This thread is about: Parking brake fault, it's in Bugs, faults and irritations at the Honda Civic forum Civinfo; Yes, you'd think so. hb3.gif...
Old 25th August 2007, 13:18   #81 (permalink)
Old 25th August 2007, 13:54   #82 (permalink)
pcr
pcr's Avatar
About the way the brake completely releases after a minute or so.
I think I said this before but I believe the problem is that the realease button is very sensitive.
If when applying the brake the first finger is inadvertently underneath the release button, maybe just touching it, then there is a high chance of half-engaging the locking mechanism, which then springs free shortly afterwards.
Try it, mine does it, and so did a loan car.
Solution,
Keep fingers away from the button when pulling up that last click.
It makes sense to me that leaving the car in gear will prevent runaway, but as each cylinder in turn looses compression the car will slowly chug down the hill, if it is steep.
Turn steering in towards curb.
Given that anyone who is unaware of this possible issue and who applies the brake in a particular way, may be caught out, I would think there are some safety concerns here.
Old 25th August 2007, 14:05   #83 (permalink)
Perfect Guy!
Brodick's Avatar
Originally Posted by FWH View Post
Although I am not going to argue with those numbers, surely it is the same design of handbrake on all Euro-Civics.
I am sure it is FWH -but as I have said before - no problems
here and I know I am not alone
So why is it that onl some cars are affected
PCR could have a point
Old 25th August 2007, 14:12   #84 (permalink)
I was definatly not (100% sure) not touching the handbrake lever at all when it went "TWANG" and released it self. I have tried recreating the problem by touching the release button, but have not managed.
Old 25th August 2007, 14:59   #85 (permalink)
vtec-hungry's Avatar
that is zily weird? y is it like so? just weird. what do you think pottsy, I really want to know what you think of this, I mean it doesnt make much sense? dd they really skimp out on the handbreak design???
Old 25th August 2007, 15:05   #86 (permalink)
its weird right had a dream last night about drivig ctr and had this hand break prob, reading too much of these threads! I mean this is a serious issue here, so far to it seems no ones injured but potentially this could be fatal, HONDA FIX IT, IT IS YOUR OBLIGATION TO EVEN AFTER SCAMMING US!
Old 25th August 2007, 15:21   #87 (permalink)
vtec-h,
Not sure what you're saying. 2% of R owners have an unspecified problem with the handbrake, and none have seen fit to even take it back to the dealer.
A small number of non-R owners have reported the lever pinging off in an unrepeatable fashion. If you leave your car in gear (which you should always do in any car that has rear discs, because the parking brakes are weak and prone to relaxing as the discs cool) then you'll be fine.
I'm sure Honda are looking at the problem with the rare pinging-off cases, but for the time being there's nothing to worry about if you leave your car in reverse.
Old 25th August 2007, 16:01   #88 (permalink)
......................hopfully wont affect me whn i get my brand new ctr end sept, CANT WAIT and I sear if the handbreak doesnt work im gonna freak! will hndbreak turns still be ok?
Old 25th August 2007, 17:13   #89 (permalink)
Perfect Guy!
Brodick's Avatar
Vtec H you really need to calm down
A few owners have some problems with their handbrake - without knowing the cause you cannot make such statements as above
Old 25th August 2007, 17:40   #90 (permalink)
yes
Old 25th August 2007, 17:41   #91 (permalink)
pcr
pcr's Avatar
OK, please humour me for a while with this one.
This is how my car is, how is yours ?.
If I grap hold of the handbrake lever, but inadvertently my my first finger is under the release button, and pull up, nine times out of ten the brake will not engage. This is without trying to depress the button in any way.
Measuring it, holding the button depressed by little more than 1mm prevents it engaging. It is the ease with which the brake can be made to not fully engage that I think makes half-engaging more likely.
I am convinced the brake can be half-engaged, how else could it ping off ?.
Now if due to tolerances, the amount the release button needs depressing varies, then some cars will be more susceptible than others.
Old 25th August 2007, 17:52   #92 (permalink)
Mine does not do this. I cannot in any way I have tried create a situtation where it does not engage due to my outside actions.
