This thread is about: A Mass of Dash Rattles!, it's in Bugs, faults and irritations at the Honda Civic forum Civinfo; Originally Posted by Wheelchair Any particular brand of silicone spray? Sorry - not very clear, but 3 in 1 is the brand - same as ...
Old 26th August 2008, 17:24   #81 (permalink)
3rd Honda's Avatar
Sorry - not very clear, but 3 in 1 is the brand - same as the 'household oil can' type
Old 26th August 2008, 18:47   #82 (permalink)
IMHO you should use only 100% silicone and not "3 in 1" because the petroleum residues could otherwise damage the plastic
Old 26th August 2008, 20:14   #83 (permalink)
3rd Honda's Avatar
You could well be right there, though it claims to be safe on rubber and vinyl. looking at the Materials Safety Data Sheet, it still contains a lot of petroleum based things
Old 26th August 2008, 20:22   #84 (permalink)
Jack The Lad.'s Avatar
You would be surprised how a carefully applied ( using the spray tube supplied) drop of WD40 will fix a squeak between plastic and plastic.
Old 28th August 2008, 09:34   #85 (permalink)
Reversing lessons anyone?
Car: 2.2 i-CTDi Type S GT, Milano
I dont think he was suggesting 3 in 1 as the spray
3 in 1 make a 100% Silicone spray on its own using the 3 in 1 brand
Old 28th August 2008, 11:58   #86 (permalink)
Goodbye all, have fun!
Will have to get some sillicone spray. I think the noises are coming from the left curtain airbag cover and where the A pillar meets the screen and dashboard.
I HATE rattles, but somehow I can forgive them more in the Civic, its such a nice car to drive.
Old 28th August 2008, 12:26   #87 (permalink)
Can you not get to drive a Honda mechanic around who will be closer and able to diagnose and cure it ?
or
Is that when it stops - getting your dealer involved = sod's law!
Old 28th August 2008, 12:30   #88 (permalink)
You can bet your life if I take it to the dealers they wont hear anything! It will stop completely and then restart once I drive home.
TBH I don't want the dealer to rip the dash apart and cause more rattles, I will try to locate it and then spray it with the sillicone.
Would only use the dealer as a last resort for this type of problem.
Old 28th August 2008, 12:36   #89 (permalink)
In that case you need a patient passenger to help find it.
Trying to find a rattle whilst driving can be a tad risky.
I had a work colleauge lying flat in the back of a Xantia once whilst we tried to find where a tailgate rattle was coming from.
In the end the dealer took off all the interior tailgate trim, sprayed it with silicone and re-assembled it - and it worked.
Old 28th August 2008, 12:37   #90 (permalink)
I shall have to persuade my Mrs to drive the car, I think she's a little nervous as she hasn't tried it yet. I'm sure she will be ok though.
Old 28th August 2008, 12:39   #91 (permalink)
Good ploy
Old 28th August 2008, 13:08   #92 (permalink)
The rattle is more than likely coming from the plastic cowel surrounding the wipers.
Simply squirt a little silicone between the glass and the plastic.
Old 28th August 2008, 13:10   #93 (permalink)
Must admit, I think its a little too loud for it to be that. I will try it out though.
Have you used the silicone?
Old 28th August 2008, 13:27   #94 (permalink)
3rd Honda's Avatar
Correct, but I have now checked, and it does have some petroleum stuff in it, so whilst I would still try it, go carefully. It does say it is safe on metal, rubber, wood, vinyl etc. so I would think its OK
Old 28th August 2008, 23:57   #95 (permalink)
Will have to get that spray pronto. Was out tonight fine on first journey, all quiet. On the return leg it was RATTLE RATTLE RATTLE!
Its very annoying!!!
Old 29th August 2008, 00:09   #96 (permalink)
It seems to go when my wife presses on the dash near the window on the passenger side in the corner. Anyone else had this?
Old 29th August 2008, 06:54   #97 (permalink)
Nope
The way that it comes and goes sounds like the dash is moving on corners ?
After a sharp left or right bend (whichever causes it) the dash may shift slightly causing the rattle.
Old 29th August 2008, 06:57   #98 (permalink)
I was doubtful too..but its now cured
BTW...the dealer failed to fix it
Old 29th August 2008, 07:00   #99 (permalink)
The dash will rattle on straight smooth roads at times, very annoying.
Robbo51, was your dash very rattly, and in the same place?
Bet you were glad the silicone worked!
Old 29th August 2008, 07:03   #100 (permalink)
Yes it will rattle on straight roads once triggered, but it takes the sharp corner to shift the dash just that mm or 2 to get it to start.
These are a nightmare to find and I can understand your reluctance to have the dealer refit the dash.
Similar Threads for: A Mass of Dash Rattles!
Squeaks Rattles Nick7 Bugs, faults and irritations 32 28th June 2008 18:51
Trim rattles CIVHEAD Wiki Article Discussion 8 10th May 2008 07:34
Squeaks Type-R Rattles StuMcBill Bugs, faults and irritations 8 3rd March 2008 20:05
Galaxy Dash board pics, Type R dash fitted to EX! Ham'sCivic Gallery 3 15th April 2007 17:53
Mass Confusion at Honda Moley RUFC General Discussion 5 5th September 2006 21:09
