| This thread is about: Desperate I-SHIFT HELP, it's in Bugs, faults and irritations at the Honda Civic forum Civinfo; Foggy69, you're right to quote that. Early twin clutch boxes had faults too. (Not today though, I believe) The point is, however, that even working ... | ||
#41 (permalink) |
Early twin clutch boxes had faults too. (Not today though, I believe) The point is, however, that even working totally to spec and in the hands of an expert, a one-clutch box is always going to be a compromise, and will always be inferior to a two-clutch assembly. In the same way that the Civic's torsion bar will almost always be inferior to multilink suspension. Why did Honda do it? Your guess is as good as mine. But it probably began with m and ended with y. Last edited by Honcho; 12th December 2007 at 16:52. |
#42 (permalink) | |
Perfect Guy!
The Corolla had a full automatic box as does the mazda 3 as does the Jazz ( well CVT) The Civic like a few other cars is a Automated manual |
#43 (permalink) | |
But he also told reporting my complain to UK factory. I have a 2006 i-shift model and not a 2007 which seems to have an improved gearbox program not retrofitable to 2006 civic. |
#44 (permalink) | |
Still on the gearbox and it's problems, the other day I decided to overtake the vehicle in front, a rather normal manoeuvre - I have done it before! I floored the accelerator, Millie dropped into the right gear and we accelerated past the vehicle. Halfway past this vehicle Millie's i-Shift decided to change up! Leaving me with NO POWER while it worked out when it would apply the higher ratio, only seconds I admit, but that was quite scary anyway! "The secret of long life? Keep breathing!" |
#45 (permalink) | |
i shift.
#47 (permalink) | |
#48 (permalink) |
One advantage of the i-shift is that it makes you drive very, very carefully. Perhaps it's a case of the 'car' or should I say the computer / CPU teaching the driver not to take any risk whatsoever. Life can be interesting if not shortened using it. I have a pacemaker - thank God !
#49 (permalink) | |
I only usually do 'local', so overtaking is a bit of a challenge for me anyway! "In my golf club, If you don't have a shrink, They think you are crazy!" |
#50 (permalink) |
The dealer has installed the new software for the i-Shift in my Civic (model 2007). I don't know yet if all my problems are solved, but my first impression is great. Changing gear is a bit faster en smoother. In auto-mode its also a lot better.
My major problem is/was that when driving in traffic-jams the clutch gets hot. Because it is protecting itself, it finaly releases the clutch at 3000 rpm. Well, you know what than happens..... I hope this problem is solved too. |
#51 (permalink) | |
Perfect Guy!
#52 (permalink) |
That would interest me as well.
Whilst some of us with '07' cars won't be due to visit the dealers for service until March, there must be some out there who have completed the 12,500 miles around now and may be able to ascertain whether they are due a 'patch'. |
#53 (permalink) | |
#54 (permalink) |
I got a call today that my dealer had received the new disk ( software ) and tomorrow after eleven months of waiting my problems will be solved. Actually not my problem but Honda's I await with baited breath. Driving the Civic has been 'fun' I have a few heart problems and have a pacemaker which has been fully tested by Honda and to date has passed with flying colours !
Have fun buy an i-Shift Gerald |
#55 (permalink) |
Our 07 Civic with I-Shift has also faulted. We are waiting for Honda to get back to use about a swap. The bottom line is there are too many issues with this transmission and Honda needs to step up and recall it - before someone gets in a serious accident and sues them. And once again our dealer says they never heard of any issues with the I-Shift.
#57 (permalink) | |
It was definitely a rogue one I had - and thankfully Honda decided to give in (with a lot of hassle and persuasion) and give me a brand new one. It really shows how bad the last one was. Just hope it continues... Good Luck all of you with problems - just keep on at Honda - in all fairness the problem lies with Honda UK NOT the dealer!! |
#58 (permalink) | |
| mod on i shift | mihael | John Pease Honda | 16 | 3rd September 2007 11:13 |
| Someone has got a bit desperate | sco77harris | Any non Civic chat here please! | 13 | 3rd May 2007 16:52 |
| WTB: 07 Type R shift knob and shift boot | 06Fg2 | For sale and Wanted | 46 | 2nd May 2007 06:03 |
| i shift mod | mihael | General commercial posts | 5 | 2nd March 2007 08:56 |
| Transmission ES With I-Shift | Pezza | Engines and Transmission | 10 | 24th June 2006 14:55 |
