This thread is about: Knocking at rear......possible solution, it's in Bugs, faults and irritations at the Honda Civic forum Civinfo; Having read all the posts about knocking from the rear, I wasn't surprised to discover that I had the same problem on my 12 day ...
Old 6th June 2008, 19:24   #1 (permalink)
Having read all the posts about knocking from the rear, I wasn't surprised to discover that I had the same problem on my 12 day old Type S 2.2
Like many on here it was occasional.
First thing in the morning with a cold engine, over potholes and tellingly when switching off and that was the clue.
With the car warmed up after a drive and sat at idle, I discovered that the rear exhaust was making ever such a small rattle that vanished when I took hold of the end pipe (big glove!)
My problem is that the chassis hanging point (Rear offside) was about 3 mm from touching the back box hanging bracket.
Consequently whilst driving, any chassis movement was resulting in metal to metal contact and the evasive rear knocking.
It appears that the Honda rubber hanging link was the suspect and after sliding it off the car and subjecting it to a yank / pull / stretch, the problem has gone.
The fit and tolerance is tight up there so I presume if the rubber link moulding is a fraction too small then hey presto an occasional knocking occurs.
It solved my annoying niggle, hopefully it will solve some one else's.
The next annoying knock is from the front passenger seatbelt buckle tapping on the B pillar trim when retracted!
A small rectangle of high quality 2mm thick black rubber glued on the B pillar trim will solve that
fickel is offline   Reply With Quote
Similar Threads for: Knocking at rear......possible solution
Suspension Knocking from front end smurf79 Wheels, Tyres, Suspension and Brakes 8 10th May 2008 16:56
Squeaks Knocking noise under the car civicman1 Bugs, faults and irritations 4 26th April 2008 14:16
Seat belt knocking Jeroen1000 Type-R 9 17th March 2008 18:20
Suspension Knocking noise in the back. sonicm Bugs, faults and irritations 2 20th December 2006 10:24
