Old 23rd October 2008, 09:18   #1 (permalink)
S18TypeR's Avatar
Humming Noise when i move off...
On my Type R, does anyone know why most times when the car is cold, just as I start to move off (low speed and still coming off, or just off the clutch) I get a humming noise from the front? Once im rolling at over 5mph its quiet again.
I'm thinking it's binding brakes, and its in for new pads with ABP v.soon, but has anyone had this themselves? I've done 11,000 miles.
Once the car has warmed up, i can pull away with no humming.
Any stories would be interesting to hear!
S18TypeR is offline   Reply With Quote
Old 23rd October 2008, 09:28   #2 (permalink)
Civic RGT
smokeR's Avatar
Sounds like it could be the thrust bearing....also not sure about the FN2 but my old EP3 the flywheel was prone to warping very very slightly, but once warmed up it was fine.
smokeR is offline   Reply With Quote
Old 23rd October 2008, 09:42   #3 (permalink)
Goodbye all, have fun!
A humming noise doesn't sound like the brakes, that's more of a metallic screeching sound.
Old 29th October 2008, 13:10   #4 (permalink)
CCC
CCC's Avatar
Yes I raised the same issue a while back, it gets worse when its wet? I'm not sure what it is but apparently its common.
http://www.civinfo.com/forum/bugs-fa...when-cold.html
CCC is offline   Reply With Quote
Old 1st November 2008, 13:53   #5 (permalink)
CCC
CCC's Avatar
This noise is worse when its wet like today, has anybody taken their car in to the dealer about this?
Old 21st November 2008, 00:29   #6 (permalink)
supra-boy's Avatar
Car: 2008 CTR MILANO RED
Yeah I get a humming sound when Im driving into my garage as its got a bit of a slope. I also get the same sound when I reverse and if the road is not level. I dont think its much to worry about if its the same sound, at least you dont get a strange sound doing 70 + MPH!
supra-boy is offline   Reply With Quote
Old 21st November 2008, 01:36   #7 (permalink)
andy l's Avatar
i used to own a hrv ( don't take the piss ) and found that the gearbox idler shaft was noisey ie when i had the car in neutral without the clutch being pressed but never had any problems with it so it must have been normal
andy l is offline   Reply With Quote
Old 21st November 2008, 10:55   #8 (permalink)
118
I've seen problems with RE6 diesel CR-V front brake pads binding and causing a humming/creaking noise at very low speeds, but never any issues like this on Civic.
Might be worth jacking the front of the car up and spinning the wheels by hand to see if this replicates the noise.
118 is offline   Reply With Quote
Old 21st November 2008, 10:59   #9 (permalink)
Wigan Warriors
x Dr Vodka x's Avatar
Car: 2008 CTR, Red
this will tell all http://www.civinfo.com/forum/bugs-fa...when-cold.html my does the same
Similar Threads for: Humming Noise when i move off...
Transmission Humming noise from clutch when cold cnicolini Bugs, faults and irritations 62 24th June 2010 00:18
email on the move... TTDegs Any non Civic chat here please! 7 26th September 2007 01:08
Should I move to the darkside??? welshtom General Discussion 22 1st June 2007 01:48
Move complete Pottsy Site suggestions, feedback and rules 0 22nd May 2006 08:21
Site owned by Jayne Potts - nothing to do with Honda!
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51
