| This thread is about: Fuel Filler Cap, it's in Bugs, faults and irritations at the Honda Civic forum Civinfo; Just have the filler cap replaced by your Dealer. Mine is fine now. It is under warranty you know !!.... | ||
#142 (permalink) |
Old enough to know better
Fuel cap bodge again
My dealer gave me a piece of foam to fit and showed me where to fit as it was pouring with rain.
It lasted one fill and now sticks the fuel cap shut. I can fiddle it open though as before by pushing on the cable physically. Will tell my dealer to come up with a permanent fix. Tony |
#143 (permalink) |
estranged
Had mine done by the ever efficient Southern Counties Honda the other day... works a treat now (looks around wildly for some wood to touch).
#144 (permalink) |
I had the fuel flap fixed three times but it only lasted a short time, the dealer then replaced it. It seems the only permanent fix as it now works first time every time !
#145 (permalink) |
Filler Cap
Sorry about the delay re. the pic of the fillercap mod well nothing to show just looks the same as it always did ..Any way stuck again last week I think the problem could be the cable stretching any views on this theory
lennie |
#147 (permalink) |
fillercap
Hi' ALl56 thanks for the feedback will try anything once will have a sort out in the morning will also try the gentle pull as well as suggested watch this space a they say
Lennie |
#148 (permalink) | |
Fallen Angel
Oh the gentle pull works like a dream!!! Was getting annoyed as ever after the umpteenth time of yanking on the lever.....decided i'd give it a try and it worked first time |
#149 (permalink) |
Why dont they just bite the bullet and give us a decent metal cap, rather than a cheap nasty plastic one... with a proper spring release mechanism, rather than a poorly made, low quality excuse for a catch...
Rant over. |
#150 (permalink) |
Still annoying me and still embarassing to have people look at the car then look at me looking silly trying to get the damn thing open.
#151 (permalink) |
Hi,dealer fitted a new spring,seems to have done the trick.
What I did before problem was fixed was to get the cap open before going to the petrol station,saves you looking like an idiot when you get there.Best of luck. |
#152 (permalink) |
Hi, I think I've solved my filler cap problems as follows.
No matter how I pulled the cable - gently, quickly, pushing down on the cable behind the lever, etc. - there was always the chance that cap would not open. The catch always disengaged, but the spring by the hinge is too weak to always push out the flap. I haven't been able to remove the flap from its hinge and tweak the spring, so have opted for what seems a simpler and fairly infallible alternative. I got some foam tubing that is used to lag 15mm water pipes. This comes in 1 metre lengths from DIY shops and is very cheap (e.g. 5 metres for £2 at Wickes). With a sharp knife I cut a short length of around 3 inches and then removed a segment of around 90 degrees, (see photo), which takes less than a minute. This then fits snugly on the inner fuel cap, which should be rotated until "horizontal". When the flap is closed the foam fits neatly into its curved inner surface, (see other photo). And the foam is squashed enough to always ping the flap open when you pull the lever. The foam can be removed temporarily when at the pump, so doesn't get in the way of anything. If it gets lost or loses its flexibility, you've got enough left out from 5 metres of insulation to make about another 60 at around 3p each. I hope this suggestion is of help to someone else. Wilson, Brighton. |
#155 (permalink) |
Filler Cap
Well took it back to the dealer today told him the mod they did is no good as it stuck on sat. in the garage ah said he there is now a mod for the mod going in on weds. for the mod mod the saga continues does it not so watch this space again
lennie |
#157 (permalink) |
Wilson, that is a good temporary solution. I suggest that you could have fixed the polyethylene foam piece onto the lid inside (where it writes "diesel") by a double-sided sticky tape (it would be cut like a slab this time). Then you wouldn't have to remove and put on the foam piece every time you handled the cap. Just a suggestion...
#158 (permalink) |
I've had the foam 'mod' done, and it did.......absolutely nothing - still refused to open whilst at the BP station about 2 days after having it done
I'll dmand that they sort it properly (replace it) when I get back from the UK in January. |
#160 (permalink) |
Mine's been in 3 times - last time was replacement which still didn't help. I've found a variation on the 'gentle pull' approach which seems to work for me. Before opening the door, I pull the lever out and keep it there. After some time (seconds), I hear a muffled click from the fuel cap area. The flap is now open. It's worked about 8 times in a row so far (more frantic wood touching!)
| Recalls Fuel Filler cap ... again ? | l-noel | Bugs, faults and irritations | 20 | 17th September 2007 22:32 |
| Fuel New fuel filler cap mod from Honda | Pottsy | Bugs, faults and irritations | 80 | 4th April 2007 16:14 |
| Fuel Fuel Filler Fix | moff | Bugs, faults and irritations | 46 | 16th March 2007 19:45 |
| Fuel Filler Cap | rogwat48 | Recycle Bin | 3 | 15th November 2006 21:43 |
