| This thread is about: hissing noise, it's in Bugs, faults and irritations at the Honda Civic forum Civinfo; My local dealership has moved the 'A' pillar (front window) to stop the dashboard rattling, however there is now a hissing noise which I think ... | ||
hissing noise
My local dealership has moved the 'A' pillar (front window) to stop the dashboard rattling, however there is now a hissing noise which I think is the material in roof rubbing against something, has anyone else had this?
I'm not totally sure what you mean but I have got hissing type noise from headlining area and it is so annoying. I think the dealer can only do so much before they start going the other way and making things worse, Honda should have put the cars together better with higher quality materials IMO, so frustrating.
My guess is that the corner of the headliner is rubbing on the windscreen. Test by sliding a credit card or similar into the corner, it should be free, there should be a reasonable clearance.
Probably a piece of foam rubber behind the headliner will fix it, else trim the headliner with a knife. |
I think your right, it just needs the dealer to put some foam lining in the gap to stop it rubbing. If I put my hand on the lining about 4 inches away from the screen the noise stops.
| Engine Noise at low RPM | laluks | Bugs, faults and irritations | 8 | 26th June 2008 06:14 |
| Noise under braking? | Rocko | Type-R | 23 | 8th April 2008 07:18 |
| AC/Heater Air con hissing | bounce75 | Bugs, faults and irritations | 11 | 5th May 2007 16:38 |
| AC/Heater Air Con noise | rogie | Bugs, faults and irritations | 6 | 23rd April 2007 20:16 |
| Wind noise | glen666 | Wiki Article Discussion | 2 | 11th April 2007 14:27 |
