| This thread is about: Where does this squeek come from?, it's in Bugs, faults and irritations at the Honda Civic forum Civinfo; Well I've checked the wiki for potential squeek sources but haven't had any luck yet (see list below). The sound is very faint (so no ... | ||
The sound is very faint (so no loud 'cracks' nor rattles). It's more like a squeek from a mouse (will put some poison in the car) or and old bed. Seems to be coming from the speedo area but pressing around there hasn't stopped it. It's also very intermittently. I mostly notice it on a good road when it get's a little bumpy here and there. Finally, a bad road doesn't make it come to the foreground. So maybe it is triggered by sideway motion rather than bumpy up and down motion. I've nicked this list from the wiki and added my own checks (typed in green)
Hi, i have the mouse type noise coming smewhere around instrument panel or door. I can't actually locate it. Did you found anything?
This might help:
Try some silcone spray around the joints in the top of your dashboard. Careful not to overspray - use the thin tube that comes with the aerosol to trickle a little into the joint - capillary action will suck it in from there. |
My findings (also see first post):
Low temps = rattling air vent and no squeek. So it seems that we had the same idea Munro. What was that saying about great minds Last edited by Jeroen1000; 8th July 2008 at 07:54. |
I've found it!! It's the headlight dimmer switch. If I put my finger on it when I get a squeek it stops. But it squeeks when it's in or out. Thinking of asking dealer for a new switch. It's driving me barmy
#10 (permalink) | |
Funny but the sound I'm getting from there is more of a cracking sound. At first, I thought it was the panel where the mirror was in on the passenger side . But the cracks there don't bother me that much. The squeak has left for now due to the still ongoing cold rainy weather. But I did get a another to replace it. The fabric right above the head (where the grip is for the passenger) makes a rubbing noise where the fabric meets the rubber (but on the drivers side then). We really should make a 'noise buster' sub forum |
| Squeaks Instrument cowling squeek cure? | PWOOD | Bugs, faults and irritations | 4 | 25th April 2008 11:44 |
| Squeaks Squeek above drivers door? | Jani | Bugs, faults and irritations | 12 | 13th July 2007 17:23 |
| Squeaks Roof liner squeek solved | Stef | Bugs, faults and irritations | 17 | 13th May 2007 23:37 |
