This thread is about: Creaking Rear!, it's in Bugs, faults and irritations at the Honda Civic forum Civinfo; Hi, has anyone else had a problem with a creaking sound coming from the rear? It only happens first thing in a morning and again ...
Old 12th May 2007, 09:49   #1 (permalink)
alloallo's Avatar
Angry Creaking Rear!
Hi, has anyone else had a problem with a creaking sound coming from the rear? It only happens first thing in a morning and again at the end of the day on my return home from work, i.e. after the car has been parked for a while. It's hard to tell whether it is coming from the tailgate or some springs. Of course the dealer, yet again! has no idea what it is and it will never do it whilst there as I've just driven 25 miles down the motorway beforehand. It creaks for a few seconds when I reverse, then again as I drive off.
alloallo is offline   Reply With Quote
Old 12th May 2007, 09:58   #2 (permalink)
paul_b's Avatar
This sounds very similar to a problem I am experiencing.
I notice it usually when turning left to drive left up a small (not tried steep) gradient. I recently parked on a gradient overnight, and the creaking was the worst I'd heard it when I started up the next morning. After a couple of seconds and back to normal driving, the creaking stopped, but it did sound quite worrying.
My car was with my dealer for the past 2 days, having a few warranty bits done. I had been told my rear shocks were on the replace list, and expected this done too - which I had attributed the creaking to. However, picking the car up yesterday, I was told my shocks were not on the replace list and therefore they were not changed or even looked at! I also experience clanking/creaking I would not expect on occasion when passing over speed bumps.
So the car is going back in for a few days for some investigation. In the meantime, I'm going to try to work out exactly when the problem happens to give the dealer the best chance of recreating the problem locally.
paul_b is offline   Reply With Quote
Old 12th May 2007, 10:02   #3 (permalink)
There could be a number of things that cause this - rear springs upside down, poor welding, tailgate rubbers not lubricated and so on.
See if any of this lot fits with what you have:
http://www.civinfo.com/forum/forumdi...fix=Suspension
Old 12th May 2007, 10:27   #4 (permalink)
alloallo's Avatar
Angry
My shocks too also sound like they need replacing. Mine is an 06 model, 1.8 SE probably built around July/August. I was told they didn't need replacing by the dealer but am not convinced as the noise and thud my car makes when going over potholes is enough to make your teeth fall out! All the dealer said was that mine was one of the quietest that they had heard. I feel sorry for some of the other Civic drivers out there if mine is the quietest. Another trip back to the dealer and another call to Honda CS. I will let you know how I get on.
Old 12th May 2007, 10:53   #5 (permalink)
JB75's Avatar
I appear to have this problem again, even though my rear shocks have been adjusted at least twice. I first noticed it when I bought the car, yet after the second return to the dealer it seemed to have been resolved. In recent weeks though I've once again heard that creaking/groaning sound when pulling away after being parked for a while.
As I've made about ten return visits to the dealer in total, I'll proably leave it until the service is due in August. It's not good though: nearly nine months down the line and I'm still collecting unusual noises from around the car.
JB75 is offline   Reply With Quote
Old 12th May 2007, 13:07   #6 (permalink)
Topcat's Avatar
Snap, I have 1.8 SE, 06 model exactly the same noise from front drivers side when going over holes, speed bumps etc and knocking at the rear from the left after the car has been stationary for a long while. Apparently mine are fine too but they have only driven it to hear the noise
My car is going in for a service at some point soon an im going to insist they get it up on the ramps and check properly.
Old 12th May 2007, 16:00   #7 (permalink)
terry's Avatar
My car is currently with the dealer to have some issues sorted out, and creaking from the rear is one of them. My driveway is on a slope, and when reversing off there is some creaking which continues when I pull forward. The loan car also does the same. I reckon it is something to do with the torsion bar
Old 12th May 2007, 16:35   #8 (permalink)
alastair b's Avatar
Creaking
I had a creaking noise from the rear of my car when I bought it(April 06),my rear shocks were changed,noise was still there.
After a check of the tailgate I found that where the rubbers rested on the bumper the pressure was causing the bumper to flex,causing an annoying creaking noise.
I put plastic spacers in behind the bumper where the rubbers rested.
Problem solved.
