| This thread is about: rear discs ??, it's in Bugs, faults and irritations at the Honda Civic forum Civinfo; after 11000 miles should the rear discs have hairline fractures or cracks in them ?... | ||
Hmm, I wonder how to best approach this. The problem is that the disc is classified as a consumable, so not covered by the warranty...
Firstly, you are sure you're not confusing brake pad marks: disc_crack1.jpg Or normal pitting: disc_crack2.jpg Real cracks are quite obvious, and will be a defect in the casting process. The rear discs do next to nothing, so your pad wear should be small. The pad material starts at 9mm, and replacement happens at about 2mm, so if you could measure the pad thickness (say it was 7mm) you could ask "is it normal to have to replace the rear discs 3 times for every pad change"? If the answer is no, then you could persuade the dealer that he has admitted that the discs are not of merchantable quality. I always approach these things with a bit of a laugh "you should see how bad those are!", trying to get the dealer to humorously agree. Any photos? |
i took the wheels off the rear and rubbed them with emmery cloth and sand paper as i thought it may be handbrake marks and they wouldn't budge?
no piccys. car is with dealer atm for replacement of squeaky center air vents and tailgate struts |
They probably won't budge. Would you say they looked more like my photo, or more like this:
crackedrotor.jpg ![]() |
Has the dealer spotted it?
I'm going to guess that they're just pad marks - cracks are pretty obvious. If the dealer hasn't seen them, just ask him to have a look. You sometimes see a bit of a crazing on the disc surface, again nothing to worry about. |
| Rusty Brake Discs | sprkeh | Cleaning and Styling | 11 | 24th June 2007 21:35 |
| Brakes rusting discs | chetan | Wheels, Tyres, Suspension and Brakes | 10 | 6th June 2007 12:52 |
| Brakes Brakes need discs skimming | Vivienne Bird | Bugs, faults and irritations | 6 | 2nd March 2007 23:43 |
| Built in CD Weird glitch playing MP3 CDs/CDR discs | Diggers | Ipods, MP3 Players and ICE | 20 | 4th February 2007 16:32 |
| Built in CD WMA Discs | fishyuk | Ipods, MP3 Players and ICE | 42 | 21st December 2006 08:27 |