I have tried pulling a different angles and other stuff I could think of too.
Quite possible.
Agreed.
Old 25th August 2007, 17:57   #93 (permalink)
Good thanks!
If I give the lever a good pull (the spec is 44 lbf) I get about 8 clicks. So if I had a problem with the ratchet, then one of the 7 remaining clicks will get it.
I have tried to simulate it, but if I miss a ratchet click it just gets caught by the next one down. Each click is pretty positive, with the button moving about 3-4 mm.
Am I going to have to pull my car apart to have a look at the ratchet mechanism?
Old 25th August 2007, 18:29   #94 (permalink)
pcr
pcr's Avatar
Thanks for that Pottsy. You see, on mine the clicks are positive enough, but the button movement is barely more than 1mm.
Anyway, I've let the good lady know that she needs to apply a force of 44lbf, to which she replied "........................................". Frankie Howard would have been proud of that line.
Old 25th August 2007, 19:47   #95 (permalink)
HappyMan's Avatar
I have been driving for about 16 years and mainly in the UK, but now I live in Poland and they don't use the Handbrake. I was surprised by this but very often when I have taken my car to the dealer for a service ( skoda at present ) the car is parked in gear without the handbrake. My father in law never aplies the handbrake just leaves it in gear unless he is on a hill.
It is interesting how I will fair in the Civic as I have to apply the gear into reverse at present due to a security device that is applied to the gears to stop people driving away with your car. The civic can't have this device so I am wondering if I will naturally put it into gear or not!!!
But by the sounds of this post I better had keep the habit
Old 25th August 2007, 20:19   #96 (permalink)
Been testing some more.
Obviously pushing the button in far enough ensures that it does not catch, but this is definatly more than 1mm. I would say around 3-4mm also.
When mine "TWANGED" it was pulled well far up (didnīt count number of clicks though).
If you donīt want to take yours apart Pottsy, you could always fly over here and dismantle mine.
Old 25th August 2007, 21:19   #97 (permalink)
pcr
pcr's Avatar
FWH,
We seem to having different experiences here, which the difference in button movement probably accounts for, mine is definately 1mm only.
Here's how I can reproduce the problem, it's hard to explain in words, more a question of feel. Apply the brake hard, the harder the better. Now ease it upwards just enough to reduce the pressure, while very gently depressing the button. You should be able to feel the teeth not fully engage. Catch it right, and it can be made to stay in this position. Now, give it a tap and it flies off.
I must say, I have no idea if this is better or worse than any other car's handbrake, and am happy enough just to take care when applying it. I do feel though that it is an issue for the unwary, and would be very annoyed to be caught out in the manner descibed by Ikes earlier.
Old 25th August 2007, 21:25   #98 (permalink)
pcr - I assume you have pulled it for about 8 clicks worth when you tap it. So my question is: when it flies off, do none of the 7 other clicks on the ratchet stop it?
Old 25th August 2007, 21:38   #99 (permalink)
pcr
pcr's Avatar
Pottsy, yes it is applied very hard, and no, it does not engage a lower tooth but flies right to the bottom, very quickly and with a lot of force. When it is appied this hard, it seems more likely to hold the teeth in this half-engaged position, I guess due to higher friction between the teeth. Maybe some grease is called for.
Old 26th August 2007, 08:51   #100 (permalink)
Got to be faulty. The whole point of the ratchet is that it can't do that! If I press the button in whilst pulling the lever as hard as I can, and then I release both at the same time, it never gets past a single notch on the ratchet, however many times I try.
I need to do some dismantling!
I'm hoping the lever trim comes off with these clips here:
Similar Threads for: Parking brake fault
Steering EPS Fault sexykungfufighter Bugs, faults and irritations 9 17th January 2008 20:02
Transmission VSA/ABS Fault blackie944 Bugs, faults and irritations 17 14th January 2008 17:04
fault vtec-hungry Type-R 15 3rd September 2007 12:08
Squeaks Exhaust Rattle and Parking Sensor Fault smb09_1999 Bugs, faults and irritations 5 18th April 2007 13:00
AC/Heater Fault or Feature? In 1.4 car
