the dealers the next time it starts. They said they have checked all the speakers for any bad or loose connections so time will tell.
Their attitude was and i quote " you've got plenty of time left on your warranty so if it gets worse just bring it back"
Not what i wanted to hear
original list of issues.
Old 22nd April 2008, 20:28   #8 (permalink)
Topcat's Avatar
[quote=ctrdaveg;174306I'll have to drive straight to the dealers the next time it starts. [/quote]
Thats what I always had to do with all my faults - I was always popping in an out made some good friends though
Old 2nd June 2008, 14:46   #9 (permalink)
jont122's Avatar
Have noticed item 3, on my car when you put either or both windows down an inch or two?
Very annoying metallic rattle noise, must take it into my dealers when I can?
jont122 is offline   Reply With Quote
Old 2nd June 2008, 15:26   #10 (permalink)
The speaker cones areworth about 10p each thats why they poping
Old 2nd June 2008, 16:10   #11 (permalink)
R-2
R-10581
R-2's Avatar
I also have had the whining noise as per your problem #1. Jeroen1000's similar experience was discussed here.
Engine sound question
The noise only ever seemed really noticable before the engine had warmed up.
I have now done well over 4000 miles and rarely get the whining sound anymore. Its not that i have got used to it.
I think this was also described as a "feature" of the car by Jeroens dealer
However i will mention it when i get my car serviced if it has not completely disappeared (along with the 3rd gear issue which also seems to have improved)
R-2 is online now   Reply With Quote
Old 2nd June 2008, 18:32   #12 (permalink)
ADE Type S's Avatar
what dealer did you take it to dave? stuart graham?? because ive gotta get mine booked in for the hand brake fix soon and have a few other little issues i want sorting out.
ADE Type S is online now   Reply With Quote
Old 17th July 2008, 10:41   #13 (permalink)
jont122's Avatar
Had drivers door seal replaced (as it was split at the top corner) but both windows still rattle. Was told all Type R's do this? as the doors are stripped out for the sports model!!!!
Old 24th July 2008, 23:14   #14 (permalink)
ANDICIV's Avatar
have had item 2 which has been reported to dealer several occasions. they say they have re greased rear suspension, but it is common fault, apparently the oil in the shocker rises when standing and the shocker bottoms out for short while until oil returns, (emmmm not convinced). knocking seems to be getting more frequent and lasting longer.
ANDICIV is offline   Reply With Quote
Similar Threads for: List of faults reported to my dealer
Dealers Main Dealer - Totally Oblivious to Common Faults ciderman4 Bugs, faults and irritations 35 12th September 2007 13:31
Long list faults faults faults pffffff meesterlijk Bugs, faults and irritations 77 2nd April 2007 09:39
Long list Long list of problems - finally got round to talking to dealer richierich Bugs, faults and irritations 11 12th March 2007 21:34
Long list List of faults I gave to dealer Fedorov Bugs, faults and irritations 24 4th January 2007 02:08
Long list List of faults pcr Bugs, faults and irritations 24 28th December 2006 22:59
