| This thread is about: Rattles, it's in Bugs, faults and irritations at the Honda Civic forum Civinfo; Great drive but a few dissapointments Having traded in for a 57 2.2 SE in February 2008 from a 2004 1.6 SE the drive is ... | ||
#21 (permalink) |
Having traded in for a 57 2.2 SE in February 2008 from a 2004 1.6 SE the drive is remarkable. However, the following are very annoying; Poor paintwork - Resulting in more front bonnet chips within 7 weeks than I had in 4 years with my previous Civic. Condensation - Always there right across rear window where glass meets plastic. Apparently a characteristic of the vehicle..... Rattling from rear - Still trying to pinpoint this Annoying noise from front interior left POSSIBLY GLOVE BOX AREA! - I guess the turbo is in this vicinity but should it really be so noisy at less than 30mph? Squeeky brakes - The car is only 6 months old but I am now getting this awful noise when the brakes are applied - sounds like metal on metal. The same noise occasionally comes in when the accelarator is depressed If anyone can help with these niggles it would be greatly appreciated. Its going to the dealer next week which I hope will give me more confidence if only a couple of these areas can be fully addressed ![]() |
#22 (permalink) | |
#23 (permalink) | |
Thanks for the reply.If any more rattle arrive I'll know where to look first! |
#24 (permalink) |
Rattle when vehicle reaches around 40mph
Hi Everyone, this is my first post on this site so appologies if this has been commented on in the past. I have taken delivery of a new Galaxy grey 1.8ES just over a week ago, and have noticed that there is an annoying rattle which appears when the car reaches aound the 40 - 45mph mark and continues over this speed
Great web site by the way |
#25 (permalink) | |
#26 (permalink) | |
Vivid Blue Rocks!!!
#27 (permalink) | |
#28 (permalink) |
Parcel Shelf Rattle / Squeak fix
If it helps anyone, my Mum's 5 door Civic had a rattle coming from the rear inside. A bit of investigation later showed it to be the parcel shelf rubbing against the ledges on which it rests.
The fix - which worked a treat - was to buy some black self-adhesive velcro about 1cm wide, only using the soft furry side, stick a strip along the ledge on which the parcel shelf sits, getting it right into the corner of the legde. Result was no more squeak/rattle whatsoever, and the strip looks like it was almost meant to be part of the original trim |
#31 (permalink) |
Can't find out how to easily access under mid console? Last edited by Pik; 15th June 2008 at 20:13. |
#32 (permalink) |
I thought I had a rattle in my car and when I listen I found that it was the passenger seatbelt rubbing against the plastic when it moves. It doesn't bother me but if it does it's an easy fix - even for me
#33 (permalink) |
Diesel of course
Just fixed my windscreen rattle by spraying (carefully) some silicone between the glass and the wiper plastic cowl...hey presto..No more rattles
| Trim rattles | CIVHEAD | Wiki Article Discussion | 8 | 10th May 2008 07:34 |
| Squeaks Squeaks and rattles and other minor problems | jalaman | Bugs, faults and irritations | 8 | 5th October 2007 22:19 |
| Windscreen rattles | CID | Wiki Article Discussion | 0 | 23rd February 2007 18:27 |
