This thread is about: Drivers Door Window Trim, it's in Bugs, faults and irritations at the Honda Civic forum Civinfo; Has anybody else out there had a problem with the rubber trim that is fixed to the door pillar and seals against the window? I ...
Old 16th June 2008, 13:41   #1 (permalink)
Angry Drivers Door Window Trim
Has anybody else out there had a problem with the rubber trim that is fixed to the door pillar and seals against the window? I have had 9 attempts at various replacements including fitting a new door! All have failed to stop the trim from pulling out along the full length of the pillar within a few months of operating the window.This looks very unsightly not to mention causing possible problems with water and wind ingress. I had been offered a replacement type s from honda UK but after viewing this at the dealership I was amazed to discover this 07 plate had the same problem. On investigating further a type r 08 plate demonstrator also had a faulty rubber trim! I was under the impression that my car was the only one but I advise all readers to check the drivers door window trim on their 3 door models!
Type S__t is offline   Reply With Quote
Old 16th June 2008, 13:52   #2 (permalink)
ante00's Avatar
if your talking about trim moveing when opening/closeing windows then it's same for all models from 2006 till now as we all discased already.......use search....
Trim moves when I open/close windows
Old 16th June 2008, 14:17   #3 (permalink)
No its the exterior rubber that seals between the glass and pillar. I will add a photo later to show the problem.
Old 16th June 2008, 14:24   #4 (permalink)
Comedian/Smart A*se
mine folds in on itself, but had never caused a problem really.
Similar Threads for: Drivers Door Window Trim
Cleaning Window Trim parsnip Cleaning 7 11th June 2008 07:58
Windows Minor annoyance with electric window trim iamholam Bugs, faults and irritations 6 7th May 2008 10:06
How do you remove the drivers window seal? thunt General Discussion 5 30th March 2008 23:51
Interior Illimination of Window lock switch on drivers armrest shedbuilder Lights 8 4th November 2007 19:14
Windows Something is jamming the drivers window enis Bugs, faults and irritations 4 19th October 2007 14:50
