| This thread is about: air con check?, it's in Bugs, faults and irritations at the Honda Civic forum Civinfo; How do folks Is there a diagnostic for checking the air con system? I recently got a 2006 ESI and when the air con is ... | ||
air con check?
How do folks
Is there a diagnostic for checking the air con system? I recently got a 2006 ESI and when the air con is on, it belts out hot heat even when its cold! Is there anyway of checking the gas level myself? Took it to kwik fit and they said that theres plently of gas, im not so sure though. Dealer wasnt much use either, wanted 80 quid to investigate and not to fix it! Any help would be great Cheers |
#12 (permalink) |
Quick question guys,
Does the Air con system use the outside air temperature sensor? If this sensor is not working, will the air con not work? I leave the floor open to suggestions |
Flyboy13,
I assume your car has Climate Control in which case there are a good few sensors, incuding outside temp, which determine the temp of the air pushed out. Press Auto, select temp, does the cabin reach that temp ? No, then it's faulty, the dealer must investigate and fix it under warranty. Remember, you've paid for that warranty. |
#14 (permalink) |
| New Car Check List - What would YOU check? | tonyt | General Discussion | 1 | 27th February 2007 18:55 |
| Collection What to check for | steeeveee | Buying, Dealers and Servicing | 5 | 24th January 2007 10:20 |
| Oil Check oil level....HELP | kevin_lufc | Engines and Transmission | 23 | 19th September 2006 23:48 |
| Other Check this out 2! | Doody2008 | Gallery | 5 | 7th September 2006 20:46 |
| Other Check this out! | Doody2008 | Gallery | 1 | 4th September 2006 16:01 |
