This thread is about: Noise at low RPM, it's in Bugs, faults and irritations at the Honda Civic forum Civinfo; I have Civic 1.8S Petrol, Manual Transmission. I am hearing "tak tak" noise from under the bonnet. This noise is audible when the rpm goes ...
Old 4th June 2008, 03:08   #1 (permalink)
laluks's Avatar
Noise at low RPM
I am hearing "tak tak" noise from under the bonnet. This noise is audible when the rpm goes above 1000 and is noticeable till 1500 -2000, after that the engine noise is prominent. The frequency of the "tak tak" increases with RPM.
I took it to the dealer, they say its a small engine knock in the lowest RPM, and asked me to drive around and not to worry...I do not trust that fully. Any suggestions?
This started after the 15k service an change of engine oil.
laluks is offline   Reply With Quote
Old 4th June 2008, 05:58   #2 (permalink)
gm1980's Avatar
It is propably the valve's hydraulics. What type of oil they used on service? The noise might propably go away aftersome miles of driving but is it continues I thing you have to visit the dealer becasue if the problem is the hydraulics then migh cause more problems in the future.
gm1980 is online now   Reply With Quote
Old 4th June 2008, 09:20   #3 (permalink)
laluks's Avatar
The dealer said they have used Honda approved Engine oil.
Do you think this can also be due to the fuel also? I have now run 200km after the service. The sound still persists.
Old 4th June 2008, 09:31   #4 (permalink)
pcr
pcr's Avatar
There is a part fixed to the back of the throttle assembly that I can hear making that sort of noise, but it is only noticable when say driving slowly in second gear.
If you are up to it, the use of a long screwdriver as a sound probe is really quite good at tracing these sort of things, but be aware of the dangers.
Old 4th June 2008, 11:21   #5 (permalink)
laluks's Avatar
Exactly. I hear this noise only when moving very slowly in 1st / 2nd gear. Also I noticed that from 0 to 1000rpm this sound is not there..(may be very feeble) but once it crosses 1000rpm it is very much noticeable till 2000rpm, the ticking frequency increases with rpm. But above 2000 I cannot hear it because of engine, probably it is still there.....
The vehicle is doing fine except for this. I am bit worried whether this is the beginning of a serious issue. The dealer said its ok..I do not want to trust that
Old 4th June 2008, 11:23   #6 (permalink)
laluks's Avatar
You have already scared me What exactly is the technique? This is just to know..I'm not inclined to try
Old 4th June 2008, 11:35   #7 (permalink)
pcr
pcr's Avatar
Take a long (say 10 - 12 inch) thin screwdriver, hold it with the blade touching the part you want to listen to and the handle to your ear. Sounds rubbish but works well.
The danger is inadvertently getting the screwdriver or your hair caught in a moving part, especially the belt or pulleys.
Old 22nd June 2008, 04:33   #8 (permalink)
laluks's Avatar
I left the car with the dealer last wednesday. Yesterday they called up to say they have identified the source of the sound. The belt of the power steering pump, has worn out and seems to be the problem. They said they will replace that under warranty....hope the issue is only that...
But a serious cause to worry, the car is just 1 year and has done around 13500km...how can nthe belt just get worn out...Is there anything strange to be looked at? some alignments, etc...
Also I do not know the results after they had changed the belt...I'll get the details only on Monday...
Guys, please let me know what you think.....
Old 26th June 2008, 06:14   #9 (permalink)
laluks's Avatar
Dealer changed the power steering pump belt. The noise is gone, the vehicle is doing great...
The problem was 2006 model belt which was wrongly used in 2007 model car. Mine was the first instance....
Replaced under warranty...Everything fine touch wood...
Similar Threads for: Noise at low RPM
Suspension Strange noise tongie Bugs, faults and irritations 10 2nd July 2008 17:43
Steering Grinding noise. czechplastik Bugs, faults and irritations 7 23rd June 2008 20:40
Scraping noise apapageo General Discussion 4 8th March 2008 18:45
AC/Heater Air Con noise rogie Bugs, faults and irritations 6 23rd April 2007 20:16
Wind noise glen666 Wiki Article Discussion 2 11th April 2007 14:27
