This thread is about: Squeaky rear suspension, it's in Bugs, faults and irritations at the Honda Civic forum Civinfo; Noticed that my rear suspension is squeaking when I sit on the rear seats with the door open at both sides, and also if I ...
Old 12th July 2006, 21:29   #1 (permalink)
basegreen's Avatar
Noticed that my rear suspension is squeaking when I sit on the rear seats with the door open at both sides, and also if I reverse down a dropped kerb I hear it.
Any ideas?
Old 12th July 2006, 21:34   #2 (permalink)
jme1978's Avatar
Too many pies?
J
jme1978 is offline   Reply With Quote
Old 12th July 2006, 21:39   #3 (permalink)
basegreen's Avatar
Hmmm.. that could be the case but pushing down on the back end makes it happen to I think.
Old 12th July 2006, 21:52   #4 (permalink)
ianjay1956's Avatar
Squeeky Suspension
Got exactly the same problem on mine, problem with shock absorbers I am told - needs to go the the dealer for warrantly replacements.
ianjay1956 is offline   Reply With Quote
Old 12th July 2006, 22:02   #5 (permalink)
basegreen's Avatar
Yeah, will take it in.
Old 13th July 2006, 00:13   #6 (permalink)
Fedorov's Avatar
Is this a different issue to the original fault found on some models where you would hear some nasty sounds when going over speed humps etc???
Old 13th July 2006, 07:14   #7 (permalink)
StGeli's Avatar
Re: Squeaky rear suspension
Originally Posted by basegreen
Noticed that my rear suspension is squeaking when I sit on the rear seats with the door open at both sides, and I reverse down a dropped kerb I hear it.
You must have long legs!
StGeli is offline   Reply With Quote
Old 13th July 2006, 08:58   #8 (permalink)
basegreen's Avatar
Old 14th February 2007, 11:27   #9 (permalink)
Juuzi01's Avatar
Mine squeaking problem solved at first service. Rear right side spring were installed upside down in factory. Now corrected and squeaking is gone.
Juuzi01 is offline   Reply With Quote
Old 15th February 2007, 13:23   #10 (permalink)
The Doctor's Avatar
BG - wasn't this the subject of an earlier thread & Pottsy came up with the opinion that it was the type of suspension at the rear rather than a fault (ie a characteristic!)?
The Doctor is offline   Reply With Quote
Old 15th February 2007, 14:45   #11 (permalink)
basegreen's Avatar
Nope - in my case it was the faulty, recalled(ish) shocks. Got them replaced under warranty, and no noise any more.
Old 16th February 2007, 08:23   #12 (permalink)
The Doctor's Avatar
In that case I'll mention my squeaky rear suspension on my first service!
Old 24th February 2007, 12:33   #13 (permalink)
leodis41's Avatar
Rear Suspension Thunk
Just to pick up on a comment earlier inthis thread.
My rear suspension thunks over the large spedd humps, specifically when I come down off then, is this the infamous rear shocks issue?
Any ideas.
leodis41 is offline   Reply With Quote
Old 24th February 2007, 12:47   #14 (permalink)
PhilCarrie's Avatar
Any ideas.
I think the original shock fault was over any bump, the shocks made noise.
All shocks make some noise if the rebound rate of the shock is faster than the speed of the changing road surface, i.e. the suspension returns to normal length whilst in "mid air" over the hole etc...
Also, if it a LARGE speed hump then you may well be hearing the noise of the tyre coming off the edge of the hump and hitting the road again, like dropping off a curb at speed king of thing. maybe.
PhilCarrie is offline   Reply With Quote
Old 26th February 2007, 19:06   #15 (permalink)
whilst I hadn't noticed that I had this problem, at my service they turned the shocks over as a matter of course anyway
Old 26th February 2007, 23:13   #16 (permalink)
Perfect Guy!
Brodick's Avatar
let's hope they don't start now
Old 26th February 2007, 23:17   #17 (permalink)
that's blown it
Similar Threads for: Squeaky rear suspension
Suspension Rear Suspension - What are the known problems? richierich Bugs, faults and irritations 167 27th August 2008 21:56
Seats Squeaky seat... basegreen Bugs, faults and irritations 16 6th September 2007 20:01
Suspension Faulty front and rear suspension! vtecpower Bugs, faults and irritations 2 15th March 2007 11:34
Windows Squeaky Window tucker101uk Bugs, faults and irritations 7 12th December 2006 19:09
Windscreen Squeaky front pillar? cosmic girl Bugs, faults and irritations 13 19th September 2006 21:59
