This thread is about: Instrument cowling squeek cure?, it's in Bugs, faults and irritations at the Honda Civic forum Civinfo; My car is a Type S. Whilst driving along the panel creaks when on uneven surfaces ( that will be most of the time then). ...
Old 24th April 2008, 20:56   #1 (permalink)
My car is a Type S. Whilst driving along the panel creaks when on uneven surfaces ( that will be most of the time then). If I put my hand on the smooth lip that surrounds the instrument binnacle and put firm pressure on it stops. When static the same area can be made to creak if pushed up and down.
Looks like it needs tightening or something place between the two surfaces. Can anyone tell me how I get to the fixings as I can be bothered putting the car in again as its already started talking Aborigine
PWOOD is offline   Reply With Quote
Old 24th April 2008, 21:15   #2 (permalink)
Vivid Blue Rocks!!!
Foggy69's Avatar
Instructions on how to remove the fascia are in this thread
Replace the fascia with the Type R glare and scratch free one
As described in the thread, there is some anti rattle velvet that might need repositioning.
Old 24th April 2008, 22:37   #3 (permalink)
Could be worth a try: I silenced mine with silicone (spray inside and solid outside) - described in several loc. on Civinfo. At least in my case, there was no need to dismantle anything.
Old 25th April 2008, 11:20   #4 (permalink)
Thanks guys.
Old 25th April 2008, 11:44   #5 (permalink)
morten's Avatar
When I complained about creeks in the dash to the dealer, they removed the cowling and added a certain type of foam in the joint before reattaching it. Been silent ever since, at least in that area of the car...
morten is offline   Reply With Quote
Similar Threads for: Instrument cowling squeek cure?
Squeaks Squeek above drivers door? Jani Bugs, faults and irritations 12 13th July 2007 17:23
Squeaks Roof liner squeek solved Stef Bugs, faults and irritations 17 13th May 2007 23:37
Cure for bird flu? Jobo Any non Civic chat here please! 2 11th February 2007 12:50
Automation Instrument backlighting - autodimming wish NickG Electronics 6 5th February 2007 09:37
Other my instrument panel looks like this! normal or not???? nstergi Electronics 9 6th August 2006 09:09
