| This thread is about: Drainage Holes For Doors, it's in Bugs, faults and irritations at the Honda Civic forum Civinfo; Heres another tip, those of you who have these bungs in place try removing one until you come across one that is starting to cause ... | ||
#21 (permalink) |
Heres another tip, those of you who have these bungs in place try removing one until you come across one that is starting to cause very minor corrosion to the drainage hole by holding moisture in. I will try and get some photos for you just for info
#25 (permalink) |
I had several Honda's and this is the first with these plastic drain covers.
They are a pain to clean the underside of the door and possibly cause water so remain inside. I think they are there only to improve the sound impression when slaming the door (make the door more air tight). I might remove them... Without the cover it looks 100% same hole as my other Honda's |
#26 (permalink) | |
Diesel Demon
#27 (permalink) |
drainage hole bungs
Mine went missing after having the passenger doors replaced on insurance after a little tussle with a BMW driver with the optional mirrors and indicators. Repairer could not order replacements and was told by Honda that these should be removed at PDI? Have I been conned?
#28 (permalink) | |
Wine and cooking !
Could someone post pictures of these pieces, because I cant found them in my car ! Could it be like said rey1234 that your dealers have made a "mistake" by letting it during the PDI (Question : Did they do this PDI correctly for the other points ? So What do they do also during service, do they respect what honda tell them ?) |
#30 (permalink) |
I see no reason why the dealer should remove them, unless it is a service note.
On the other hand, I never had the covers in any of my 11 previous Honda's... |
#31 (permalink) |
Hi here are the picyures for the bungs taken off my car.
If you look at the door photo you can see the dirt on the edge and some rust forming, also the picture of the bung on the shows rust stuck to it, and the flap that is supposed to open for water outlet. |
#32 (permalink) |
service manual says (in Hungarian) that it should be there..... so I dunno
what if we remove it? water will get out easily but it can go in???? (driving in wet...) where can the water get in the door by the way???? |
#33 (permalink) |
via the window seal it is no 100% water tight
maybe if Honda was to look a the door window seal this could possibly resolve the issue, by removing the bungs all you are doing is just getting over the problem, not resolving the cause, in the long term,water is still running through the inner of the door panel that will lead to further problems regards Pete |
#34 (permalink) |
Water running through the doors a problem??
Every single car in the world has drainage holes in the doors. Yes, some water does get between the window and the seal. They cannot make them water-tights because the window opens. There would be too much pressure and resistance against the glass if they tried. Anyway, it would be a slow trickle at worst in heavy, driving rain, not like any waterfall inside the door. |
#35 (permalink) | |
#36 (permalink) |
It seems that these little buggers are removing the paint!
I think I will remove them - Easier to clean the door edge - No more water inside - No more problems for possible rust |
#37 (permalink) |
Hi
just to clear things up - BUNGLE ** spot on. The outer door window seal is supposed to let water in, it can no way be made watertight, every car manufacturer has in place drainage holes in the bottom of the doors. The components inside the door are usually glavanised steel or aluminium and designed to operate in moist conditions. Electrical items are water resistant, but not watertight. The problem with Honda is that they have fitted bungs where they are not required, as all other Honda's dont have bungs. Also, when you open the door look at the door apeture, you will see a rubber weather seal. This is designed to prevent water and wid noise getting into the cabin. By removing the bungs doesnt mean you will let water into the car, it just wont happen unless you have a damaged door seal that is. By keeping the bungs in place is not a probelm as long as you check and keep them clear on a regular basis, otherwise they will cause rust, and paint to flake off, which is NOT what you want especially under doors. Hope this helps |
#38 (permalink) | |
#39 (permalink) |
The wider the tyres qnd the lower the profile, the more road noise.
I did put some extra layer of ''rubber sound proof spray'" inside the rear wheel arch, also added some damping material dehind the front plastic arch trim. I removed a lot of panels while installing stuff on my car, and all panels have sound proofing materilal. If you have noise while still, please check if the door are closed tight fit. I must admit that road noise is a problem on ALL Honda cars all over the world. I had a lot of Honda's big and small and all have the same problem. I also read about this problem in US magazines. The wider tyres and low profile does not help, it does give the car a special feel to driver. |
#40 (permalink) |
Mine seem to be draining OK.
I always seem to knock one or 2 off when I run the leather across the bottom of the door. Fortunately noticed and replaced them straight away. I'm in 2 minds whether to just remove them? |
LinkBack to this Thread: http://www.civinfo.com/forum/bugs-faults-irritations/4335-drainage-holes-doors.html
| YouTube - 2006 Honda Civic with Magnaflow Cat-Back | This thread | Refback | 28th August 2007 08:12 | |
| YouTube - Water coming out of a Honda Civic door | Post #78 | Refback | 15th August 2007 22:33 | |
| Which spec 5 doors or Type S | Sekhmet | Buying, Dealers and Servicing | 17 | 28th September 2007 20:18 |
| Bodykit Radical Doors | Munro | Gallery | 26 | 15th September 2007 09:38 |
| How many doors you've got? | mitokde | General Discussion | 24 | 18th October 2006 03:09 |
| Just 3 Doors Sir? | Charles_Harding | General Discussion | 2 | 17th October 2006 14:27 |
| New Mod: Lambo doors. | basegreen | General Discussion | 6 | 17th May 2006 11:57 |
