| This thread is about: Reversing sensor problem, it's in Bugs, faults and irritations at the Honda Civic forum Civinfo; I know it's gonna have to go back to be looked at, I just wondered if anyone else has come across this? When reversing, all ... | ||
When reversing, all of a sudden the beeper will do the steady beep - like someone's walked behind the car - which has jumped me a couple of times. This has happened the last two or three days and now appears to be an intermittent long beep. I've checked the actual sensors in case there's something stuck on any of them and they're fine. So I'm now assuming it's a wiring fault. Annoying though. |
Its probably a wiring fault, mine did that but it was obvious that they were broken as one of the sensors had popped inside (broken bracket apparently)
I wouldnt rely on them if I were you for parking close to anything just in case, bloody annoying as you say |
Are they offical honda sensors? If so, get them to replace them...
If not you need to isolate the faulty sensor. I had this with some I fitted, It was a faulty sensor which I replaced. No problem now |
| Parking Reversing Camera | Sandozer | Electronics | 7 | 16th March 2008 11:29 |
| Parking OEM sensor problem | markcook | Electronics | 1 | 18th September 2007 23:13 |
| Video Reversing camera - photos | Pottsy | Electronics | 42 | 8th September 2007 23:05 |
| Parking Reversing camera | Giggy | Electronics | 7 | 31st August 2007 23:57 |
| Reverse Reversing lights | civvie06 | Lights | 22 | 10th September 2006 23:31 |
