This thread is about: Drainage Holes For Doors, it's in Bugs, faults and irritations at the Honda Civic forum Civinfo; Been in dealers today ( Honda web site suggested I need a recall) and checked 2 new cars in the showroom... all bungs fitted. Does ...
Old 24th July 2007, 20:21   #121 (permalink)
St Thomas's Avatar
Cleaning bungs
Does using the doors make a difference? Mine was in the rear off side door which I do not use very often. Perhaps opening the door causes the flap to flap and clear the dirt etc.
I agree, impossible to fit upside down.
St Thomas is offline   Reply With Quote
Old 24th July 2007, 20:35   #122 (permalink)
Transalp's Avatar
Don't think it was designed like that. What was the basic idear???? They were better of spending that money on other specs or acc.
Transalp is offline   Reply With Quote
Old 24th July 2007, 21:23   #123 (permalink)
burnside's Avatar
Checked mine today after the weekend floods (Type-S picked up Fri), both doors have the first bung removed, but the other two are still there.
burnside is offline   Reply With Quote
Old 24th July 2007, 21:32   #124 (permalink)
Transalp's Avatar
Hmmm.... very strange. When I checked (with the first wash), the holes on the far end of the hinges on all 4 doors didn't have them . So removed in total 8 of them.
I understand that some had 12....
Still.....I 'm curious about TC's pictures...of the inside of the doors that is
Old 25th July 2007, 18:06   #125 (permalink)
Topcat's Avatar
Just for you Transalp
Im pleased to report my door was not affected at all by the water.
Old 25th July 2007, 18:23   #126 (permalink)
greeze's Avatar
Almost the same as me. Both front doors had the first bung removed (leaving two more in place) and the rear doors had no bungs removed at all!
Needless to say, as I don't find the sound of sloshing water soothing, they've all been removed and binned!
greeze is offline   Reply With Quote
Old 25th July 2007, 20:39   #127 (permalink)
Transalp's Avatar
Thumbs up
Glad to hear everything is okay, dispite the water. THANKS!!! TC
Very interesting to look at. I hope the dealer didn't look strange to see you moving around with a camera...
Old 18th August 2007, 16:05   #128 (permalink)
I picked up a new Civic on August 10th and it had no bungs in any doors.
According to the dealer it came that way from the factory.
Old 18th August 2007, 18:46   #129 (permalink)
Topcat's Avatar
As I said my dealer told me to remove all bungs as advised by HUK.
Old 18th August 2007, 18:50   #130 (permalink)
I was just confirming that it has been implemented in production also.
Old 18th August 2007, 18:51   #131 (permalink)
Topcat's Avatar
Yeah I know
I was just confirming that my dealership was right as it would appear others have said something different
Old 18th August 2007, 19:00   #132 (permalink)
Yeah I know
That was sort of my point exactly.
Old 27th August 2007, 23:23   #133 (permalink)
eyemdee's Avatar
My new (to me) Mar/April 07 car collected on Saturday has all 3 bungs fitted in all 4 doors and no sign of any water collection. Anyone know if these have been modified yet if they aren't working properly?
eyemdee is offline   Reply With Quote
Old 28th August 2007, 06:46   #134 (permalink)
TANSTAAFL!
GHGH's Avatar
Same here. Collected the car feb -07, with bungs.
Found no water yet, but now its raining heavy so I should find something if I got a problem.
Please remind me to check the bungs when I leave work at 1600 CET
Old 28th August 2007, 07:16   #135 (permalink)
I would still remove all the bungs completely.
Even though the majority of the water may be draining OK there is still an area around each bung which clogs up with muck. The water can only drain down to the bottom of the rubber flap.
I had a small circle of dirt around each door drain hole when I removed mine.
Old 28th August 2007, 07:35   #136 (permalink)
TANSTAAFL!
GHGH's Avatar
Supppose you're right.
Silly question: You just tear the out?
Old 28th August 2007, 07:35   #137 (permalink)
P@tje's Avatar
indeed it's for the door itself the best thing to remove the flaps. I mean in case of lifetime
Old 28th August 2007, 07:41   #138 (permalink)
Yes - they just pop out very easily, no tools neccessary.
When you do you may see the small build up of dirt behind them.
Old 28th August 2007, 07:42   #139 (permalink)
TANSTAAFL!
GHGH's Avatar
OK, thanks.
Old 5th November 2007, 16:07   #140 (permalink)
clindsay's Avatar
i just removed mine at the weekend and to be honest was horrified at the amount of gunk and water being held in by these bungs. would rather get wet feet once in a while than have a load of gloopy gunk held inside my doors slowly while they slowly rust away. stuck the hose in and gave it a blast and got far too much dirt and gunk out - anyone want to buy a set of bung hole thingys give me a shout mine are not going back in!!
clindsay is offline   Reply With Quote
LinkBack to this Thread: http://www.civinfo.com/forum/bugs-faults-irritations/4335-drainage-holes-doors.html
YouTube - 2006 Honda Civic with Magnaflow Cat-Back This thread Refback 28th August 2007 08:12
YouTube - Water coming out of a Honda Civic door Post #78 Refback 15th August 2007 22:33
Similar Threads for: Drainage Holes For Doors
Which spec 5 doors or Type S Sekhmet Buying, Dealers and Servicing 17 28th September 2007 20:18
Bodykit Radical Doors Munro Gallery 26 15th September 2007 09:38
How many doors you've got? mitokde General Discussion 24 18th October 2006 03:09
Just 3 Doors Sir? Charles_Harding General Discussion 2 17th October 2006 14:27
New Mod: Lambo doors. basegreen General Discussion 6 17th May 2006 11:57
