| This thread is about: Gearbox on i-CTDi Notchy, it's in Bugs, faults and irritations at the Honda Civic forum Civinfo; The gearbox on my Civic has been rather notchy and stiff from when I picked it up are they all like this as I can't ... | ||
make sure the clutch is fully disengaged. The travel is much greater than on my previos car, which resulted in a couple of grinds and difficult gear selections to start off with.
Hello Tydo. The gearbox is one of the best features of the Civic. Changing should be very easy.
If its notchy or stiff, go back to the Dealer , and let them check it. |
Mine's fine too
The demo was (from memory) not 'sprung' properly - I kept getting 5th instead of 3rd - but I've only done that once on mine Take it in and let them have a look |
I still have complaints about mine, you may recall from previous posts the reason i had a replcement car was because of gear change problems I was experiencing. On this new car I have intermittent days (few and far between) where the gears are stiff, notchy and slip in to the wrong gears, esp 2nd to 3rd!
2nd to 3rd can be iffy - sometimes when snatching the gears, y ou can hit the "gate between 1st and 3rd. Gentler hands stops this happening.
Also - I've driven quite a few civics now, with various mileage, and the gearbox does soften a bit after a few thousand miles. |
No complaints here re the gear change. A bit notchy going into first when it is cold but smooth as silk through the rest of the gears the rest of the time.
#11 (permalink) | |
12th June 2006 1.8EX
| Gearbox, Enginestart .. any Problems? | siam | Type-R | 8 | 5th May 2008 07:46 |
| Oil Which Oil in your 2.2 CTDi? | Hartside | Engines and Transmission | 86 | 18th February 2008 07:17 |
| Transmission Gearbox - Type R 3rd gear | eddie1010 | Bugs, faults and irritations | 3 | 23rd October 2007 12:48 |
| Transmission closer gearbox for civic '07 1.8 5d | Roukounas | Engines and Transmission | 0 | 23rd September 2007 15:48 |
| Tech i-CTDi | SUPERTEACH | Engines and Transmission | 10 | 26th October 2006 12:43 |
