AC/Heater Dual Zone Climate Control - If one side was warm and one side cold.. - Civinfo
post #1 of 7 (permalink) Old 20th January 2010, 21:03 Thread Starter
jameseh's Avatar
Car: Orchid White GG6 Si
...with the passenger side being warm and the drivers side set to cold, does the two central air vents each blow hot and cold air?
Problem with (I don't know if its a design flaw) the dual zone climate control is when the wife wants her side warm and I want my side cold, the central vent seems to blow more cold air than warm air on her side (shes specifically said RIGHT THIGH) even though the vents aren't pointed on her side I don't get where the cold is coming from! So I just end up turning off dual zone and setting both sides to the same setting (then I start to sweat..)
Has anyone else had this problem?
Cheers
jameseh is offline
post #2 of 7 (permalink) Old 21st January 2010, 09:35
NoNumpty's Avatar
Car: 2008 2.2 i-CTDi ES NHB
Cheers
If the passenger side is set to hot and the drivers set to cold then the passenger side central vent will blow hot and the drivers side central vent will blow cold and visa-versa.
You can move the central vents so the one on the passenger side points at the passenger and the one on the drivers side points at the driver.
The Missus and I are the opposite way round to you - she like it cold and I like it warm - I don't have a problem using the dual setting (it even comes out different on the foot vents too).
I've also noticed that the glove box vent is controlled by the passenger temperature settings
NoNumpty is offline
post #3 of 7 (permalink) Old 21st January 2010, 17:04 Thread Starter
jameseh's Avatar
I've tested it out again and yeah you're right the passenger side central air vent will blow whatever heat she wants but shes still getting a really cold draft on her right thigh (and she repeats again, RIGHT THIGH) even though her central air vent is pointing towards her and mine pointing towards me... :S
When you're using the dual setting are your heating settings set only a few degrees from each other? Most of the time mines on 16 degrees and she has hers on 21, but the fan is only set to 2/6 which isn't exactly blowing like a hairdryer so I don't understand how shes getting a cold right thigh..
WOMEN MAN!!
jameseh is offline
post #4 of 7 (permalink) Old 21st January 2010, 17:15
The Property Man
fat4y's Avatar
Car: 2007 VW Beetle 1.6
never had a problem with mine..why are girls always hot?lol
fat4y is offline
post #5 of 7 (permalink) Old 21st January 2010, 17:45
NoNumpty's Avatar
WOMEN MAN!!
Are you not using it on auto then ??
Try setting auto, then dual controls enabled and then set the temperature - the fan and which vents are active are automatic so should blow correctly
NoNumpty is offline
post #6 of 7 (permalink) Old 22nd January 2010, 23:34 Thread Starter
jameseh's Avatar
I don't really use the auto function anymore as everytime I set it to a level (e.g 20 degrees) it either feels too warm or too cold after like 5 minutes of driving - you'll need to reset it another setting every so often.
Meh, I'll try it again when I get home from work.. will report back later!
jameseh is offline
post #7 of 7 (permalink) Old 23rd January 2010, 21:08
NoNumpty's Avatar
When you set the temperature it should maintain that temperature when set to auto - sounds like your aircon is faulty - read this Climate Control - Civinfo Wiki
NoNumpty is offline
  Civinfo > 8th Generation Euro Honda Civic > Bugs, faults and irritations
Human Verification
Fog Change rear foglight side/dual rear fogs onweed Lights 1 5th December 2009 21:28
AC/Heater Duel Zone Climate Control fault TommyL Electronics 0 10th October 2009 20:19
AC/Heater Dual Zone Control Problems Zeberdee Electronics 2 10th June 2009 09:20
AC/Heater Dual Zone Question Mr JP Electronics 19 5th November 2008 08:11
AC/Heater Dual-Zone Climate Control elfa7 Electronics 12 5th January 2007 23:36
