This thread is about: IMPORTANT!!! Immobiliser Locks out when jump starting!, it's in Bugs, faults and irritations at the Honda Civic forum Civinfo; Hi All - Just thought i would post a story of the fiasco i've had this morning... To cut a long story short I was ...
Old 30th June 2007, 10:32   #1 (permalink)
tucker101uk's Avatar
Thumbs down IMPORTANT!!! Immobiliser Locks out when jump starting!
Hi All -
To cut a long story short I was a div and left my lights on last night. Tried to jump start to car this morning, and the immobiliser light came on and stayed on - so although the car turned over, it wouldnt start.
Cue the AA, towage to my local Honda dealer, and following a short conversation with the Mr Man at Honda, i became aware of a serious fault.
If you connect the jump leads to the battery with the key in the ignition, the immobiliser scrambles and shuts down, meaning that Mr Honda needs to plug his computer into the car to get it started again. Therefore the moral of the story is:
***Make sure your keys ARE NOT in the ignition before you connect your jump leads to the battery!!!!***
Apparently Honda are aware of this, but have failed to inform anyone about it. Nice one!!!
tucker101uk is offline   Reply With Quote
Old 30th June 2007, 10:42   #2 (permalink)
Dalboy's Avatar
Originally Posted by tucker101uk View Post
Hi All -
Worth knowing
Dalboy is offline   Reply With Quote
Old 30th June 2007, 13:15   #3 (permalink)
Harris Tweed
Anthony's Avatar
Hi All -
Thanks for the heads up Tom...
Anthony.
Anthony is offline   Reply With Quote
Old 30th June 2007, 13:56   #4 (permalink)
pcr
pcr's Avatar
Good piece of advice, and I assume the same applies to disconnecting/reconnecting the battery ??
Old 30th June 2007, 19:54   #5 (permalink)
Handy tip, one for the wiki...
Old 30th June 2007, 21:15   #6 (permalink)
Exclamation
this problem only affects 2006 5dr cars only,When the ignition keys are left in the ignition and jump leads are connected to the vehicle it causes an electrical disturbance (chattering) to the +B voltage, this disturbance causes a problem with the data within the EEPROM. The MICU sees the data problem and re-writes the whole EEPROM contents which also overwrites the key, when you try to start the car the immobiliser does not recognise the key and prevents the engine from starting.
All 3dr cars & all those built from the end of 2006 should not be affected as the eeprom software has been made more resistant to electrical disturbance when jump starting !
hondatech is offline   Reply With Quote
Old 30th June 2007, 22:04   #7 (permalink)
12th June 2006 1.8EX
WoolyCiv's Avatar
Should this not be the subject of a recall to correct all the 2006 models? I would also like to know the answer to PCR's question about disconnectng/reconnecting the battery. Click the image to open in full size.
Old 1st July 2007, 09:44   #8 (permalink)
jofawe's Avatar
you learn something new everyday...
jofawe is offline   Reply With Quote
Old 1st July 2007, 15:41   #9 (permalink)
I personally dont think its a serious enough problem to warrant a recall,if the simple precaution of removing your keys prior to connecting your jump leads/pack is followed then there isnt a problem,as for concerns over connecting/disconnecting battery leads etc then also take the keys out of the ignition. This is good practice really,very similar to removing battery leads when welding on a car,you are trying to prevent any voltage spikes from frying any ecu`s etc.
Old 2nd July 2007, 17:56   #10 (permalink)
cracking (pair of) answers there hondatech, cheers!
Old 2nd July 2007, 20:10   #11 (permalink)
This simple precaution only works if you've read this thread and know you need to remove the key to prevent a problem in the first place .
You're right it is good practice. Now, I've had plenty of practice with jump starting my Civic over the last few months, and never come across this problem. It 's probably because I've never have the key in the ignition before connecting the jump leads - but I wouldn't swear to that.
chaser is offline   Reply With Quote
Old 2nd July 2007, 21:36   #12 (permalink)
pcr
pcr's Avatar
I would think the average driver will have no idea that the ignition key needs to be removed when jump starting, Honda should do something abour this, even if it is just a warning label fitted to the top of the battery.
Imagine returning from holiday to a flat battery, no problem, the parking lot will jump start it. Oh sh*t, you now need a tow to a Honda dealers who will be open on Monday.
Old 2nd July 2007, 21:45   #13 (permalink)
WoolyCiv's Avatar
Would this occur if you offered a jump start to some else? I was always told to start my engine then connect from the dead battery to the good battery (Neg first then postive).
Would this cause the voltage fluctuation and if so would it be enough to scramble the eeprom? I always noted a drop in engine revs when the 'flat' battery was conected as the alternator came online so I presume the good battery voltage had dropped quite a bit.
Old 2nd July 2007, 21:56   #14 (permalink)
romatic's Avatar
Thank you for that info, Hondatech.
romatic is offline   Reply With Quote
Old 2nd July 2007, 23:28   #15 (permalink)
paul_b's Avatar
This seems like a serious issue to me.
A large percentage of Civic owners are not members of this forum and will not have a clue about this.
pcr sums up my thoughts on the issue. The cost and inconvenience of what should be an unnecessary tow is not going to do any good for Honda's reputation in my opinion.
paul_b is online now   Reply With Quote
Old 2nd July 2007, 23:33   #16 (permalink)
A sticker on the battery would be easy.
Old 3rd July 2007, 08:10   #17 (permalink)
Bog
Bog's Avatar
I agree, Honda could write to all 2006 5dr owners highlighting the problem and enclose a battery sticker to remind them.
This would also be much cheaper than a recall and show customers they care!
Old 3rd July 2007, 08:26   #18 (permalink)
Wine and cooking !
l-noel's Avatar
Or they can do a remapping of the ECU during the next service.
Old 9th July 2007, 11:33   #19 (permalink)
Personally I think that something should be done.
Normally jumping the car with the keys in the ignition wont cause an issue, and i dont see why it should with this car specifically.
More importantly, why havnt current owners been informed, if Honda is aware of the issue.
If i didnt have AA cover then i would have been screwed...
Similar Threads for: IMPORTANT!!! Immobiliser Locks out when jump starting!
Options taken the jump to honda land!! davep Buying, Dealers and Servicing 3 9th October 2007 22:27
Alarm Immobiliser Unit, where is it ? davek9 Electronics 10 17th July 2007 10:20
Alarm 1.4 SE - DSI; does it have a Thatcham Cat 1 Immobiliser? generationgav Electronics 12 22nd May 2007 17:59
Dead Locks (super locks) nitin881 Type-R 11 6th May 2007 19:29
Engine Non starting 2.2ES Normsky Bugs, faults and irritations 15 12th October 2006 17:47
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20
