| This thread is about: Check your alarm system, it's in Bugs, faults and irritations at the Honda Civic forum Civinfo; Just got a call from my stealer..............................."Your car is ready sir " What was the problem ? " a loose connection sir " Come to ... | ||
| View Poll Results: Check your alarm, does it work ? | |||
| Yes, it hurt my ears thanks ! |
215 | 71.91% |
| No, Honda have done it again ! |
84 | 28.09% |
| Voters: 299. You may not vote on this poll | Withdraw Vote | |||
LinkBack | Thread Tools |
#141 (permalink) |
TYPE R GT (R-15016)
![]() Join Date: 11th May 2008
Come to your own conclusions , I will check it works when I pick it up tonight !!! |
#143 (permalink) |
At last, summer tyres!
![]() Car: 2008 1.8i Sport, Milano Red
Alarm update - it pays to read the manual
Just a quick update after finally getting my owner's manual in English (so much easier that trying to translate).
So, I stated earlier that the alarm did not go off if opening the driver's door with the key (not remote), and this is still correct and the way it should be. However, how many of you use the "super locking" feature? Super locking is when you lock the car by pressing the lock button on the remote twice within 5 seconds (or turning the key in the lock twice). If the car is "super locked" then all locks inside the car are disabled (cannot be opened from inside so do not do this with someone in the car, well maybe kids So, it is not an easy system, but reading the manual sometimes can really help... Still not sure about the "siren" though, must be extra... lol EDIT: "Siren" (or bleeper as it is referred to in the manual) is only on cars with the ultasonic sensor. Last edited by hurricane; 25th June 2008 at 13:45. |
#144 (permalink) | |
![]() Join Date: 29th February 2008
#146 (permalink) |
Just spoke to the dealer and it looks like the new siren and control box haven't resolved the issue.
They have put a new fuse box on from a different car - with a working alarm - which they believe has solved the fault. However, Honda arent happy with the warrenty claim/resolution and are sending a senior engineer down to inspect the car tomorrow!!!! Maybe the number of sirens/control boxes being ordered has raised some eyebrows?? Oh - what fun!!! Lets see what tomorrow brings Simon. |
#147 (permalink) |
TYPE R GT (R-15016)
Deffo made HUK sit up according to my dealer , They suspect that repalcement boxs are also faulty..............watch this space !!
#148 (permalink) | |
Civic gone, not forgotten
![]() Car: 08 Zafira 150 CDTi
Sports (like the SE), do not have the CAT 1 alarm, so opening with the key will not activate the alarm. On that point, at least Honda provide you with two full keys. My neighbour's C Max came with one full key and one without the remote. You cannot open the car with the 2nd key without setting the alarm off. |
#149 (permalink) | |
As for the key issue, it seems pointless having one alarm key and one basic key. What happens if you lose the main one? |
#150 (permalink) |
![]() Join Date: 15th June 2007
Ignore my poll result, my alarm does work! Sat in the car, locked the door and opened the bonnet. Hey presto, a honking horn!
A few days previously, I opened the door from the inside which didn't trigger the alarm. Should it have?? |
#152 (permalink) |
![]() Join Date: 20th December 2006
I have a Jan 06 model and my alarm works fine. Sat in the car and locked it, moved around and the alarm (not the horn) sounded. Also locked the car with the window down and waved my arm inside with same result. Using the key when it was locked made the indicators flash but using key when it was "double locked" sets off the alarm.
#153 (permalink) | |
Apparently, the alarm does work - but only once!!! Some problem with the fuse box means that when first connected to the battery it works - but only the once. Disconnecting the battery and reconnecting makes it work again - but again only once! This is probably why all the cars would have passed their PDI. Annoyingly, despite trying two new, and presumably improved, fuse boxes on my car and proving that they work they wouldnt leave the part with the dealer Lets hope so Simon PS you may have guessed from my post that I am not too technical when it comes to cars. So hopefully someone may come on with a fuller explanation!!! |
#155 (permalink) | |
On the C Max Ghia, you can stop the alarm with the basic key by putting the key in the ignition, I can only assume that locking with the key will not fully arm the alarm. Can any one with a Civic ES or EX confirm if this is the same with the Civic? |
#156 (permalink) |
![]() Join Date: 15th August 2007
You've lost me! So is the problem with the fuse box or the alarms cpu box? Someone on here said that they had their siren and cpu replaced and this fixed the issue?
#158 (permalink) |
Wigan Warriors
![]() Car: 2008 CTR, Red
Mine works like a dream now...... I think we are getting lost a bit here.
If you lock your car with the remote (whilst out side the car), wait 1 minute (important). Now put your key in the lock and turn. This will trigger the alarm. If you have sound and flashing lights = Good If you have flashing lights and no sound = Bad If you don’t have anything chances are you don’t have an alarm. Now ultrasonic sensors. Open drivers window, close door, lock with remote. Again wait 1 min. Wave hands around inside car. If you have sound and flashing lights = Good If you have flashing lights and no sound = Bad If you don’t have anything chances are you don’t have an alarm This is the official procedure to test the system. |
#159 (permalink) | |
The only sure fire test is to open the bonnet while sitting in a double locked car. |
#160 (permalink) | |
Wigan Warriors
Thats odd, it should do as its an entry point, like bonnet, fuel filler and boot |
| Faults Check system fault | Kpow99 | Engines and Transmission | 3 | 3rd November 2008 19:31 |
| Electrics Check System icon displayed on engine start | ricky_west | Bugs, faults and irritations | 3 | 11th January 2008 17:07 |
| Warnings Check System - Engine Symbol! | Gloucestershire | Electronics | 2 | 12th December 2007 07:43 |
| Engine Check System ON glowplug indicator flashing | 3rd Honda | Bugs, faults and irritations | 31 | 9th December 2007 12:51 |
| Alarm 2 Way alarm System | beachead21 | Electronics | 4 | 2nd November 2006 07:35 |