I am not sure if this is what is causing your creak but it certainly cured mine.All the best.
alastair b is offline   Reply With Quote
Old 12th May 2007, 17:51   #9 (permalink)
JoeyF's Avatar
Originally Posted by alastair b View Post
Problem solved.
Hi alastair,
Please could you tell me where the spacers were fitted and what type of spacers you used, I have the same problem I think I might give this a go...
Old 12th May 2007, 18:02   #10 (permalink)
alastair b's Avatar
Spacers
Hello Joey,
You can see the spacer in the picture,believe it or not it is one half of a plastic clothes peg,I broke off the top part and this left me with a tapered shaft.I just wedged it in behind the bumper,took a couple of minutes.
Let me know how you get on.All the best.
Old 12th May 2007, 18:05   #11 (permalink)
JoeyF's Avatar
Hello Joey,
I'm going now to go nick a peg from the wife's peg bag (if I can find it that is!!) cheers..
Old 12th May 2007, 18:51   #12 (permalink)
sexykungfufighter's Avatar
got the same problem! been told i need new shocks! the noise comes from the rear from cold start
sexykungfufighter is offline   Reply With Quote
Old 14th May 2007, 10:33   #13 (permalink)
The Doctor's Avatar
Yes I have this as well. It only happens first thing in the morning, reversing off the drive. If I bounce the rear end of the car before reversing, it creaks for the first 2 or 3 pushes & then resolves itself. Is there something in there which is self lubricating & dries out after standing all night?
The Doctor is offline   Reply With Quote
Old 14th May 2007, 13:31   #14 (permalink)
Fedorov's Avatar
Been discussed a few times on here, mine has always done this from new 1yr ago, never resolved, it's a characteristic of my car now
Old 14th May 2007, 14:05   #15 (permalink)
Charles_Harding's Avatar
Got my squeak sorted at the stealers.
He said that Honda know of the fault but will only cure it if the customer requests it, therefore avoiding the need for the embarrassing recall.
Nice and quiet now.
"Have you ever noticed that wrong numbers are never engaged?"
Charles H.
Old 14th May 2007, 14:14   #16 (permalink)
Topcat's Avatar
Pathetic!!
Old 14th May 2007, 14:53   #17 (permalink)
Originally Posted by Topcat View Post
Pathetic!!
There are not just following a trend, they're setting it!
"Don't really want to be a politian. Must be hard being right all the time!"
Charles H.
Old 15th May 2007, 11:16   #18 (permalink)
It is not the rear shocks, that is a different noise.
But it is something that almost all 06 Civic's do.....it was funny driving the one of the dealer lot with the two Honda bod's there....they said, 'whats that noise!'.
I then explained that all Civics do it for the first 30 seconds are so after pulling away if the car has been standing outside all night.
You know...I also hear this noise if I have just cleaned the car and left it a few hours. I think it is water or condensation collecting around the handbrake and rear suspension that is then causing a creak for whatever reason. I think it will never be solved...but my advice is to drive it before you try to sell it privately in the future. Cos no-one will believe it when you say they all do it!
Cheltenhamshire is offline   Reply With Quote
Old 15th May 2007, 11:45   #19 (permalink)
pcr
pcr's Avatar
Some of these descriptions sound like the creaking I had, sounded quite similar to a loose floorboard and was caused by the spot welded seam along the sill flexing.
Old 15th May 2007, 16:49   #20 (permalink)
Scorcher's Avatar
I have heard that the car settles overnight then when you first move off in the morning the gas in the shocks expands hence the creaking noise. Apparently on the first models many had to have replacement shocks as they has insufficient gas in them.
Now I am no expert but this explanation makes sense to me.
Scorcher is offline   Reply With Quote
Similar Threads for: Creaking Rear!
Type R - Trick Rear Seats or Magic Rear Seats ??? Munro Type-R 27 30th November 2007 20:36
Transmission Creaking gear change Topcat Bugs, faults and irritations 20 7th August 2007 08:38
Creaking Civic chris rowden Introduce yourself 5 8th June 2007 07:23
Options Rear Camera Or Rear Sensor??which To Go J777JSY Buying, Dealers and Servicing 19 21st January 2007 17:20
Squeaks Creaking trim around the back doors.... Cheltenhamshire Bugs, faults and irritations 15 29th September 2006 21:25
