| This thread is about: [Suspension] URGENT: Defect on Civic Safety Critical Part, it's in Bugs, faults and irritations at the Honda Civic forum Civinfo; Sounds reasonasble to me. Anyway, VOSA are looking into it now. Something has to come out of this investigation, and then we'll know.... | ||
LinkBack (1) | Thread Tools | Search this Thread | Display Modes |
#82 (permalink) | |
Trouble is,the nut might have to be removed to get at the spindle thread. |
#84 (permalink) | ||
Which means (to me) that each person's level of panic should depend on who you want to believe. On one hand we have FEMA, with his statement that the wheel spindles are undersized. On the other hand we have VOSA saying no action required. And in case you have a hand spare still, Honda are saying that all parts are within their spec. Honda are saying VOSA are investigating, FMEA saying they are not (anymore). |
#85 (permalink) | |
So, it's left in the hands of VOSA and Honda. Honda you hope would be long-term enough to recall products if there was a safety issue, but you also have to accept that there is a slight conflict of interest here and they have to manage both the technical and PR risk. So, back to VOSA, which has no such conflicts.... If you believe either that VOSA aren't truly independent and/or are corrupt in some way, you worry about this. Otherwise, you have to trust that they're dealing with the matter in a competent way, pending further "evidence". FMEA, if you're still reading this, what evidence do you have that this is a safety risk? Courant |
#87 (permalink) | |
Wine and cooking !
Standard
#88 (permalink) |
#89 (permalink) |
I’ve read the original post several times and something doesn’t feel right.
Anyway, I’m an Avionics engineer and my knowledge on effects of an incorrect thread tolerance is a little limited, BUT I do work in an office with a bunch of structure geeks. So I asked them what the effects would be? If the tolerance was too much for the "spindle" it would strip the thread when tightening(I assume your talking about the rear axel stub, spindles are on bikes). If the tolerance is acceptable then problems would only develope during the maintenance of the part (i.e. removal and re-attachment). Take from that what you will, I personally are very suspicious of those that make claims with out giving background information. Last edited by Duecut : 23rd April 2008 at 14:29. Reason: typo |
#90 (permalink) |
Here is a question to think about;
After the production of the first 4,521 civics why did Honda change this part? If there was no problem surely they would have continued to use it. |
#92 (permalink) |
TC, it's quite conceivable that the OEM supplied it incorrectly for the first batch, or Honda made a mistake in ordering the first batch - but either way if you re-do the design calculations on the dimensions of the first batch it's found to be still within all the design and legal requirements for the job in hand.
#93 (permalink) |
Just as a little aside to the whole thing...
As well as the actual tightness of the nut on the bolt, there is also a 'stake' which prevents the nut from undoing itself. Which I guess comes under the heading of 'extra safety built in' |
#94 (permalink) | |
Anyway they say their paint thickness is within the specified requirements but many of know us know that it is not true with some civics. |
#95 (permalink) | |
Newton Honda
It's quite conceivable that the first batch of parts were exactly that, the first batch and that the company that manufactured them, then manufactured the next batch at a slightly different set of tollerances. At some stage it has become apparent that these initial measurements may or may not have been correct..... |
#96 (permalink) |
It is indeed keyed:
hub.gif The more I think about this, the more it smells:
Bolt tolerance allegation causes no incidents in Honda's new Civic! |
#97 (permalink) |
I'm with the general consensus. My car has an almost certain chance of being affected, however as an aeronautical (aerodynamics) engineer myself, I am completely happy with it. This is because all load bearing parts are always designed to have significant safety margins. As Pottsy very correctly points out, normal practice would mean Honda probably (and am I very certain they would have) ran the numbers again and found all this meant is the safety factor is smaller than the design safety factor. In the real world these things happen all the time.
TC- why did they change it, well when someone spotted this problem, they would have stopped using it! They would have gone back to the original design and check if this part was fine. The fact that this claim only affects 4500 cars simply means the problem was known about early on and should give us all reassurance! I am not comfortable with the dramatic nature of the original post which almost tries to over impress us with some technical knowledge. I have suspicions this has connections to lowering our cars retail value. I hope the media doesn't dramatically make this out to be worse than it is, especially since none of us have heard about any cases of wheels falling of our car model! Now, I sit back and eagerly wait for this dramatic 'evidence' |
#99 (permalink) | |
I am not aware that the 8 gen Civic has rear wheel steer so perhaps at best this is a hotchpotch of different comments. At worst it is slander....... |
#100 (permalink) |
Alan - I think he might be referring the the affect on the steering of the car should you suddenly find yourself a wheel short
Which doesn't mean I'm condoning the assumption that the wheel is going to fall off in the first place |
| Sponsored Links | |
Advertisement |
LinkBack to this Thread: http://www.civinfo.com/forum/bugs-faults-irritations/13637-suspension-urgent-defect-civic-safety-critical-part.html
| Zusammenfassung der FK-Mängel : Honda Civic FK, FN, FD | This thread | Refback | 23rd April 2008 09:50 | |
Similar Threads for: [Suspension] URGENT: Defect on Civic Safety Critical Part
| New Civic in Finland, part 2 | repales | Gallery | 11 | 14th January 2008 18:42 |
| New safety rate for Civic 2008! (Euroncap test) | Humano | General Discussion | 15 | 24th December 2007 00:49 |
| Urgent help required for new Civic buyer. | garbfink | Buying, Dealers and Servicing | 20 | 24th November 2007 11:57 |
| Help! Urgent | sexykungfufighter | Bugs, faults and irritations | 17 | 28th May 2007 21:38 |
| CiViC Safety | SqueakyWD40 | General Discussion | 33 | 8th December 2006 17:52 |
