This thread is about: squeeky clutch??, it's in Bugs, faults and irritations at the Honda Civic forum Civinfo; i dont remember seeing this posted on here so thought i would ask if anyone else has a squeeky clutch??...
Old 7th October 2006, 20:01   #1 (permalink)
Andrea's Avatar
squeeky clutch??
Andrea is offline   Reply With Quote
Old 7th October 2006, 20:03   #2 (permalink)
allan40alt's Avatar
No; I have a shower every morning.
Old 7th October 2006, 21:04   #3 (permalink)
Jobo's Avatar
OMG, allan, you get worse!
Andrea, I haven't got a problem with my car's clutch..... touch wood!
Jobo is offline   Reply With Quote
Old 7th October 2006, 23:41   #4 (permalink)
Andrea's Avatar
the other half reckons wd40 will solve the problem, just wanted to know if anyone else had had the same problem. XX
Old 8th October 2006, 00:06   #5 (permalink)
12th June 2006 1.8EX
WoolyCiv's Avatar
Andrea, I would return to the dealers. I once had a squeaky clutch on a cavalier and it was one of the nylon clutch pivot bushes worn/misaligned, eventually it wore completely and I had to have fitted, a complete new pedal assembly at £ £ £. I should have returned it but didn't to my cost
Old 8th October 2006, 00:24   #6 (permalink)
Andrea's Avatar
thank you, will take it in when i get chance, thanks for letting me know. XX
Old 8th October 2006, 08:03   #7 (permalink)
Wise advice! I would have just squirted it, and I'm sure the dealer will as well, but now you'll have it on record that there was a fault just in case the whole assembly does give in.
Old 8th October 2006, 21:01   #8 (permalink)
Nanucq's Avatar
It was a very well known problem on muy previous ford focus II (also touch the cmax): it's been solved with lithium grease by the dealer.
You should bring your car to your dealer, it's wiser
Nanucq is offline   Reply With Quote
Old 9th October 2006, 08:30   #9 (permalink)
Nick7's Avatar
On 6th gen Civic's that is a well known 'feature'. Odd that it's still same thing on 8th gen...
Old 9th October 2006, 11:13   #10 (permalink)
fromswedenwithlove's Avatar
I have this problem on my car as well. Going to the dealer next week to get it fixed (I hope).
fromswedenwithlove is offline   Reply With Quote
Old 22nd February 2007, 20:33   #11 (permalink)
mine was squeaky and dealership had a look at it i have to get a new clutch slave cylinder
tenko is offline   Reply With Quote
Old 22nd February 2007, 21:05   #12 (permalink)
PTR
PTR's Avatar
on the 7th gen. Civ was also a well known problem...
they changed the clutch cylinder for free...
show your dealer the problem!
one of my old friends has a very very early MY06 1.8 and he had also the problem.. dunno what was the solution
Old 23rd February 2007, 17:53   #13 (permalink)
Yes I have a squeaky clutch pedal, not all the time though, thought it was my shoes.. will need to investigate.
rey1234 is offline   Reply With Quote
Old 23rd February 2007, 20:17   #14 (permalink)
Andrea's Avatar
this was sorted last wednesday guys, was meant to be done before xmas but they needed to order the master cylinder and it took a while coming in.
Old 8th March 2007, 11:38   #15 (permalink)
snelle snip's Avatar
Although it has been fixed after 1500 Kms it starts to squeek again now after 5500 Kms. I don't know yet if i'm going to learn to live with it or to complain again at the dealer.
Great car after all!
snelle snip is offline   Reply With Quote
Old 8th March 2007, 11:52   #16 (permalink)
PTR
PTR's Avatar
what (wich part) have they fixed/changed?
clutch cylinder in the engine bay or in the passenger room?
or they have just put some grease on the pedal somewhere?
actually I have a click (like a relais) when I press the pedal in and out also.. just a simple click on halfway (not the clutch switch!!)
I think I will show it to my dealer... it disturbs me well hmmm a bit... would be good to have it silent!
Old 8th March 2007, 12:31   #17 (permalink)
@PTR: I don't know exactly what (which) part(s) they fixed or changed (warranty), but I'm sure it has been done. Before that (approx. 1000 Kms) they have indeed put some grease somewhere but that didn't help.
About the click you mentioned: I hear it too (it wasn't there before the so named 'fixing').
I think I'm going to tell both things to the dealer whenever I pass there for 10000 Kms oilchange.
Old 9th March 2007, 20:00   #18 (permalink)
Fallen Angel
sarahjo's Avatar
Ok my clutch...(yes for those of you who know me well enough i have spelt it right ) clicks at a certain point when i press it and depress it....WHY????? I don't know...do i need to do anyting about it!!!!!!!
sarahjo is offline   Reply With Quote
Old 11th March 2007, 01:56   #19 (permalink)
Moe
Wannabe Wheelnut
Moe's Avatar
I had this problem last summer and my god it got annoying! Finally, when I couldn't stand it any longer, I took it to the dealer. Prior to that, I had used WD40 and taken it to the dealer who used grease to grease it up, which worked decent for 2 days after which the squeaking returned.
They booked the car in and replaced something... the squeaking went away. For a month this time. Then it returned!
My third visit to the dealer got it sorted once and for all. They had to order in a replacement of some sort. It's been 2 months now and touch wood the squeaking hasn't returned. Though some good did come out of visits to the dealers... they let me use a brand new Civic 2.2 diesel 56-plate as courtesy car. Only had 8 miles on the clock when they let me take it away for 4 days.
Gave me an insight into how the diesel would have fared. Bottom line, I'm glad I went with the 1.8 i-vtec. Different strokes for different folks...
Take it to the dealer.
Moe is offline   Reply With Quote
Old 11th March 2007, 09:09   #20 (permalink)
PTR
PTR's Avatar
I found yesterday what is clicking (not squeaking): it is the clutch switch... so I'm not that worried anymore but it still disturbs me a bit and when the car was new it was silent.
So I think I will show it to the dealer.
Does any of you have that clicking pedal?
(It isn't to loud so not that easy to hear. Radio off, engine off and push it a few times a bit faster.. at about halfway I hear it.
Similar Threads for: squeeky clutch??
FN2 clutch vibration MoOriginal Type-R 14 Yesterday 16:53
Squeaks Clutch pedal noise Mr Lovedog Bugs, faults and irritations 17 12th August 2007 17:27
Transmission Clutch pedal nuisance. Ricky m Bugs, faults and irritations 5 27th June 2007 14:54
Suspension Squeeky Shockers scol78 Bugs, faults and irritations 11 12th October 2006 08:17
Transmission Clutch Judder geoff Bugs, faults and irritations 10 13th September 2006 05:33
