| This thread is about: Steamy windows (merged), it's in Bugs, faults and irritations at the Honda Civic forum Civinfo; There's a song there somewhere? Hi all, Just wondered if you guys ever get a misty front windscreen? I find pressing the demist button ALWAYS ... | ||
Hi all, Just wondered if you guys ever get a misty front windscreen? I find pressing the demist button ALWAYS does the trick, in fact, it works in seconds. But I don't want to keep on using it as it uses the AC motor and turning it on and off every 3 or 4 minutes can't be good for it! I was just wondering though, does anyone know of a liquid solution we could appy to the inside of the windscreen to stop the build up of mist? I've heard someone say mixing in some lemon juice with water and applying that - any thoughts? |
There's a liquid called 'Aqua Ban'. Not sure how good it is as I leave my Air-Con on all year round.
Ps: This is a small spray-on anti condensation liquid; not the tablets you get from the chemist! Aqua Ban Ltd, 2 The Ropewalk, Ilkeston. Last edited by allan40alt; 23rd October 2006 at 14:35. |
You are right, turning the AC on and off repeatedly is not good for it. If you leave the system on Auto, it will cycle the AC as needed and should prevent misting.
From wha I understand, the difference in fuel cunsuption between the system cycling in auto, and AC being turned off is negligable. I had to use my demister button for the front screen for the first time yesterday, and it worked within seconds, I then hit the auto button and all was fine. |
#5 (permalink) | |
Am about to make a long journey later tonight and will try what you suggest! Appreciate it - thanks VERY much. Thanks to all other replies too! |
Are you sure its not you thats steaming up the windows with that youre thinking at the time?
On a serious note Ive noticed my front windoes mist on the inside often even when im driving. There must be a ventiliation issue somewhere. |
5 seats are a must!
This discussion always comes around when the damp cooler weather comes around.
Think about it, breathing creates moisture, as does rain. By getting in the car this traps the moisture which condenses on the cold glass. The A/C clears this by blowing de-humidified air into the cabin. It is best to have it on all the time, but of course as it switches off and on by it's self; there's no real difference if you do it manually. |
Turning A/C on/off is *not* bad of A/C.
What do you think how A/C works when it's ON? It turns compressor on/off all the time when needed... so switchign on/off won't do any harm at all. |
The company that makes Rain-X also make an Anti-Fog liquid to wipe on to the windscreen. I have used it in the past and it worked at the time.
I'd be very carefull about those liquids. I heard horror stories from people that tried them - like in cold liquid turns like it's milk on windows, etc.... and worst part is it's close to impossible to remove that stuff from window later!
If you are going to use this stuff, tripplecheck with people who used that for longer periods of time already. |
#12 (permalink) | |
Many air con systems, including portable home ones, have a time delay switch to prevent you turning the compressor on and off quickly. If you have in on, the turn the compressor off, and select 'on' again, it will wait a minute or two before activating. I was told the car was similar, that the Auto timing between on and off is enough to be safe, it won't switch a few times a minute! Repeatedly swithing it on and off in quick sucsession is bad for it. I can't say what part it is bad for, the clutch or the compressor or what, but I have been advised againt it. It was a word of warning just in case, if you think it is OK to do, that's fine. One thing I do know for sure is that you should use the system regularly. Never let it stay unused for any length of time, especially in winter. |
Agree with Bungle, using the Auto setting and occasionally screen demister button seems to be the way to go.
I have my aircon running all the time and still return 40mpg which I am pleased with. |
#14 (permalink) | |
Thanks for the above info. I went for a long ride last night and did what you suggest and it works a treat. How does the system know when to use the A/C motor (in Auto) or not then? What must happen for the A/C to come on or off (in Auto)? |
#15 (permalink) |
I just zap the demister button for a few minutes at a time.
I NEVER use the Auto button because it turns my Recycle air button off - I've driven for the last 10 years probably with recycle air buttons to avoid breathing all that carbon crap outside, the moment any gets in the car I nearly choke! |
#16 (permalink) |
On manual AC it works in this way: compressor is on untill air temperature going behind AC cooler (hmm.. or whatever is called, srry for lack of english words) is under 1 degree celcius. At that point AC compressor is disengaged. It engages again when air reaches over 4degree celcius (I'm not 100% positive on those temperatures, but could check in manuals).
As for on manual using A/C with heating - air is first cooled, than heated. The first cooling part is one that helps with defogging. As for Bungle's comment: A/C compressor always switched on/off... intervals depend how fast air cools/heats up. Usually this is arround 1 minute period, while in high heat A/C compressor can sometimes be always on. As to manual on/off - it is *not* bad for it. It might be bad if you flick it on/off each second - but each few minutes is nothing else than as if it were working automatically - so there is no harm at all. |
#17 (permalink) | |
( i used the ac in the pug 10-20 mins a week to keep it in good order but in winter didnt use it anymore but in summer used it alot) |
#19 (permalink) | |
(for those of us old enough to remember) See these amps? They go up to 11! But why didn't they just make 10 louder? But these go up to 11! (it works better in the film |
| Cleaning windows | AndyG72 | Cleaning and Styling | 9 | 9th October 2007 14:46 |
| Electrics windows | pnut | Electronics | 15 | 8th June 2007 12:40 |
| Tint Windows or not? | Type S Bournemouth | Cleaning and Styling | 35 | 24th February 2007 10:04 |
| Has anyone done their own Tinted Windows? | damianscott71 | Cleaning and Styling | 3 | 8th February 2007 11:37 |
| Automation Windows and lights | candle | Electronics | 4 | 19th September 2006 10:24 |
